    1:08 AM
  2. Andy
    Andy Active Member
    546
    90
    10:08 AM
    I'm using this version on my 2 servers and I found that many changes are being added over time. What is the best way to get the latest centmin.sh so that we always got latest version of all the software installed by centmin.
    1:08 AM
  4. Andy
    Andy Active Member
    546
    90
    10:08 AM
    1:08 AM
    For nginx versions are the same unless specifically a .08 beta commit changes something with nginx compile options would you need to recompile/update Nginx.
    YUM update is outside of Centmin Mod script, so you can update whenever. But if you mean getting that new MariaDB 10 CentOS 7 repo instead of MariaDB 10 CentOS 6 repo, you won't be able to with any yum updates or using latest .08 beta download as there is no code specifically made for switching that MariaDB 10 YUM repo from CentOS 6 to CentOS 7 one right now. Pretty much the same for MariaDB 10, just CentOS 6 repo uses init.d and CentOS 7 repo uses systemd
  6. Andy
    Andy Active Member
    546
    90
    10:08 AM
    Sorry for the confusion, George. What I mean is a few days ago, I download the latest script. Then a day later, you update the script to use a newer version of a specific library.
    If I want to update that library, do I run yum update? If I update nginx later on, do they use the version specified in your install script?
    1:08 AM
    totally depends on what was updated as not all changes can be grabbed or utilised by just downloading the latest .08 beta code and running menu based updates.
    which updated library you talking about Commits · centminmod/centminmod · GitHub ? you mean update EPEL 7 release rpm download url update EPEL 7 release download version · 4ea5c3d · centminmod/centminmod · GitHub ? Yes that change and any changes for inc/downloadlinks.inc can usually be obtained by grabbing latest .08 beta zip download but there's no need to run any YUM commands as that download is only installed once at initial install time to install EPEL YUM repo. So it's only a problem you'd encounter on fresh .08 beta installs.
    1:08 AM
    1:08 AM
    1:08 AM
    FYI, was just doing some yum updates for a CentOS 7.0 512MB VPS and ran out of memory with 0 swap assigned. So added a 2GB Swap file to the VPS and tried yum updates again and saw swap used was up to 480MB. So it does seem true that for CentOS 7.0 you need a minimum of 1GB of memory to get by given that the yum update easily consumed 512MB + 480MB = 992MB of memory.
    So be aware if you want to use CentOS 7.0 either a minimum of 1GB of memory is required or at least 512MB of memory + ample swap disk allocation is required !
    these were the YUM updated packages involved.
     tail -80 /var/log/yum.log | grep 'Oct 02'
    Oct 02 04:34:52 Updated: nss-util-3.16.2-2.el7_0.x86_64
    Oct 02 04:34:52 Updated: systemd-libs-208-11.el7_0.2.x86_64
    Oct 02 04:34:52 Updated: mesa-libglapi-9.2.5-6.20131218.el7_0.x86_64
    Oct 02 04:34:52 Updated: centos-release-7-0.1406.el7.centos.2.5.x86_64
    Oct 02 04:34:54 Updated: systemd-208-11.el7_0.2.x86_64
    Oct 02 04:34:54 Updated: libgudev1-208-11.el7_0.2.x86_64
    Oct 02 04:34:55 Updated: initscripts-9.49.17-1.el7_0.1.x86_64
    Oct 02 04:34:55 Updated: 12:dhcp-libs-4.2.5-27.el7.centos.1.x86_64
