SSL Letsencrypt I keep getting SSL Error and How to Switch from Selfsigned to Letsencrypt SSL
Discussion in 'Domains, DNS, Email & SSL Certificates' started by radbrad, Aug 11, 2020.
  1. radbrad
    radbrad Member
    34
    6:07 PM
    • CentOS Version:CentOS 7 64bit
    Yesterday I installed 5 websites to my server using the 22 option with self signed SSL and then used Cloudflare SSL selected to FULL.
    Now, 3 of my sites working fine except 2 websites where I'm getting the below error
    Previously I was not aware that I can install "Letsencrypt SSL" and installed Self signed SSL.
    Is it fine to have a self-signed SSL?
    My question: Is there a way to change the self-signed SSL to Letsencrypt SSL?
    Regards?
  2. Jon Snow
    Jon Snow Active Member
    855
    172
    9:37 AM
    Nginx 1.13.9
    MariaDB 10.1.31
  3. pamamolf
    4,101
    428
    3:37 PM
    Nginx-1.26.x
    You can use:
    /usr/local/src/centminmod/addons/acmetool.sh reissue-only yourdomain.com live
    55,247
    12,253
    10:37 PM
    It's fine to use self-signed SSL behind Cloudflare Full SSL mode :) Just make sure the domains actually have cloudflare orange cloud proxy enabled in DNS and not disabled which bypasses cloudflare and goes direct to your nginx HTTPS which would then report invalid SSL cert in web browsers.
    55,247
    12,253
    10:37 PM
    yes like @pamamolf mentioned, try acmetool.sh add reissue-only option for existing nginx HTTPS SSL vhosts with domain.com.ssl.conf vhost config files that exist. This only does reissue of letsencrypt SSL cert without touching the nginx vhost. Ideal for use when you tried creating a Nginx HTTPS SSL default vhost site but letsencrypt SSL issuance failed the first time. When it fails, Centmin Mod usually falls back to self-signed SSL as a place holder for the domain.com.ssl.conf vhost config. When you run:
    cd /usr/local/src/centminmod/addons
    ./acmetool.sh reissue-only domain.com live
    It will only try reissuing the letsencrypt SSL certificate for the domain = domain.com for live production SSL certificate without touching any of the existing nginx vhost at domain.com.ssl.conf
  6. radbrad
    radbrad Member
    34
    6:07 PM
    Thanks , This worked.
