Xenforo How To Install Elasticsearch 6.x for Xenforo
Discussion in 'Centmin Mod User Tutorials & Guides' started by Sunka, Nov 30, 2017.
    4,127
    11:06 PM
    Is an elastic search restart needed after that setting?
    Also it will survive after upgrading or restarting the server?
  2. pamamolf
    4,127
    11:06 PM
    Did you adjust the default entries at the config file?
  3. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    10:06 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    Still 5 shards
    curl 'localhost:9200/_stats?human&pretty'
      "_shards" : {
        "total" : 5,
        "successful" : 5,
        "failed" : 0
    So how to fix that?
  4. pamamolf
    4,127
    11:06 PM
    Then maybe your index name is not content?
  5. Andy
    Andy Active Member
    546
    90
    3:06 PM
    6.3.1 is available via yum update.
  6. Jimmy
    4:06 PM
    Does anyone have an update for this. I'm getting an error on install. This worked the last time I tried to install elastic search. Now it's saying that the RPM isn't signed. I hesitate forcing the install.
     Package                            Arch                        Version                        Repository                              Size
    Installing:
     elasticsearch                      noarch                      6.3.2-1                        elasticsearch-6.x                       87 M
    Transaction Summary
    Install  1 Package
    Total size: 87 M
    Installed size: 136 M
    Downloading packages:
    Package elasticsearch-6.3.2.rpm is not signed
  7. Sunka
    1,150
    325
    Pula, Croatia
    10:06 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    Install guide not need an update.
    It was ES crew mistake!
  8. Sunka
    1,150
    325
    Pula, Croatia
    10:06 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    # yum update
    Determining fastest mirrors
    epel/x86_64/metalink        |  25 kB  00:00:00
     * base: mirror.centos.org
     * epel: mirror.23media.de
     * extras: mirror.centos.org
     * rpmforge: mirror.de.leaseweb.net
     * updates: mirror.centos.org
    base        | 3.6 kB  00:00:00
    centos-sclo-rh        | 3.0 kB  00:00:00
    centos-sclo-sclo        | 2.9 kB  00:00:00
    elasticsearch-6.x        | 1.3 kB  00:00:00
    epel        | 3.2 kB  00:00:00
    extras        | 3.4 kB  00:00:00
    mariadb        | 2.9 kB  00:00:00
    rpmforge        | 1.9 kB  00:00:00
    updates        | 3.4 kB  00:00:00
    (1/11): base/7/x86_64/group_gz                                                          | 166 kB  00:00:00
    (2/11): epel/x86_64/group_gz                                                            |  88 kB  00:00:00
    (3/11): epel/x86_64/updateinfo                                                          | 928 kB  00:00:00
    (4/11): base/7/x86_64/primary_db                                                        | 5.9 MB  00:00:00
    (5/11): extras/7/x86_64/primary_db                                                      | 172 kB  00:00:00
    (6/11): centos-sclo-sclo/x86_64/primary_db                                              | 289 kB  00:00:00
    (7/11): updates/7/x86_64/primary_db                                                     | 4.2 MB  00:00:00
    (8/11): epel/x86_64/primary                                                             | 3.5 MB  00:00:00
    (9/11): mariadb/primary_db                                                              |  61 kB  00:00:00
    (10/11): centos-sclo-rh/x86_64/primary_db                                               | 3.5 MB  00:00:00
    (11/11): elasticsearch-6.x/primary                                                      |  92 kB  00:00:00
    rpmforge/primary_db        | 125 kB  00:00:00
    elasticsearch-6.x        226/226
    epel        12619/12619
    279 packages excluded due to repository priority protections
    Resolving Dependencies
    --> Running transaction check