    Oct 02 04:34:55 Updated: policycoreutils-2.2.5-11.el7_0.1.x86_64
    Oct 02 04:34:55 Updated: nss-softokn-freebl-3.16.2-2.el7_0.x86_64
    Oct 02 04:34:56 Updated: nss-softokn-3.16.2-2.el7_0.x86_64
    Oct 02 04:34:56 Updated: nss-3.16.2-7.el7_0.x86_64
    Oct 02 04:34:56 Updated: nss-sysinit-3.16.2-7.el7_0.x86_64
    Oct 02 04:34:56 Updated: 1:NetworkManager-glib-0.9.9.1-26.git20140326.4dba720.el7_0.x86_64
    Oct 02 04:47:42 Updated: MariaDB-common-10.0.14-1.el6.x86_64
    Oct 02 04:47:42 Updated: MariaDB-compat-10.0.14-1.el6.x86_64
    Oct 02 04:47:45 Updated: MariaDB-client-10.0.14-1.el6.x86_64
    Oct 02 04:47:45 Updated: 12:dhcp-common-4.2.5-27.el7.centos.1.x86_64
    Oct 02 04:47:45 Updated: 12:dhclient-4.2.5-27.el7.centos.1.x86_64
    Oct 02 04:47:45 Updated: kernel-tools-libs-3.10.0-123.8.1.el7.x86_64
    Oct 02 04:47:45 Updated: systemd-sysv-208-11.el7_0.2.x86_64
    Oct 02 04:47:45 Updated: 1:NetworkManager-0.9.9.1-26.git20140326.4dba720.el7_0.x86_64
    Oct 02 04:47:46 Updated: mesa-libgbm-9.2.5-6.20131218.el7_0.x86_64
    Oct 02 04:47:49 Updated: linux-firmware-20140804-0.1.git6bce2b0.el7_0.noarch
    Oct 02 04:47:56 Installed: kernel-3.10.0-123.8.1.el7.x86_64
    Oct 02 04:47:56 Updated: mesa-libEGL-9.2.5-6.20131218.el7_0.x86_64
    Oct 02 04:47:56 Updated: 1:NetworkManager-tui-0.9.9.1-26.git20140326.4dba720.el7_0.x86_64
    Oct 02 04:47:56 Updated: kernel-tools-3.10.0-123.8.1.el7.x86_64
    Oct 02 04:48:07 Updated: MariaDB-server-10.0.14-1.el6.x86_64
    Oct 02 04:48:09 Updated: MariaDB-devel-10.0.14-1.el6.x86_64
    Oct 02 04:48:09 Updated: MariaDB-shared-10.0.14-1.el6.x86_64
    Oct 02 04:48:10 Updated: kernel-headers-3.10.0-123.8.1.el7.x86_64
    Oct 02 04:48:10 Updated: iwl6000g2b-firmware-17.168.5.2-35.el7_0.noarch
    Oct 02 04:48:10 Updated: 1:iwl1000-firmware-39.31.5.1-35.el7_0.noarch
    Oct 02 04:48:10 Updated: iwl100-firmware-39.31.5.1-35.el7_0.noarch
    Oct 02 04:48:10 Updated: iwl5150-firmware-8.24.2.2-35.el7_0.noarch
    Oct 02 04:48:10 Updated: iwl2000-firmware-18.168.6.1-35.el7_0.noarch
    Oct 02 04:48:10 Updated: iwl3945-firmware-15.32.2.9-35.el7_0.noarch
    Oct 02 04:48:10 Updated: epel-release-7-2.noarch
    Oct 02 04:48:10 Updated: iwl135-firmware-18.168.6.1-35.el7_0.noarch
    Oct 02 04:48:10 Updated: libertas-sd8686-firmware-20140804-0.1.git6bce2b0.el7_0.noarch
    Oct 02 04:48:10 Updated: iwl7260-firmware-22.0.7.0-35.el7_0.noarch
    Oct 02 04:48:10 Updated: iwl4965-firmware-228.61.2.24-35.el7_0.noarch
    Oct 02 04:48:28 Installed: kernel-devel-3.10.0-123.8.1.el7.x86_64
    Oct 02 04:48:28 Updated: mesa-libGL-9.2.5-6.20131218.el7_0.x86_64
    Oct 02 04:48:29 Updated: iwl6050-firmware-41.28.5.1-35.el7_0.noarch
    Oct 02 04:48:29 Updated: iwl2030-firmware-18.168.6.1-35.el7_0.noarch
    Oct 02 04:48:29 Updated: nss-tools-3.16.2-7.el7_0.x86_64
    Oct 02 04:48:29 Updated: iwl6000g2a-firmware-17.168.5.3-35.el7_0.noarch
    Oct 02 04:48:29 Updated: libertas-sd8787-firmware-20140804-0.1.git6bce2b0.el7_0.noarch
    Oct 02 04:48:29 Updated: 2:libertas-usb8388-firmware-20140804-0.1.git6bce2b0.el7_0.noarch
    Oct 02 04:48:30 Updated: tzdata-2014g-1.el7.noarch
    Oct 02 04:49:37 Updated: selinux-policy-targeted-3.12.1-153.el7_0.11.noarch
    Oct 02 04:49:38 Updated: iwl105-firmware-18.168.6.1-35.el7_0.noarch
    Oct 02 04:49:39 Updated: ca-certificates-2014.1.98-70.0.el7_0.noarch
