Nginx https and gzip
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by tjk, Jun 20, 2016.
  1. tjk
    tjk Member
    76
    16
    1:34 PM
    I haven't had a chance to dig into this in detail yet, but in testing, gzip doesn't appear to be working with https vhost, with valid or self signed cert.
    With http vhost, it is on. gzip is enabled in the nginx.conf file, so not sure why https is getting disabled.
    This is with latest beta and testing against Check GZIP compression using default settings.
    Any idea @eva2000, I won't be able to dig into this until tomorrow afternoon again.
    55,239
    12,253
    3:34 AM
    is test file less than 1400 bytes ?
    nginx.conf has a gzip_min_length set at 1400 bytes so anything under is not gzipped
    grep gzip_min /usr/local/nginx/conf/nginx.conf
            gzip_min_length   1400;
    try another gzip test that i use WhatsMyIP.org | HTTP Compression Test
  3. tjk
    tjk Member
    76
    16
    1:34 PM
    That test site gives me an even stranger error: Error - Unable To Load URL.
    But this one Gzip Test | HTTP Compression Test says gzip is enabled.
    55,239
    12,253
    3:34 AM
    did you enable nginx brotli compression that runs over HTTPS ? could be testing tool can't read content-encoding = br
    NGINX_LIBBROTLI='y'
    you can check for brotli = br at Brotli Test | Brotli compression check
    curl check over https = content-encoding = br for clients that support Accept-Encoding: br otherwise fall back to Accept-Encoding: gzip
    curl -sI /dev/null -H"Accept-Encoding: gzip,br" https://centminmod.com | egrep 'Content-Encoding|^Content-Type|Content-Length'
    Content-Encoding: br
    curl over gzip only returns gzip compressed files
    curl -sI /dev/null -H"Accept-Encoding: gzip" https://centminmod.com | egrep 'Content-Encoding|^Content-Type|Content-Length'
    Content-Encoding: gzip
    If brotli compression enabled in nginx via NGINX_LIBBROTLI='y' then problem is with testing tools themselves whether they can understand content-encoding = br :)
  5. tjk
    tjk Member
    76
    16
    1:34 PM
    OK, so it gets even more odd...
    I'm running defaults on centmin mod install, in my centmin.sh NGINX_LIBBROTLI='n', but the Brotli test site says Brtotli is supported.
    nginx -V shows: --with-http_gzip_static_module --add-dynamic-module=../ngx_brotli
    So, it was compiled in with nginx, even though it is set to no in the config file?
    Also, I assume it is ok to run gzip and brotli together?
    Curl output:
    Content-Type: text/html;charset=UTF-8
    Content-Length: 8967
    [/codeb]
    55,239
    12,253
    3:34 AM
    Yes it is as Web browser support it properly
    As to brotli did you set it in custom_config.inc? Or use 123.09beta01 installer-latest.sh? Both will enable brotli
    The installer-latest.sh does it via the persistent custom_config.inc file
  7. tjk
    tjk Member
    76
    16
    1:34 PM
    I didn't change any of the defaults, it is enabled in the custom_config.inc, and disabled in the centmin.sh file under the #General Configuration, and enabled under the #Nginx Dynamic Modules section.
    I have not modified any of these files, but now looking through them, I assume custom_config.inc is the one file we should be changing for modules and such, and will not get overwritten on upgrades, and the others will?
    55,239
    12,253
    3:34 AM
    Yup
    Only installer-latest.sh initial install will enable brotli via custom_config.inc out of the box
  9. tjk
    tjk Member
    76
    16
    1:34 PM
    Thanks Eva, as always, appreciate the time you take helping folks out too!
    55,239
    12,253
    3:34 AM
    you're welcome
    fyi, you can check what the installer-latest.sh pre-populates in persistent config file /etc/centminmod/custom_config.inc on github on lines 415-432 - installer-latest.sh corresponds to betainstaller-latest.sh on centminmod.com via install command
    curl -O https://centminmod.com/betainstaller-latest.sh && chmod 0700 betainstaller-latest.sh && bash betainstaller-latest.sh
