Featured Nginx How to use Brotli compression for Centmin Mod Nginx web servers
Discussion in 'Centmin Mod User Tutorials & Guides' started by eva2000, Mar 6, 2017.
    12,579
    10:34 PM
    Update: February 5, 2019. Centmin Mod 123.09beta01 and newer branches now auto enable nginx brotli module if Intel Skylake or newer cpus exist. Newer cpus allow brotli compressed nginx files to be served faster Beta Branch - enable nginx brotli module on Intel Skylake & newer cpus in 123.09beta01 :)
    brotli --version
    brotli 1.0.7
  2. rdan
    8:34 PM
    Merged back to [google/ngx_brotli](eustas/ngx_brotli).
    12,579
    10:34 PM
    thanks for heads up just updated 123.09beta01 to use original ngx_brotli github repo again
    12,579
    10:34 PM
  5. upgrade81
    upgrade81 Member
    296
    CH
    2:34 PM
    1.17
    10.3
    have they finally solved the problem that plagued 90% of my VMs?
    many times Nginx went 100% already discussed on the forum...
    12,579
    10:34 PM
    test and see :)
  7. rdan
    8:34 PM
    For my small server and small site, I just want to generate .gz files as I don't have brotli enabled, is it possible with this script? Thanks.
    12,579
    10:34 PM
    not possible as the script tries to install brotli command line binary if it doesn't exist
  9. rdan
    8:34 PM
    Can this also support woff2/woff font files?
    12,579
    10:34 PM
    WOFF/WOFF2 font files are already compressed. You don't want to do double compression on them :)
    Reduce WebFont Size
  11. rdan
    8:34 PM
    Based on my testing, it's worst to have Brotli on PHP request.
    Having gzip only has lower Response Times and Higher Response Counts.
    Disabling Brotli on my live servers from now on.
    12,579
    10:34 PM
    Yeah this this forum and blog haven't had Brotli enabled for past 18 months :)
  13. upgrade81
    upgrade81 Member
    296
    CH
    2:34 PM
    1.17
    10.3
    Hi you mean nginx brotli? Interesting
    12,579
    10:34 PM
    Both Nginx Brotli or Cloudflare Brotli :)