    Oct 02 04:49:39 Updated: iwl5000-firmware-8.83.5.1_1-35.el7_0.noarch
    Oct 02 04:49:39 Updated: iwl6000-firmware-9.221.4.1-35.el7_0.noarch
    Oct 02 04:49:40 Updated: iwl3160-firmware-22.0.7.0-35.el7_0.noarch
    Oct 02 04:49:40 Updated: kexec-tools-2.0.4-32.el7.centos.4.x86_64
    1:08 AM
    Updated inc/phpsededit.inc moving the initial PHP php.ini tweaks from /usr/local/lib/php.ini to /etc/centminmod/php.d/custom_php.ini so they are preserved on PHP upgrades. Commit Commits · centminmod/centminmod · GitHub
  12. Matt
    Matt Well-Known Member
    937
    415
    Rotherham, UK
    4:08 PM
    1.5.15
    MariaDB 10.2
    Giving it a try now
    1:08 AM
    about time @Matt :)
    Discovered a bug in initial MariaDB install routine which affects both .07 stable and .08 betas when InnoDB is enabled the InnoDB engine may fail to load as there is a mismatched innodb_log_file_size from what was initially created size of 5MB at install and the custom /etc/my.cnf size of 48MB or 64MB - you can see this in MariaDB error log when you enable InnoDB for the first time. I had a workaround for this, but mistakenly placed the work around too early in the install routine before the custom /etc/my.cnf was set. The workaround should be placed after the custom /etc/my.cnf is set.
    So committed fixes for both branches
    If it's your first time enabling innodb in /etc/my.cnf and you're on Centmin Mod prior to the committed fixes, you'd want to first check your MariaDB error log /var/log/mysqld.log to make sure you are experiencing the same exact error messages outlined here (for failed innodb engine and innodb_log_file_size) and follow the commands to rectify them outlined here or below.
    check your error logs for mysql
    tail -50 /var/log/mysqld.log
    141007 19:37:42 [Note] /usr/sbin/mysqld: Normal shutdown
    141007 19:37:42 [Note] Event Scheduler: Purging the queue. 0 events
    141007 19:37:42 [Note] /usr/sbin/mysqld: Shutdown complete
    141007 19:37:42 mysqld_safe mysqld from pid file /var/lib/mysql/vla01.centminmod.com.pid ended
    141007 19:37:46 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
    141007 19:37:46 InnoDB: The InnoDB memory heap is disabled
    141007 19:37:46 InnoDB: Mutexes and rw_locks use GCC atomic builtins
    141007 19:37:46 InnoDB: Compressed tables use zlib 1.2.3
    141007 19:37:46 InnoDB: Using Linux native AIO
    141007 19:37:46 InnoDB: Initializing buffer pool, size = 16.0M
    141007 19:37:46 InnoDB: Completed initialization of buffer pool
    InnoDB: Error: log file ./ib_logfile0 is of different size 0 5242880 bytes
    InnoDB: than specified in the .cnf file 0 67108864 bytes!
    InnoDB: Possible causes for this error:
    (a) Incorrect log file is used or log file size is changed
    (b) In case default size is used this log file is from 10.0
    (c) Log file is corrupted or there was not enough disk space
    In case (b) you need to set innodb_log_file_size = 48M
    141007 19:37:46 [ERROR] Plugin 'InnoDB' init function returned error.
    141007 19:37:46 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
    141007 19:37:46 [Note] Plugin 'FEDERATED' is disabled.
    141007 19:37:46 [Note] Plugin 'ARCHIVE' is disabled.
    141007 19:37:46 [Note] Plugin 'FEEDBACK' is disabled.
    141007 19:37:46 [Note] Server socket created on IP: '0.0.0.0'.
