Security ImageMagick vulnerabilities CVE-2016-3714 (imagetragick) active exploitation confirmed
Discussion in 'CentOS, Redhat & Oracle Linux News' started by Revenge, May 4, 2016.
    12:53 AM
    what's output for
    convert -list policy
    php --ri imagick
    yum list ImageMagick-last*  --enablerepo=remi --disableplugin=priorities -q
  2. trxerz
    trxerz Member
    75
    6
    3:53 PM
    Forget it, my bad, the policy.xml get overwritten after yum update :banghead:
    12:53 AM
    latest centmin.sh menu option 15 for 123.09beta01 auto reapplies the policy.xml fixes when ran for updates as does 123.08stable :)
    so update centmin mod code via centmin.sh menu option 23 submenu option 2
  4. trxerz
    trxerz Member
    75
    6
    3:53 PM
    So, when auto yum nightly update run, the policy.xml will overwritten again?
    Should I run option 23 Update Centmin Mod Code Base?
    12:53 AM
    yes centmin.sh menu option 23 submenu option 2 to update code base first - usually i do that before running any menu options to ensure on latest code first
    but yum updates may overwrite policy.xml not sure as i haven't had an update for it to verify - did yours overwrite ? 123.09beta01 whenever you run centmin.sh it auto checks policy.xml and reapplies fixes silently too :)
  6. trxerz
    trxerz Member
    75
    6
    3:53 PM
    I've no idea about it, but it got overwritten once I run
    yum -y update --enablerepo=remi --disableplugin=priorities
    Any links about how to safely update to 123.09beta01 from 123.08stable?
    12:53 AM
    centmin.sh menu option 23 submenu option 3 in 1st post at Beta Branch - Centmin Mod .09 beta branch Testing | Centmin Mod Community
    and links below
    Getting Started Guide step 19 outlines also how to keep Centmin Mod code updated or how to switch version branches.
    Centmin Mod LEMP stack's script code is constantly updated for improvements, bug fixes and security fixes so keeping the Centmin Mod code up to date is important. With Centmin Mod 1.2.3-eva2000.08) (123.08stable) and higher releases, a newly added centmin.sh menu option 23 allows much easier code updates and version branch swicthing via Git backed environment you can setup. For full details read the following links:
    1. Upgrading the actual Centmin Mod code outlined at Upgrade Centmin Mod. This is heart of Centmin Mod where the code is the engine that runs centmin.sh shell based menu and all the automation you're accustomed to. You can easily update within a Centmin Mod version branch or switch version branches via centmin.sh menu option 23 outlined here.
    2. Upgrade software that Centmin Mod installed or manages. For this part following outline at How to upgrade Centmin Mod software installed on your server.
  8. BobbyWibowo
    BobbyWibowo Active Member
    197
    42
    Indonesia
    9:53 PM
    1.17.x
    10.3.x
    ./test.sh
    testing read
    SAFE
    testing delete
    SAFE
    testing http with local port: 46016
    SAFE
    testing http with nonce: HNHNZY4F
    SAFE
    testing rce1
    SAFE
    testing rce2
    SAFE
    testing MSL
    SAFE
    Tried the PoCs. Seemed to be working properly ;)
  9. trxerz
    trxerz Member
    75
    6
    3:53 PM
    I forgot to update code base first (option 2) and straight to option 3. Is it OK?
    Should I uninstall yum-cron to prevent policy.xml overwritten when Imagick updated?
  10. BobbyWibowo
    197
    42
    Indonesia
    9:53 PM
    1.17.x
    10.3.x
    @trxerz I believe you can exclude certain packages from yum cron. If I remember correctly, I had excluded ImageMagick from yum cron, for some reason.
  11. trxerz
    trxerz Member
    75
    6
    3:53 PM
    Halo mas bob,
    I've no idea about it, can you show me any links? especially to exclude Imagick
  12. BobbyWibowo
    197
    42
    Indonesia
    9:53 PM
    1.17.x
    10.3.x
    @trxerz I did it a couple months ago, so I can't really remember where I found the info.
    But here's what I have in yum-cron-hourly.conf and yum-cron.conf:
    [base]
    # This section overrides yum.conf
    exclude = ImageMagick*
    I'm not really sure what [...] does in the config file. But to be safe, just add it after [base], I suppose.
    FYI, I've set yum-cron.conf not to download or apply updates and yum-cron-hourly.conf to always download and apply "default" updates (as opposed to its default, "security" updates only). So it should check updates every hour, but so far there's no issue with policy.xml.
