  1. Andy
    Andy Active Member
    546
    90
    5:11 PM
    @eva2000
    I got this far. Does it mean I have to run the install again?
    * Running updatedb command. Please wait....
    Error: axivo-release-7-1.noarch.rpm not found !!! Download now......
    2014-09-06 12:08:20 URL:http://rpm.axivo.com/axivo-release-7-1.noarch.rpm [16856/16856] -> "axivo-release-7-1.noarch.rpm" [1]
    Download done.
    Preparing...                          ########################################
    Updating / installing...
    axivo-release-7-1                     ########################################
    http://mirror.rackspace.com/centos/7.0/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
    Trying other mirror.
     One of the configured repositories failed (CentOS-7.0 - Base),
     and yum doesn't have enough cached data to continue. At this point the only
     safe thing yum can do is fail. There are a few ways to work "fix" this:
         1. Contact the upstream for the repository and get them to fix the problem.
         2. Reconfigure the baseurl/etc. for the repository, to point to a working
            upstream. This is most often useful if you are using a newer
            distribution release than is supported by the repository (and the
            packages for the previous distribution release still work).
         3. Disable the repository, so yum won't use it by default. Yum will then
            just ignore the repository until you permanently enable it again or use
            --enablerepo for temporary usage:
                yum-config-manager --disable base
         4. Configure the failing repository to be skipped, if it is unavailable.
            Note that yum will try to contact the repo. when it runs most commands,
            so will have to try and fail each time (and thus. yum will be be much
            slower). If it is a very temporary problem though, this is often a nice
            compromise:
                yum-config-manager --save --setopt=base.skip_if_unavailable=true
    failure: repodata/repomd.xml from base: [Errno 256] No more mirrors to try.
    Error: problem with axivo-release-7-1.noarch.rpm install.
    ccache stats:
    cache hit (direct)                   712
    cache hit (preprocessed)             303
    cache miss                          2517
    called for link                      216
    called for preprocessing             154
    compile failed                        47
    preprocessor error                    39
    bad compiler arguments                20
    unsupported source language           57
    autoconf compile/link                413
    unsupported compiler option           14
    no input file                         89
    files in cache                      6002
    cache size                         190.1 Mbytes
    max cache size                       2.0 Gbytes
    Total YUM Time: 369.154334496 seconds
    Total Centmin Mod Install Time: 1497.976711029 seconds
    Created command shortcuts:
    * type cmdir to change to Centmin Mod install directory
      at /usr/local/src/centminmod-123.08centos7beta01
    * type centmin call and run centmin.sh
      at /usr/local/src/centminmod-123.08centos7beta01/centmin.sh
    59,946
    12,556
    8:11 AM
  3. Andy
    Andy Active Member
    546
    90
    5:11 PM
    Is this an issue going forward?
    [root@cloud-server-01 ~]# yum update
    Loaded plugins: fastestmirror, langpacks, priorities
            compromise:
    59,946
    12,556
    8:11 AM
  5. Andy
    Andy Active Member
    546
    90
    5:11 PM
    yum clean all does not help.
    content of yum.conf
    [main]
    cachedir=/var/cache/yum
    keepcache=0
    debuglevel=2
    logfile=/var/log/yum.log
    distroverpkg=redhat-release
    tolerant=1
    exactarch=1
    obsoletes=1
    gpgcheck=1
    plugins=1
    exclude=*.i386 *.i586 *.i686 nginx* php* mysql*
    # Note: yum-RHN-plugin doesn't honor this.
    metadata_expire=1h
    installonly_limit = 5
    # PUT YOUR REPOS HERE OR IN separate files named file.repo
    # in /etc/yum.repos.d
    59,946
    12,556
    8:11 AM
    what about /etc/yum.repos.d/*.repo files ?
    looks like rackspace mirror changed to Index of /centos/7/os/x86_64 minus the .0 in 7.0
    checking all the other reported 404 YUM mirrors has common problem, the mirrors changed from 7.0 to just 7
  7. Andy
    Andy Active Member
    546
    90
    5:11 PM
    I see no .conf file under that directory
    [root@cloud-server-01 ~]# ls -al /etc/yum.repos.d/
    total 96
    drwxr-xr-x.  2 root root 4096 Sep  6 12:08 .
    drwxr-xr-x. 91 root root 4096 Sep  6 12:08 ..