    141007 19:37:46 [Note] Event Scheduler: Loaded 0 events
    141007 19:37:46 [Note] /usr/sbin/mysqld: ready for connections.
    Version: '5.5.39-MariaDB'  socket: '/var/lib/mysql/mysql.sock'  port: 3306  MariaDB Server
    InnoDB engine failed to load as it seems somewhere in MariaDB install routine it creates a 5MB sized innodb log file prior to the custom tweaked my.cnf I created is read which has a 48MB sized innodb log file so it causes problems until you stop mysql server and remove the 5MB innodblog files ib_logfile* from /var/lib/mysql
    Manual fix after enabling innodb in /etc/my.cnf for the very first time.
    mysqladmin flush-tables
    sleep 30
    service mysql stop
    sleep 30
    rm -rf /var/lib/mysql/ib_logfile*
    service mysql start
  14. Andy
    Andy Active Member
    546
    90
    10:08 AM
    How do I check if innodb is enabled?
    I see this line in the /etc/my.cnf file
    innodb=ON
    Do I have to add
    default-storage-engine=innodb
    default-table-type=innodb
    Also, the command
    killall mysqld
    resulted in
    -bash: killall: command not found
    1:08 AM
    just check if mysql variable have_innodb is YES
    via command
     mysqladmin var | grep have_innodb
    will show YES if innodb engine is enabled
    | have_innodb                                       | YES
    killall not found is okay as mysql stop command already stopped mysqld
  16. Andy
    Andy Active Member
    546
    90
    10:08 AM
    That command to check innodb return nothing
    [root@ryan centminmod-123.08centos7beta01]# mysqladmin var | grep have_innodb
    1:08 AM
    MariaDB 10 doesn't have that variable. So need to verify to see if any innodb variables are listed, if not then innodb engine wasn't loaded, if it returns variables then innodb engine is enabled and loaded
    mysqladmin var | grep innodb | tr -s ' '
    i.e.
    | ignore_builtin_innodb | OFF |
    | innodb_adaptive_flushing | ON |
    | innodb_adaptive_flushing_lwm | 10 |
    | innodb_adaptive_hash_index | ON |
    | innodb_adaptive_hash_index_partitions | 1 |
    | innodb_adaptive_max_sleep_delay | 150000 |
    | innodb_additional_mem_pool_size | 8388608 |
    | innodb_api_bk_commit_interval | 5 |
    | innodb_api_disable_rowlock | OFF |
    | innodb_api_enable_binlog | OFF |
    | innodb_api_enable_mdl | OFF |
    | innodb_api_trx_level | 0 |
    | innodb_autoextend_increment | 64 |
    | innodb_autoinc_lock_mode | 1 |
    | innodb_buffer_pool_dump_at_shutdown | OFF |
    | innodb_buffer_pool_dump_now | OFF |
    | innodb_buffer_pool_filename | ib_buffer_pool |
    | innodb_buffer_pool_instances | 8 |
    | innodb_buffer_pool_load_abort | OFF |
    | innodb_buffer_pool_load_at_startup | OFF |
    | innodb_buffer_pool_load_now | OFF |
    | innodb_buffer_pool_populate | OFF |
    | innodb_buffer_pool_size | 50331648 |
    | innodb_change_buffer_max_size | 25 |
    | innodb_change_buffering | all |
    | innodb_checksum_algorithm | innodb |
    | innodb_checksums | ON |
    | innodb_cleaner_lsn_age_factor | high_checkpoint |
    | innodb_cmp_per_index_enabled | OFF |
    | innodb_commit_concurrency | 0 |
    | innodb_compression_failure_threshold_pct | 5 |
    | innodb_compression_level | 6 |
    | innodb_compression_pad_pct_max | 50 |
    | innodb_concurrency_tickets | 5000 |
    | innodb_corrupt_table_action | assert |
    | innodb_data_file_path | ibdata1:10M:autoextend |
    | innodb_data_home_dir | |
    | innodb_disable_sort_file_cache | OFF |
    | innodb_doublewrite | ON |
    | innodb_empty_free_list_algorithm | backoff |
    | innodb_fake_changes | OFF |
    | innodb_fast_shutdown | 1 |
    | innodb_file_format | Antelope |
    | innodb_file_format_check | ON |
    | innodb_file_format_max | Antelope |
    | innodb_file_per_table | ON |
    | innodb_flush_log_at_timeout | 1 |
    | innodb_flush_log_at_trx_commit | 2 |
    | innodb_flush_method | O_DIRECT |
    | innodb_flush_neighbors | 1 |