    12:53 AM
    Word from Wordpress ImageMagick Vulnerability Information – Make WordPress Core
    12:53 AM
    Follow up by Sucuri Analyzing ImageTragick Exploits in the Wild - Sucuri Blog
  15. Revenge
    Revenge Active Member
    469
    93
    Portugal
    3:53 PM
    1.9.x
    10.1.x
    For IPS users like me, Invision released a security fix, that even if someone have a vulnerable ImageMagick version, it will not be exploitable.
    12:53 AM
  17. Oxide
    Oxide Active Member
    534
    29
    12:53 AM
    I ran yum update and there was a new openssl/libre i think.
    imagick
    imagick module => enabled
    imagick module version => 3.4.2
    imagick classes => Imagick, ImagickDraw, ImagickPixel, ImagickPixelIterator, ImagickKernel
    Imagick compiled with ImageMagick version => ImageMagick 6.9.3-10 Q16 x86_64 2016-05-04 http://www.imagemagick.org
    Imagick using ImageMagick library version => ImageMagick 6.9.3-10 Q16 x86_64 2016-05-04 http://www.imagemagick.org
    ImageMagick copyright => Copyright (C) 1999-2016 ImageMagick Studio LLC
    ImageMagick release date => 2016-05-04
    ImageMagick number of supported formats:  => 225
    ImageMagick supported formats => 3FR, AAI, AI, ART, ARW, AVI, AVS, BGR, BGRA, BGRO, BIE, BMP, BMP2, BMP3, BRF, CAL, CALS, CANVAS, CAPTION, CIN, CIP, CLIP, CMYK, CMYKA, CR2, CRW, CUR, CUT, DATA, DCM, DCR, DCX, DDS, DFONT, DNG, DOT, DPX, DXT1, DXT5, EPDF, EPI, EPS, EPS2, EPS3, EPSF, EPSI, EPT, EPT2, EPT3, ERF, EXR, FAX, FITS, FRACTAL, FTS, G3, GIF, GIF87, GRADIENT, GRAY, GROUP4, GV, H, HALD, HDR, HISTOGRAM, HRZ, HTM, HTML, ICB, ICO, ICON, IIQ, INFO, INLINE, IPL, ISOBRL, ISOBRL6, JBG, JBIG, JNG, JNX, JPE, JPEG, JPG, JPS, JSON, K25, KDC, LABEL, M2V, M4V, MAC, MAGICK, MAP, MASK, MAT, MATTE, MEF, MIFF, MKV, MNG, MONO, MOV, MP4, MPC, MPEG, MPG, MRW, MSL, MSVG, MTV, MVG, NEF, NRW, NULL, ORF, OTB, OTF, PAL, PALM, PAM, PANGO, PATTERN, PBM, PCD, PCDS, PCL, PCT, PCX, PDB, PDF, PDFA, PEF, PES, PFA, PFB, PFM, PGM, PICON, PICT, PIX, PJPEG, PLASMA, PNG, PNG00, PNG24, PNG32, PNG48, PNG64, PNG8, PNM, PPM, PREVIEW, PS, PS2, PS3, PSB, PSD, PTIF, PWP, RADIAL-GRADIENT, RAF, RAS, RAW, RGB, RGBA, RGBO, RGF, RLA, RLE, RMF, RW2, SCR, SCT, SFW, SGI, SHTML, SIX, SIXEL, SPARSE-COLOR, SR2, SRF, STEGANO, SUN, SVG, SVGZ, TEXT, TGA, THUMBNAIL, TIFF, TIFF64, TILE, TIM, TTC, TTF, TXT, UBRL, UBRL6, UIL, UYVY, VDA, VICAR, VID, VIFF, VIPS, VST, WBMP, WEBP, WMF, WMV, WMZ, WPG, X, X3F, XBM, XC, XCF, XPM, XPS, XV, XWD, YCbCr, YCbCrA, YUV
    imagick.locale_fix => 0 => 0
    imagick.skip_version_check => 0 => 0
    imagick.progress_monitor => 0 => 0
    How do I confirm, i am on the safe version?
    12:53 AM
    As expected forum sites are getting attacked via imagemagick vulnerabilities for those without the workaround fix or updated imagemagick 6.9.3.10 versions ImageTragick Exploits Detected in Live Attacks against vBulletin, IP.Board Sites
  19. Revenge
    469
    93
    Portugal
    3:53 PM
    1.9.x
    10.1.x
    Im curious why they said IPB sites(i think its the only one that took measures against this exploit ) and not Xenforo for example.