    -rw-r--r--.  1 root root 1161 Aug  9 20:06 axivo.repo
    -rw-r--r--.  1 root root 1625 Aug 27 16:54 CentOS-Base.OLD
    -rw-r--r--.  1 root root 1691 Sep  6 11:43 CentOS-Base.repo
    -rw-r--r--.  1 root root 1664 Aug 22 16:21 CentOS-Base.repo.rpmnew
    -rw-r--r--.  1 root root  649 Aug 22 16:21 CentOS-Debuginfo.repo
    -rw-r--r--.  1 root root  290 Aug 22 16:21 CentOS-fasttrack.repo
    -rw-r--r--.  1 root root 1331 Aug 22 16:21 CentOS-Sources.repo
    -rw-r--r--.  1 root root  156 Aug 22 16:21 CentOS-Vault.repo
    -rw-r--r--.  1 root root  934 Aug 27 16:54 epel.OLD
    -rw-r--r--.  1 root root  961 Sep  6 11:47 epel.repo
    -rw-r--r--.  1 root root  957 Sep  2 16:14 epel.repo.rpmnew
    -rw-r--r--.  1 root root 1056 Sep  2 16:14 epel-testing.repo
    -rw-r--r--.  1 root root  356 Sep  6 11:58 mariadb.repo
    -rw-r--r--.  1 root root  739 Jun 12 01:41 mirrors-rpmforge
    -rw-r--r--.  1 root root  717 Jun 12 01:41 mirrors-rpmforge-extras
    -rw-r--r--.  1 root root  728 Jun 12 01:41 mirrors-rpmforge-testing
    -rw-r--r--.  1 root root  267 Dec 16  2009 Percona.OLD
    -rw-r--r--.  1 root root  340 Sep  6 11:48 Percona.repo
    -rw-r--r--.  1 root root 1128 Jun 12 01:41 rpmforge.OLD
    -rw-r--r--.  1 root root 1139 Sep  6 11:48 rpmforge.repo
    -rw-r--r--.  1 root root  212 Jul  9  2013 varnish.OLD
    -rw-r--r--.  1 root root  223 Sep  6 11:48 varnish.repo
    59,946
    12,556
    8:11 AM
    meant *.repo heh in particular /etc/yum.repos.d/CentOS-Base.repo
    Try this
    yum clean all
    rm -rf /var/cache/yum/*
  9. Andy
    Andy Active Member
    546
    90
    5:11 PM
    [root@cloud-server-01 ~]# rm -rf /var/cache/yum/*
    [URL]http://mirror.rackspace.com/centos/7.0/os/x86_64/repodata/repomd.xml[/URL]: [Errno 14] HTTP Error 404 - Not Found
            compromise:
  10. Sebastian B.
    Sebastian B. New Member
    25
    12:11 AM
    1.7.2
    5.5
    Well I have done this on my linode to still dont working. I made an ticket
    59,946
    12,556
    8:11 AM
    what's contents of /etc/yum.repos.d/CentOS-Base.repo ?
  12. Andy
    Andy Active Member
    546
    90
    5:11 PM
    # CentOS-Base.repo
    # The mirror system uses the connecting IP address of the client and the
    # update status of each mirror to pick mirrors that are updated to and
    # geographically close to the client.  You should use this for CentOS updates
    # unless you are manually picking other mirrors.
    ## If the mirrorlist= does not work for you, as a fall back you can try the
    # remarked out baseurl= line instead.
    [base]
    name=CentOS-$releasever - Base
    #mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=os
    baseurl=http://mirror.rackspace.com/centos/$releasever/os/$basearch/
    gpgcheck=1
    gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-7
    priority=1
    #released updates
    [updates]
    name=CentOS-$releasever - Updates
    #mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=updates
    baseurl=http://mirror.rackspace.com/centos/$releasever/updates/$basearch/
    gpgcheck=1
    priority=1
    priority=1
    59,946
    12,556
    8:11 AM
    uncomment the mirrorlist lines
    then do
    yum clean all
  14. Andy
    Andy Active Member
    546
    90
    5:11 PM
    http://ftp.cuhk.edu.hk/pub/Linux/centos/7.0/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
    http://centos.mirror.iweb.ca/7.0/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
    http://ftp.jaist.ac.jp/pub/Linux/CentOS/7.0/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
    ftp://mirror.aarnet.edu.au/pub/centos/7.0/os/x86_64/repodata/repomd.xml: [Errno 14] FTP Error 550 - Server denied you to change to the given directory
    http://mirrors.coreix.net/centos/7.0/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
    http://mirror.us.leaseweb.net/centos/7.0/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
    ftp://mirror.anl.gov/pub/centos/7.0/os/x86_64/repodata/repomd.xml: [Errno 14] FTP Error 550 - Server denied you to change to the given directory
    http://mirror.as24220.net/pub/centos/7.0/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
    ftp://ftp.free.fr/mirrors/ftp.centos.org/7.0/os/x86_64/repodata/repomd.xml: [Errno 14] FTP Error 550 - Server denied you to change to the given directory
    ftp://mirror.bytemark.co.uk/centos/7.0/os/x86_64/repodata/repomd.xml: [Errno 14] FTP Error 550 - Server denied you to change to the given directory
            compromise:
  15. Sebastian B.
    25
    12:11 AM
    1.7.2
    5.5
    [base]
    baseurl=http://mirrors.linode.com/centos/$releasever/os/$basearch/
    gpgcheck=1
    priority=1
    #released updates
    [updates]
    baseurl=http://mirrors.linode.com/centos/$releasever/updates/$basearch/
    gpgcheck=1
    priority=1
    priority=1
    #additional packages that may be useful
    [extras]
    name=CentOS-$releasever - Extras
    mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=extras
    baseurl=http://mirrors.linode.com/centos/$releasever/extras/$basearch/
    gpgcheck=1
    priority=1
    #additional packages that extend functionality of existing packages
    [centosplus]
    name=CentOS-$releasever - Plus
    mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=centosplus
    baseurl=http://mirrors.linode.com/centos/$releasever/centosplus/$basearch/
    gpgcheck=1
    enabled=0
    priority=2
    priority=2
    And the links do really not exist:
    http://mirrors.linode.com/centos/7.0/os/x86_64/repodata/repomd.xml
    should be without ".0"
    http://mirrors.linode.com/centos/7/os/x86_64/repodata/repomd.xml --> works
    59,946
    12,556
    8:11 AM
    try replacing in /etc/yum.repos.d/CentOS-Base.repo instances of
    OR
    with
    http://mirror.centos.org
    then
    yum clean all
  17. Sebastian B.
    25
    12:11 AM
    1.7.2
    5.5
    59,946
    12,556
    8:11 AM
    Yeah someone changed the mirror locations for CentOS 7 :mad: :rolleyes:
    my working CentOS 7 has for /etc/yum.repos.d/CentOS-Base.repo
    # CentOS-Base.repo
    [base]
    mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=os&infra=$infra
    #baseurl=http://mirror.centos.org/centos/$releasever/os/$basearch/
    gpgcheck=1
    priority=1
    #released updates
    [updates]
    mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=updates&infra=$infra
    #baseurl=http://mirror.centos.org/centos/$releasever/updates/$basearch/
    gpgcheck=1
    priority=1
    priority=1
    [extras]
    mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=extras&infra=$infra
    #baseurl=http://mirror.centos.org/centos/$releasever/extras/$basearch/
    gpgcheck=1
    priority=1
    [centosplus]
    mirrorlist=http://mirrorlist.centos.org/?release=$releasever&arch=$basearch&repo=centosplus&infra=$infra
    #baseurl=http://mirror.centos.org/centos/$releasever/centosplus/$basearch/
    gpgcheck=1
    enabled=0
    priority=2
    and for mirror list at /var/cache/yum/base/mirrorlist.txt
    http://mirror.ventraip.net.au/CentOS/7.0.1406/os/x86_64/
    http://centos.syd.au.glomirror.com.au/7.0.1406/os/x86_64/
    http://mirror.overthewire.com.au/pub/centos/7.0.1406/os/x86_64/
    http://centos.mirror.crucial.com.au/7.0.1406/os/x86_64/
    http://centos.mirror.serversaustralia.com.au/7.0.1406/os/x86_64/
    http://centos.wtl.nsw.au.glomirror.com.au/7.0.1406/os/x86_64/
    http://centos.vic.au.glomirror.com.au/7.0.1406/os/x86_64/
    http://mirror.colocity.com/centos/7.0.1406/os/x86_64/
    http://ftp.swin.edu.au/centos/7.0.1406/os/x86_64/
    http://mirror.internode.on.net/pub/centos/7.0.1406/os/x86_64/
    for /var/cache/yum/updates/mirrorlist.txt
    http://mirror.ventraip.net.au/CentOS/7.0.1406/updates/x86_64/
    http://centos.mirror.serversaustralia.com.au/7.0.1406/updates/x86_64/
    http://mirror.web24.net.au/centos/7.0.1406/updates/x86_64/
    http://mirror.rackcentral.com.au/centos/7.0.1406/updates/x86_64/
    http://centos.wtl.nsw.au.glomirror.com.au/7.0.1406/updates/x86_64/
    http://mirror.internode.on.net/pub/centos/7.0.1406/updates/x86_64/
    http://centos.mirror.uber.com.au/7.0.1406/updates/x86_64/
    http://mirror.colocity.com/centos/7.0.1406/updates/x86_64/
    http://mirror.mel.bkb.net.au/pub/centos/7.0.1406/updates/x86_64/
    http://ftp.swin.edu.au/centos/7.0.1406/updates/x86_64/
  19. Andy
    Andy Active Member
    546
    90
    5:11 PM
    I change the content to yours, @eva2000 but still same 404 errors.
    59,946
    12,556
    8:11 AM
    I'd contact your respective web hosts tech support at Rackspace and Linode :)