    | innodb_flushing_avg_loops | 30 |
    | innodb_force_load_corrupted | OFF |
    | innodb_force_recovery | 0 |
    | innodb_foreground_preflush | exponential_backoff |
    | innodb_ft_aux_table | |
    | innodb_ft_cache_size | 8000000 |
    | innodb_ft_enable_diag_print | OFF |
    | innodb_ft_enable_stopword | ON |
    | innodb_ft_max_token_size | 84 |
    | innodb_ft_min_token_size | 3 |
    | innodb_ft_num_word_optimize | 2000 |
    | innodb_ft_result_cache_limit | 2000000000 |
    | innodb_ft_server_stopword_table | |
    | innodb_ft_sort_pll_degree | 2 |
    | innodb_ft_total_cache_size | 640000000 |
    | innodb_ft_user_stopword_table | |
    | innodb_io_capacity | 100 |
    | innodb_io_capacity_max | 2000 |
    | innodb_kill_idle_transaction | 0 |
    | innodb_large_prefix | OFF |
    | innodb_lock_wait_timeout | 50 |
    | innodb_locking_fake_changes | ON |
    | innodb_locks_unsafe_for_binlog | OFF |
    | innodb_log_arch_dir | ./ |
    | innodb_log_arch_expire_sec | 0 |
    | innodb_log_archive | OFF |
    | innodb_log_block_size | 512 |
    | innodb_log_buffer_size | 8388608 |
    | innodb_log_checksum_algorithm | innodb |
    | innodb_log_compressed_pages | ON |
    | innodb_log_file_size | 67108864 |
    | innodb_log_files_in_group | 2 |
    | innodb_log_group_home_dir | ./ |
    | innodb_lru_scan_depth | 1024 |
    | innodb_max_bitmap_file_size | 104857600 |
    | innodb_max_changed_pages | 1000000 |
    | innodb_max_dirty_pages_pct | 75 |
    | innodb_max_dirty_pages_pct_lwm | 0 |
    | innodb_max_purge_lag | 0 |
    | innodb_max_purge_lag_delay | 0 |
    | innodb_mirrored_log_groups | 1 |
    | innodb_monitor_disable | |
    | innodb_monitor_enable | |
    | innodb_monitor_reset | |
    | innodb_monitor_reset_all | |
    | innodb_old_blocks_pct | 37 |
    | innodb_old_blocks_time | 1000 |
    | innodb_online_alter_log_max_size | 134217728 |
    | innodb_open_files | 1000 |
    | innodb_optimize_fulltext_only | OFF |
    | innodb_page_size | 16384 |
    | innodb_print_all_deadlocks | OFF |
    | innodb_purge_batch_size | 300 |
    | innodb_purge_threads | 1 |
    | innodb_random_read_ahead | OFF |
    | innodb_read_ahead_threshold | 56 |
    | innodb_read_io_threads | 2 |
    | innodb_read_only | OFF |
    | innodb_replication_delay | 0 |
    | innodb_rollback_on_timeout | OFF |
    | innodb_rollback_segments | 128 |
    | innodb_sched_priority_cleaner | 19 |
    | innodb_show_locks_held | 10 |
    | innodb_show_verbose_locks | 0 |
    | innodb_simulate_comp_failures | 0 |
    | innodb_sort_buffer_size | 2097152 |
    | innodb_spin_wait_delay | 6 |
    | innodb_stats_auto_recalc | ON |
    | innodb_stats_method | nulls_equal |
    | innodb_stats_on_metadata | OFF |
    | innodb_stats_persistent | ON |
    | innodb_stats_persistent_sample_pages | 20 |
    | innodb_stats_sample_pages | 8 |
    | innodb_stats_transient_sample_pages | 8 |
    | innodb_status_output | OFF |
    | innodb_status_output_locks | OFF |
    | innodb_strict_mode | OFF |
    | innodb_support_xa | ON |
    | innodb_sync_array_size | 1 |
    | innodb_sync_spin_loops | 30 |
    | innodb_table_locks | ON |
    | innodb_thread_concurrency | 0 |
    | innodb_thread_sleep_delay | 10000 |
    | innodb_track_changed_pages | OFF |
    | innodb_undo_directory | . |
    | innodb_undo_logs | 128 |
    | innodb_undo_tablespaces | 0 |
    | innodb_use_atomic_writes | OFF |
    | innodb_use_fallocate | OFF |
    | innodb_use_global_flush_log_at_trx_commit | ON |
    | innodb_use_native_aio | ON |
    | innodb_use_stacktrace | OFF |
    | innodb_use_sys_malloc | ON |
    | innodb_version | 5.6.20-68.0 |
    | innodb_write_io_threads | 2 |
    also double check your mysql error log as per MariaDB - mysql problems the mysqltuner & tuning-primer | Centmin Mod Community and see if you experienced the same problem
  18. Andy
    Andy Active Member
    546
    90
    10:08 AM
    140926 19:46:25 [Note] InnoDB: 128 rollback segment(s) are active.