    ---> Package clamav-data.noarch 0:0.100.0-2.el7 will be updated
    ---> Package clamav-data.noarch 0:0.100.1-1.el7 will be an update
    ---> Package clamav-filesystem.noarch 0:0.100.0-2.el7 will be updated
    ---> Package clamav-filesystem.noarch 0:0.100.1-1.el7 will be an update
    ---> Package elasticsearch.noarch 0:6.3.1-1 will be updated
    ---> Package elasticsearch.noarch 0:6.3.2-1 will be an update
    Dependencies Resolved
    Updating:
     clamav-data                  noarch            0.100.1-1.el7               epel                         159 M
     clamav-filesystem            noarch            0.100.1-1.el7               epel                          26 k
    Transaction Summary
    Upgrade  3 Packages
    Total download size: 246 M
    Is this ok [y/d/N]: y
    No Presto metadata available for elasticsearch-6.x
    epel/x86_64/prestodelta        | 1.0 kB  00:00:00
    (1/3): clamav-data-0.100.1-1.el7.noarch.rpm                                             | 159 MB  00:00:03
    (2/3): clamav-filesystem-0.100.1-1.el7.noarch.rpm                                       |  26 kB  00:00:00
    (3/3): elasticsearch-6.3.2.rpm                                                          |  87 MB  00:00:04
    Total        30 MB/s | 246 MB  00:00:08
    Running transaction test
    Transaction test succeeded
    Running transaction
      Updating   : clamav-filesystem-0.100.1-1.el7.noarch                                                      1/6
      Updating   : clamav-data-0.100.1-1.el7.noarch                                                            2/6
      Updating   : elasticsearch-6.3.2-1.noarch        3/6
    warning: /etc/elasticsearch/jvm.options created as /etc/elasticsearch/jvm.options.rpmnew
      Cleanup    : clamav-data-0.100.0-2.el7.noarch                                                            4/6
      Cleanup    : clamav-filesystem-0.100.0-2.el7.noarch                                                      5/6
      Cleanup    : elasticsearch-6.3.1-1.noarch        6/6
    Created elasticsearch keystore in /etc/elasticsearch
      Verifying  : elasticsearch-6.3.2-1.noarch        1/6
      Verifying  : clamav-data-0.100.1-1.el7.noarch                                                            2/6
      Verifying  : clamav-filesystem-0.100.1-1.el7.noarch                                                      3/6
      Verifying  : clamav-data-0.100.0-2.el7.noarch                                                            4/6
      Verifying  : elasticsearch-6.3.1-1.noarch        5/6
      Verifying  : clamav-filesystem-0.100.0-2.el7.noarch                                                      6/6
    Updated:
      clamav-data.noarch 0:0.100.1-1.el7  clamav-filesystem.noarch 0:0.100.1-1.el7  elasticsearch.noarch 0:6.3.2-1
    Complete!
  9. Andy
    Andy Active Member
    546
    90
    3:06 PM
    6.4.1 is now available.
  10. Sunka
    1,150
    325
    Pula, Croatia
    10:06 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    Installed last night and everything seems fine
  11. xenbiarritz
    xenbiarritz Member
    44
    10:06 PM
    @Sunka
    What is the correct step for xf2
    Thank you
  12. xenbiarritz
    xenbiarritz Member
    44
    10:06 PM
    same problem on xf2 did you find a solution?
  13. xenbiarritz
    xenbiarritz Member
    44
    10:06 PM
    now i have this error
    Rejecting mapping update to [elastic] as the final mapping would have more than 1 type: [elastic, xf] in
    i can't rebuid or remove search index from xf2
    my cluster name "elastic"
    can some one help me
    how can i delete my index or cluster? try many thing can't find solution
    don't know what to do?
  14. Sunka
    1,150
    325
    Pula, Croatia
    10:06 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    You may do that step or not. It is not to must for xf2
  15. Sunka
    1,150
    325
    Pula, Croatia
    10:06 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    Nop.
