  1. Tracy Perry
    Tracy Perry Active Member
    280
    118
    Texas
    5:34 PM
    1.21.6
    MariaDB 10.3.36
    I think that it was a "custom" config option, then that had an option (I think) to use the default kernel - which I assume meant the REAL kernel. If nothing else, I'll burn it again if this doesn't work. Like I commented to the guy over on TAZ... some people think this stuff is fun (messing with servers) and I happen to be one of them. Yes, I'm a sick puppy. :wacky:
    59,946
    12,556
    8:34 AM
    i have the same disease :D
    59,946
    12,556
    8:34 AM
    @Tracy Perry if you can take screenshot of the right template and kernel option once you figured it out, that would be great so others know :)
  4. Tracy Perry
    280
    118
    Texas
    5:34 PM
    1.21.6
    MariaDB 10.3.36
    That's what it was... it's working fine now. They need to redo their setup.. if I want their custom kernel I'll ask for it.. don't shove it down my throat like that!
  5. Tracy Perry
    280
    118
    Texas
    5:34 PM
    1.21.6
    MariaDB 10.3.36
    Already burned it.. but I went JUST to the point of no return and grabbed screenshots. Let me edit them in PhotoShop for some stuff and then I'll upload them here.
  6. Tracy Perry
    280
    118
    Texas
    5:34 PM
    1.21.6
    MariaDB 10.3.36
    First step... choose one of these two poisons.
    Second step, make sure you click on the Custom Installation
    Next, either accept the default partitions, or customize your layout
    Then make sure on the next screen you choose "Use the distribution kernel".
  7. Tracy Perry
    280
    118
    Texas
    5:34 PM
    1.21.6
    MariaDB 10.3.36
    Where is the option to turn off the creation of FTP users... since I don't "do" FTP and only via SSH.
  8. rdan
    6:34 AM
    Looks like Tracy already figure it out :).
  9. Tracy Perry
    280
    118
    Texas
    5:34 PM
    1.21.6
    MariaDB 10.3.36
    yeah, now I just have to figure out what I want to do with the server.
    Now I'm debating grabbing SolusVM and installing on it and using to to create VPS's with. Already played with ProxMox so now may be time to try something new.
  10. robbyq92
    robbyq92 New Member
    12:34 AM
    1.9.2
    Maria DB 10
    php 5.7 only work for centos 7?
  11. rdan
    6:34 AM
    No, will work on 6.6, 6.6 ,7.0, 7.1
  12. robbyq92
    robbyq92 New Member
    12:34 AM
    1.9.2
    Maria DB 10
  13. rdan
    6:34 AM
    There's no 5.7 by the way, Only PHP 7.
    59,946
    12,556
    8:34 AM
    from Beta Branch - Centmin Mod .08 beta + pure-ftpd virtual FTP user support | Centmin Mod Community - 2nd post
    You can read PHP - PHP 7.0.0 Alpha 1 Released | Centmin Mod Community PHP 5.7 is now called PHP 7.0 and yes from linked page instructions on updating to PHP 7.0 Alpha so if you have questions on PHP 7 updating you can ask at PHP - PHP 7.0.0 Alpha 1 Released | Centmin Mod Community :)
  15. rdan
    6:34 AM
    Still I have this error on initial install:
    59,946
    12,556
    8:34 AM
    arrgh.. :banghead: will look at it again !
    59,946
    12,556
    8:34 AM
    i updated .08 beta03's post install checks to make sure if crond service is running as I found on ONLY some VPS that after Centmin Mod initial install that crond service isn't running. Folks can check by typing
    service crond status
    and start and enable start on reboot by typing
    service crond start
    chkconfig crond on
    reason is something strange happens with the new check in place at postinstall check
    Ensure crond service is running
    service crond start
    crond: unrecognized service
    chkconfig crond on
    error reading information on service crond: No such file or directory
    however, manually running is fine
    crond is stopped
    service crond start
    Starting crond:                                            [  OK  ]
    chkconfig crond on
    59,946
    12,556
    8:34 AM
    will need to add another 3rd party YUM repo = ATrpms for CentOS 7 fix for centmin.sh menu option 19 install of ffmpeg-php extension as CentOS 7's epel and rpmforge YUM repos are missing some packages which CentOS 6 equivalent have. ATrpms has such missing packages. Also fixed inc/ffmpeginstall.inc routine too
    @Matt reported the issue and made a fix via experimental git branch, 123.08beta03-el7ffmpeg-fix at Unable to install FFMPEG PHP extension
    edit: Just merged the branch into official 123.08beta03 branch Commits · centminmod/centminmod · GitHub :D
    for existing .08 beta03 users after updating your code, to sync the new ATrpms YUM repo, run centmin.sh menu option 5 and when prompted for YUM install checks answer yes = y but when asked to upgrade PHP answer NO = n.
                       Centmin Mod Menu
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    11). MariaDB 5.2/5.5 & 10.x Upgrade Sub-Menu
    14). SELinux disable
    16). Change SSHD Port Number
    20). NSD Re-install
    24). Exit
    Enter option [ 1 - 24 ] 5
    Custom configure CSF settings...set
    Do you want to run YUM install checks ?  [y/n]
    This will increase your upgrade duration time wise.
    Check the change log centminmod.com/changelog.html
    to see if any Nginx or PHP related new additions
    which require checking YUM prequisites are met.
    If no new additions made, you can skip the
    YUM install check to speed up upgrade time.
    [y/n]: y
    PHP Upgrade - Would you like to continue? [y/n] n
    Then you should have ATrpms added and setup then you can proceed with centmin.sh menu option 19
    59,946
    12,556
    8:34 AM
    59,946
    12,556
    8:34 AM