    140926 19:46:25 [Note] InnoDB: Waiting for purge to start
    140926 19:46:25 [Note] InnoDB:  Percona XtraDB (http://www.percona.com) 5.6.20-68.0 started; log sequence number 1601056
    140926 19:46:25 [Note] Plugin 'FEDERATED' is disabled.
    140926 19:46:25 [Note] Plugin 'ARCHIVE' is disabled.
    140926 19:46:25 [Note] Plugin 'FEEDBACK' is disabled.
    140926 19:46:25 [Note] Server socket created on IP: '::'.
    140926 19:46:25 [Note] Event Scheduler: Loaded 0 events
    140926 19:46:25 [Warning] InnoDB: Cannot open table mysql/gtid_slave_pos from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem.
    140926 19:46:25 [Warning] Failed to load slave replication state from table mysql.gtid_slave_pos: 1932: Table 'mysql.gtid_slave_pos' doesn't exist in engine
    140926 19:46:25 [Note] /usr/sbin/mysqld: ready for connections.
    Version: '10.0.14-MariaDB'  socket: '/var/lib/mysql/mysql.sock'  port: 3306  MariaDB Server
    2014-09-28 09:33:42 7f5a0486b700 InnoDB: Error: Table "mysql"."innodb_table_stats" not found.
    141008  1:51:32 [Note] /usr/sbin/mysqld: Normal shutdown
    141008  1:51:32 [Note] Event Scheduler: Purging the queue. 0 events
    141008  1:51:32 [Note] InnoDB: FTS optimize thread exiting.
    141008  1:51:32 [Note] InnoDB: Starting shutdown...
    141008  1:51:33 [Note] InnoDB: Shutdown completed; log sequence number 2006070
    141008  1:51:33 [Note] /usr/sbin/mysqld: Shutdown complete
    141008 01:51:33 mysqld_safe mysqld from pid file /var/lib/mysql/ryan.quantnet.com.pid ended
    141008 01:52:08 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
    141008  1:52:09 [Note] InnoDB: Using mutexes to ref count buffer pool pages
    141008  1:52:09 [Note] InnoDB: The InnoDB memory heap is disabled
    141008  1:52:09 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
    141008  1:52:09 [Note] InnoDB: Memory barrier is not used
    141008  1:52:09 [Note] InnoDB: Compressed tables use zlib 1.2.3
    141008  1:52:09 [Note] InnoDB: Using Linux native AIO
    141008  1:52:09 [Note] InnoDB: Using CPU crc32 instructions
    141008  1:52:09 [Note] InnoDB: Initializing buffer pool, size = 48.0M
    141008  1:52:09 [Note] InnoDB: Completed initialization of buffer pool
    141008  1:52:09 [Note] InnoDB: Setting log file ./ib_logfile101 size to 64 MB
    141008  1:52:09 [Note] InnoDB: Setting log file ./ib_logfile1 size to 64 MB
    141008  1:52:09 [Note] InnoDB: Renaming log file ./ib_logfile101 to ./ib_logfile0
    141008  1:52:09 [Warning] InnoDB: New log files created, LSN=2006070
    141008  1:52:09 [Note] InnoDB: Highest supported file format is Barracuda.
