I got the error "ERR_TOO_MANY_REDIRECTS" when using SSL
Discussion in 'Domains, DNS, Email & SSL Certificates' started by Manhhailua, Jul 16, 2016.
  1. Manhhailua
    Manhhailua Member
    39
    Hanoi
    7:11 PM
    1.11.1
    10.0.x
    My wordpress home page is broken with "ERR_TOO_MANY_REDIRECTS". I'm using default nginx config from centmin installation (without any modification). I got the same error when force Ghost Blog to redirect site to https.
    My site url:
    1. http://isavn.com
    2. https://isavn.com
    55,229
    12,253
    10:11 PM
  3. Manhhailua
    Manhhailua Member
    39
    Hanoi
    7:11 PM
    1.11.1
    10.0.x
    My domain.conf content:
    # server {
    #   listen   80;
    #   server_name codek.org;
    #   return 301 $scheme://www.codek.org$request_uri;
      server_name codek.org www.codek.org;
      # ssi  on;
      access_log /home/nginx/domains/codek.org/log/access.log combined buffer=256k flush=60m;
      error_log /home/nginx/domains/codek.org/log/error.log;
      root /home/nginx/domains/codek.org/public;
      location ~ (?:^|/)\. {
        deny all;
        #autoindex  on;
        #autoindex_localtime on;
    And here is domain.ssl.conf:
    # For SPDY SSL Setup
      return 302 https://$server_name$request_uri;
      listen 443 ssl http2;
      ssl_dhparam /usr/local/nginx/conf/ssl/codek.org/dhparam.pem;
      ssl_certificate      /usr/local/nginx/conf/ssl/codek.org/codek.org.crt;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/codek.org/codek.org.key;
      # mozilla recommended
      ssl_ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA:!CAMELLIA:!DES-CBC3-SHA;
      #spdy_headers_comp 5;
      ssl_buffer_size 1400;
      ssl_session_tickets on;
      # enable ocsp stapling
      #resolver_timeout 10s;
      #ssl_stapling on;
      #ssl_stapling_verify on;
      #ssl_trusted_certificate /usr/local/nginx/conf/ssl/codek.org/codek.org-trusted.crt;
      # ssi  on;
        deny all;
        #autoindex  on;
    Every pages works fine but the homepage if I use a ssl force plugin (Really Simple SSL) then if I turn the plugin off... My home page will be broken.
    55,229
    12,253
    10:11 PM
    you don't need force ssl plugin if you redirect http to https at nginx level. You only need one of the nginx vhosts if you use http to https redirect. See instructions at below
    Posted at centminmod.com/nginx_domain_dns_setup.html#httpsredirect
    key to testing is using 302 temp redirect first in a private incognito browser session otherwise the problems you can experience may end up being due to browser caching or 301 permanent redirects unless you clear browser cache and reboot local computer(s) and even then some web browsers don't let go of 301 permanent redirect browser cache that willingly :)
  5. Manhhailua
    Manhhailua Member
    39
    Hanoi
    7:11 PM
    1.11.1
    10.0.x
    Great, eva! It saved my day! :cool:
  6. Manhhailua
    Manhhailua Member
    39
    Hanoi
    7:11 PM
    1.11.1
    10.0.x
    Ouch! This problem continued to occur when I used cloudflare. I could not access my website. I created a file named "cloudflare.conf" at "/usr/local/nginx/conf/" containing Cloudflare's ips.
    And this is my SSL vHost config (I disabled HTTP vHost (official way)):
        server_name mqteam.com www.mqteam.com;
        return 301 https://$server_name$request_uri;
        ssl_dhparam /usr/local/nginx/conf/ssl/mqteam.com/dhparam.pem;
        ssl_certificate      /root/.acme.sh/mqteam.com/mqteam.com.cer;
        ssl_certificate_key  /root/.acme.sh/mqteam.com/mqteam.com.key;
        #ssl_stapling on;
        #ssl_trusted_certificate /usr/local/nginx/conf/ssl/mqteam.com/mqteam.com-trusted.crt;
        # ssi  on;
        access_log /home/nginx/domains/mqteam.com/log/access.log combined buffer=256k flush=60m;
        error_log /home/nginx/domains/mqteam.com/log/error.log;
        root /home/nginx/domains/mqteam.com/public;
        # uncomment cloudflare.conf include if using cloudflare for server and/or vhost site
            deny all;
            #autoindex  on;
            try_files    $uri $uri/ /index.php?$args;
    I've just realized that I did not allow any of cloudflare IPs from CSF. Do I have to do this step!?
    55,229
    12,253
    10:11 PM
    Are you using cloudflare's ssl certificate and not your own ? if you are then you actually only need the non-http nginx vhost as cloudflare looks to non-https origin for backend not the https backend unless you have full strict ssl enabled in cloudflare
    Did you also enable cloudflare to http to https redirect ?
    Centmin Mod LEMP stack installs CSF Firewall out of the box, so to be able to remotely connect to external servers, you need to whitelist and allow the remote IP address see the info below:
    If you use a reverse proxy in front of Centmin Mod Nginx, you need to setup nginx realip to be passed onto Nginx.
    See Getting Started Guide step 4 and setting correct real ip via nginx module config at Nginx Cloudflare & Incapsula (reverse proxy HttpRealIpModule) - CentminMod.com LEMP Nginx web stack for CentOS.
    If using Centmin Mod 123.09beta01 and newer, there's an added tools/csfcf.sh script to aid in this. Details at:
    You just need to setup a cronjob to run
    /usr/local/src/centminmod/tools/csfcf.sh auto
    and ensure your nginx.conf http{} context has the include file /usr/local/nginx/conf/cloudflare.conf and/or your individual nginx vhost's server contexts has the same include file
    http {
    map_hash_bucket_size 128;
    map_hash_max_size 2048;
    server_names_hash_bucket_size 128;
    server_names_hash_max_size 2048;
    limit_req_zone $binary_remote_addr zone=xwplogin:16m rate=40r/m;
    #limit_conn_zone $binary_remote_addr zone=xwpconlimit:16m;
    more_set_headers "Server: nginx centminmod";
    more_set_headers "X-Powered-By: centminmod";
    include /usr/local/nginx/conf/maintenance.conf;
    include /usr/local/nginx/conf/vts_http.conf;
    include /usr/local/nginx/conf/fastcgi_param_https_map.conf;
    Then restart nginx server via command shortcut
    ngxrestart
    or
    service nginx restart
  8. jeparamedia
    jeparamedia Member
    32
    7:11 PM
    1.15.12
    MariaDB 10.3.15
    I always getting ERR_TOO_MANY_REDIRECTS if I activated self sign SSL.
    because my setup is failed , I deleted server and now I must wait for couple weeks to re-install Wordpress cos If I do now with selft sign ssl=NO, the SSL will broken cos Acme already release SSL for me.
    I still not sure what is the best option for Cloudflare (orange or grey) before I install WP in option 22.
    55,229
    12,253
    10:11 PM
    Cloudflare Full SSL in that case.
