Featured Nginx How to use Brotli compression for Centmin Mod Nginx web servers
Discussion in 'Centmin Mod User Tutorials & Guides' started by eva2000, Mar 6, 2017.
    12,579
    10:34 PM
  2. buik
    2,044
    527
    Flanders
    2:34 PM
    Great .... new browser support but the main problem is more and more the fact that Nginx broti is not maintained anymore. Also no communication what so ever from the creator.
    https://github.com/google/ngx_brotli/issues
    12,579
    10:34 PM
  4. buik
    2,044
    527
    Flanders
    2:34 PM
    Nothing against PiotrSikora.
    Very simple.
    If you don't have time don't start a project.
    But that's the most difficult kind of thing for a typical programmer.
    Planning and communicating.
  5. upgrade81
    upgrade81 Member
    296
    CH
    2:34 PM
    1.17
    10.3
    Which is the best method you use to restart nginx immediately after the overnight update of compressed files?
    I'm using this what do you say?
    10 5 * * * /root/tools/brotli/brotli.sh /home/nginx/domains/domainxxx.it/public/wp-content/themes/ "ngxrestart" > /dev/null 2>&1
  6. BamaStangGuy
    BamaStangGuy Active Member
    669
    192
    7:34 AM
    Cloudflare now offers this:
    12,579
    10:34 PM
    that won't work on command line .. put then in a bash shell script and reference script in cronjob
    but probably not needed as once you enable Centmin Mod ngx_brotli, you can on the fly compress static text files using brotli compression. I do it on thsi forum and on centminmod.com site :)
  8. upgrade81
    upgrade81 Member
    296
    CH
    2:34 PM
    1.17
    10.3
    I understand, you mean the restart command that does not work, right?
    but I use both on the fly and static files that are still more compressed.
    It works that if it finds the static file skips the process on the fly, correct?
    in this way I take a lot less cpu
    12,579
    10:34 PM
    you need to separate multiple commands on a single line with semi-column ;
    cmd1
    cmd2
    would be
    cmd1; cmd2
    Compression is only done once with static compressed files taken priority over on the fly. And yes static pre-compressed files uses less cpu resources.
  10. rdan
    8:34 PM
    Why does it needs nginx restart?
    12,579
    10:34 PM
    To clear any nginx caches.
  12. knguyen2015
    knguyen2015 New Member
    11
    8:34 AM
    1.12.1
    15.1
    Do I need to disable gzip after enabling Brotli?
    12,579
    10:34 PM
    no don't disable gzip, not all browsers support brotli so for those browsers nginx will fall back to gzip instead
  14. Dnyan
    Dnyan Member
    106
    24
    6:04 PM
    1.17.8
    10.3.22
    i get error
    how i can correct it.
    i also added
    $config['enableGzip'] = false;
    in my src/config.php on xenforo2
    12,579
    10:34 PM
    did you literally use the same command ? You have to test against a domain url file on your server that is valid replacing the domain.com boostrap.min.css url I used below
    curl -sI /dev/null -H"Accept-Encoding: gzip,br" [URL]https://domain.com/brotlitest2/bootstrap.min.css[/URL]
  16. Dnyan
    Dnyan Member
    106
    24
    6:04 PM
    1.17.8
    10.3.22
    i Replaced only domain.com with my domain name and keep rest as it is
  17. Dnyan
    Dnyan Member
    106
    24
    6:04 PM
    1.17.8
    10.3.22
    I did online testing and found that brotil is working.
    Is this OK or i need to configure something more.
    12,579
    10:34 PM
    need to change url to valid file otherwise you get 404 not found.. but yes online brotli test shows working
  19. Dnyan
    Dnyan Member
    106
    24
    6:04 PM
    1.17.8
    10.3.22
    I am confuse on what i should change.
    can you please put more lights on it.
  20. Nitin
    Nitin New Member
    24
    6:04 PM
    Hi, i have enable brotli but my site still keycdn show no brotli. Do i need google pagespeed too. I am new here and dont know much about configuration. I am using vultr 1gb ram vps for running 3 low traffic wordpress blog.
    Checked in chrome also. site address wpseo.ml
    I have done cloudflare authenticated origin pulls correctly. (Doesn't this interfere in renew of letsencrypt certificate). Anything else you want to suggest.
    nginx version: nginx/1.13.12
    built by gcc 7.2.1 20170829 (Red Hat 7.2.1-1) (GCC)
    built with OpenSSL 1.1.0h  27 Mar 2018
    TLS SNI support enabled
    configure arguments: --with-ld-opt='-L/usr/local/lib -ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib' --with-cc-opt='-I/usr/local/include -m64 -march=native -DTCP_FASTOPEN=23 -g -O3 -fstack-protector-strong -flto -fuse-ld=gold --param=ssp-buffer-size=4 -Wformat -Werror=format-security -Wimplicit-fallthrough=0 -fcode-hoisting -Wp,-D_FORTIFY_SOURCE=2 -Wno-deprecated-declarations -gsplit-dwarf' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-compat --with-http_stub_status_module --with-http_secure_link_module --with-libatomic --with-http_gzip_static_module --add-dynamic-module=../ngx_brotli --with-http_sub_module --with-http_addition_module --with-http_image_filter_module=dynamic --with-http_geoip_module --with-stream_geoip_module --with-stream_realip_module --with-stream_ssl_preread_module --with-threads --with-stream=dynamic --with-stream_ssl_module --with-http_realip_module --add-dynamic-module=../ngx-fancyindex-0.4.2 --add-module=../ngx_cache_purge-2.4.2 --add-module=../ngx_devel_kit-0.3.0 --add-dynamic-module=../set-misc-nginx-module-0.32 --add-dynamic-module=../echo-nginx-module-0.61 --add-module=../redis2-nginx-module-0.15 --add-module=../ngx_http_redis-0.3.7 --add-module=../memc-nginx-module-0.18 --add-module=../srcache-nginx-module-0.31 --add-dynamic-module=../headers-more-nginx-module-0.33 --with-pcre=../pcre-8.42 --with-pcre-jit --with-zlib=../zlib-cloudflare-1.3.0 --with-http_ssl_module --with-http_v2_module --with-openssl=../openssl-1.1.0h --with-openssl-opt='enable-ec_nistp_64_gcc_128'