    141008  1:52:09 [Note] InnoDB: 128 rollback segment(s) are active.
    141008  1:52:09 [Note] InnoDB: Waiting for purge to start
    141008  1:52:09 [Note] InnoDB:  Percona XtraDB (http://www.percona.com) 5.6.20-68.0 started; log sequence number 2006540
    141008  1:52:09 [Note] Plugin 'FEDERATED' is disabled.
    141008  1:52:09 [Note] Plugin 'ARCHIVE' is disabled.
    141008  1:52:09 [Note] Plugin 'FEEDBACK' is disabled.
    141008  1:52:09 [Note] Server socket created on IP: '::'.
    141008  1:52:09 [Note] Event Scheduler: Loaded 0 events
    141008  1:52:09 [Warning] InnoDB: Cannot open table mysql/gtid_slave_pos from the internal data dictionary of InnoDB though the .frm file for the table exists. See http://dev.mysql.com/doc/refman/5.6/en/innodb-troubleshooting.html for how you can resolve the problem.
    141008  1:52:09 [Warning] Failed to load slave replication state from table mysql.gtid_slave_pos: 1932: Table 'mysql.gtid_slave_pos' doesn't exist in engine
    141008  1:52:09 [Note] /usr/sbin/mysqld: ready for connections.
    2014-10-08 02:30:15 7f61ed584700 InnoDB: Error: Table "mysql"."innodb_table_stats" not found.
    1:08 AM
    @Andy you fixed the innodb_log_file_size errors as seen in mysqld error log and shows you have InnoDB engine loaded and enabled
    However, you have another set of errors for mysql.gtid_slave.pos and mysql.innodb_table_stats system tables being corrupted or mismatched data from the *ibd files and innodb table space.
    The fix can be complicated and isn't 100% guaranteed. However, I written a quick shell script to do all the leg work, mariadb10fix.sh.
    This problem and fix is only if you're running MariaDB 10. The script will:
    1. make a full backup of all your databases on your server at /home/mysql10fix/all_databases_backup.sql
    2. download the most common 3 missing innodb tables schema (with no-data) create tables structure sql file named mariadb10_3tables.sql - which was created from a working MariaDB 10.0.x database system
    3. stop mysql server and nginx and remove physically the *.ibd data files for the 3 common innodb tables within mysql database for gtid_slave_pos, innodb_table_stats and innodb_index_stats and then start up mysql server and nginx again. I stopped nginx so you don't get email bombarded with mysql error messages
    4. then discard those tables from innodb tablespace
    5. then import the mysql databases 3 innodb tables structures from mariadb10_3tables.sql file
    6. then restart mysql server, and move old mysql error log file from /var/log/mysqld.log to /var/log/mysqld.log-oldlog and create a new empty fresh old file
    7. then run mysql_upgrade forced option to check and repair all mysql database tables.
    8. then tail the last 25 lines of mysql error log /var/log/mysqld.log to check if mysql restarted clean and without errors (as shown in below example)
    how to download and run mariadb10fix.sh
    wget -cnv https://gist.github.com/centminmod/ee2befd9f8807561cd0a/raw/mariadb10fix.sh
    chmod +x mariadb10fix.sh
    ./mariadb10fix.sh
    example output below
    creating work directory at /home/mysql10fix
    changing to /home/mysql10fix
    backuping up all databases first including system tables
    backup time depends on size of all your databases
    downloading missing tables sql file
    2014-10-08 04:52:20 URL:https://gist.githubusercontent.com/centminmod/9bb511a8e59a9df7190f/raw/417ac17a855fc2c00a297ce100808fdb444c95f3/mariadb10_3tables.sql [3530] -> "mariadb10_3tables.sql" [1]
    stopping mysql server
    Shutting down MySQL.. SUCCESS!