    Still have default 5 shards
  16. Sunka
    1,150
    325
    Pula, Croatia
    10:06 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    Try rebuild search through cli.
    enter to your forum folder and run
    php cmd.php xf-rebuild:search
  17. xenbiarritz
    xenbiarritz Member
    44
    10:06 PM
    it return
      [XF\PrintableException]
      An error was triggered while indexing. See the XenForo error log for details.
    xf-rebuild:search [--log-queries LOG-QUERIES] [-b|--batch BATCH] [--type TYPE] [--truncate]
  18. xenbiarritz
    xenbiarritz Member
    44
    10:06 PM
    hi @Xon thank you for your help
    it return
      "error" : {
        "root_cause" : [
            "type" : "index_not_found_exception",
            "reason" : "no such index",
            "resource.type" : "index_expression",
            "resource.id" : "_all"
      "status" : 404
    in this steps
    nano /etc/elasticsearch/elasticsearch.yml
    at the end of file add this:
    cluster.name: CUSTOM NAME OF YOUR CLUSTER (same name should be inserted into your XenForo field in Admin Control Panel in field Elasticsearch Index Name)
    network.host: localhost
    http.port: 9200
    i choose "elastic" for my custom name
    First i configure xfes and enter "elastic" in index name
    i enable xfes and first it workes then i wanted to change the Word stemming setting in xfes and my problem start
    here are the error
    if i run optimise on xfes setting it return
    XFES\Elasticsearch\RequestException: Rejecting mapping update to [elastic] as the final mapping would have more than 1 type: [elastic, xf] in src/addons/XFES/Elasticsearch/Api.php at line 387
    XFES\Elasticsearch\Api->request() in src/addons/XFES/Elasticsearch/Api.php at line 287
    XFES\Elasticsearch\Api->createIndex() in src/addons/XFES/Service/Optimizer.php at line 85
    XFES\Service\Optimizer->optimize() in src/addons/XFES/Admin/Controller/EnhancedSearch.php at line 151
    XFES\Admin\Controller\EnhancedSearch->actionOptimize() in src/XF/Mvc/Dispatcher.php at line 249
    XF\Mvc\Dispatcher->dispatchClass() in src/XF/Mvc/Dispatcher.php at line 88
    XF\Mvc\Dispatcher->dispatchLoop() in src/XF/Mvc/Dispatcher.php at line 41
    XF\Mvc\Dispatcher->run() in src/XF/App.php at line 1934
    XF\App->run() in src/XF.php at line 333
    XF::runApp() in admin.php at line 13
    if i want to rebuid search index and checked remove the index
    XFES\Service\Optimizer->optimize() in src/addons/XFES/Search/Source/Elasticsearch.php at line 139
    XFES\Search\Source\Elasticsearch->truncate() in src/XF/Search/Search.php at line 127
    XF\Search\Search->truncate() in src/XF/Job/SearchRebuild.php at line 25
    XF\Job\SearchRebuild->run() in src/XF/Job/Manager.php at line 241
    XF\Job\Manager->runJobInternal() in src/XF/Job/Manager.php at line 187
    XF\Job\Manager->runJobEntry() in src/XF/Job/Manager.php at line 103
    XF\Job\Manager->runByIds() in src/XF/Admin/Controller/Tools.php at line 120
    XF\Admin\Controller\Tools->actionRunJob() in src/XF/Mvc/Dispatcher.php at line 249
    when i run
    curl -XGET 'localhost:9200'
    it return
      "name" : "tywki3X",
      "cluster_name" : "elastic",
      "cluster_uuid" : "BpM-rmyfT6OzwObqGJC1gA",
      "version" : {
        "number" : "6.5.4",
        "build_flavor" : "default",
        "build_type" : "rpm",
        "build_hash" : "d2ef93d",
        "build_date" : "2018-12-17T21:17:40.758843Z",
        "build_snapshot" : false,
        "lucene_version" : "7.5.0",
        "minimum_wire_compatibility_version" : "5.6.0",
        "minimum_index_compatibility_version" : "5.0.0"
      "tagline" : "You Know, for Search"
  19. xenbiarritz
    xenbiarritz Member
    44
    10:06 PM
    and when i reconfigue in xfes i have this line
    Index name
    elastic
    This index does not exist yet.
    when i run
     curl -X GET "localhost:9200/_cat/indices?v"
    it return
    health status index uuid pri rep docs.count docs.deleted store.size pri.store.size
  20. xenbiarritz
    xenbiarritz Member
    44
    10:06 PM
    hi @Sunka
    how to update to elasticsearch 7?