    check missing table files
    -rw------- 1 mysql mysql 1.0K Sep 20 01:19 gtid_slave_pos.frm
    -rw------- 1 mysql mysql  96K Sep 20 01:19 gtid_slave_pos.ibd
    -rw------- 1 mysql mysql 4.9K Sep 20 01:19 innodb_index_stats.frm
    -rw------- 1 mysql mysql  96K Sep 20 01:19 innodb_index_stats.ibd
    -rw------- 1 mysql mysql 1.5K Sep 20 01:19 innodb_table_stats.frm
    -rw------- 1 mysql mysql  96K Sep 20 01:19 innodb_table_stats.ibd
    removing missing tables' files
    starting mysql server
    Starting MySQL. SUCCESS!
    discarding missing table spaces
    importing missing tables create sql file
    mysql_upgrade --force mysql
    Phase 1/3: Running 'mysql_fix_privilege_tables'...
    Processing databases
    mysql
    mysql.column_stats                                 OK
    mysql.columns_priv                                 OK
    mysql.db                                           OK
    mysql.event                                        OK
    mysql.func                                         OK
    mysql.gtid_slave_pos                               OK
    mysql.help_category                                OK
    mysql.help_keyword                                 OK
    mysql.help_relation                                OK
    mysql.help_topic                                   OK
    mysql.host                                         OK
    mysql.index_stats                                  OK
    mysql.innodb_index_stats                           OK
    mysql.innodb_table_stats                           OK
    mysql.plugin                                       OK
    mysql.proc                                         OK
    mysql.procs_priv                                   OK
    mysql.proxies_priv                                 OK
    mysql.roles_mapping                                OK
    mysql.servers                                      OK
    mysql.table_stats                                  OK
    mysql.tables_priv                                  OK
    mysql.time_zone                                    OK
    mysql.time_zone_leap_second                        OK
    mysql.time_zone_name                               OK
    mysql.time_zone_transition                         OK
    mysql.time_zone_transition_type                    OK
    mysql.user                                         OK
    Phase 2/3: Fixing table and database names
    Phase 3/3: Checking and upgrading tables
    information_schema
    performance_schema
    OK
    check mysql error log
    141008  4:52:23 [Note] InnoDB: Starting shutdown...
    141008  4:52:25 [Note] InnoDB: Shutdown completed; log sequence number 1617174
    141008  4:52:25 [Note] /usr/sbin/mysqld: Shutdown complete
    141008 04:52:25 mysqld_safe mysqld from pid file /var/lib/mysql/centos65np.localdomain.pid ended
    141008 04:52:26 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
    141008  4:52:26 [Note] InnoDB: Using mutexes to ref count buffer pool pages
    141008  4:52:26 [Note] InnoDB: The InnoDB memory heap is disabled
    141008  4:52:26 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
    141008  4:52:26 [Note] InnoDB: Compressed tables use zlib 1.2.3
    141008  4:52:26 [Note] InnoDB: Using Linux native AIO
    141008  4:52:26 [Note] InnoDB: Not using CPU crc32 instructions
    141008  4:52:26 [Note] InnoDB: Initializing buffer pool, size = 48.0M
    141008  4:52:26 [Note] InnoDB: Completed initialization of buffer pool
    141008  4:52:26 [Note] InnoDB: Highest supported file format is Barracuda.
    141008  4:52:26 [Note] InnoDB: 128 rollback segment(s) are active.
    141008  4:52:26 [Note] InnoDB: Waiting for purge to start
    141008  4:52:26 [Note] InnoDB:  Percona XtraDB (http://www.percona.com) 5.6.19-67.0 started; log sequence number 1617174
    141008  4:52:26 [Note] Plugin 'FEDERATED' is disabled.
    141008  4:52:26 [Note] Plugin 'ARCHIVE' is disabled.
    141008  4:52:26 [Note] Plugin 'FEEDBACK' is disabled.
    141008  4:52:26 [Note] Server socket created on IP: '::'.
    141008  4:52:26 [Note] Event Scheduler: Loaded 0 events
    141008  4:52:26 [Note] /usr/sbin/mysqld: ready for connections.
    Version: '10.0.13-MariaDB'  socket: '/var/lib/mysql/mysql.sock'  port: 3306  MariaDB Server
  20. Andy
    Andy Active Member
    546
    90
    10:08 AM
    Thank you very much George.
    I have run the fix and the log output is exactly like what you expected.
