  1. Mask
    Mask Active Member
    108
    31
    3:34 AM
    Nginx 1.9.1
    MariaDB 10.0.19
    Ahhh,
    I used github method using Option1.
    So no stats in that case ?
  2. Mask
    Mask Active Member
    108
    31
    3:34 AM
    Nginx 1.9.1
    MariaDB 10.0.19
    Well since I didn't really setup a domain on server, I went ahead with a OS reinstall and setup CMM again just to get those pretty stats. :D
    On a 4 Core / 8GB Ram VPS. (OpenVZ)
    59,946
    12,556
    8:34 AM
    Nice and fast ~18 seconds faster than my fastest time so far :)
    yeah no extended stats only for curl as the curl method is a separate script wrapper to run centmin install so i can get the stats after centmin install is done via the separate script wrapper. While github method runs the centmin install script and that doesn't have stats until after install so the stats not available during centmin mod centmin.sh install.
    59,946
    12,556
    8:34 AM
    Updated cminfo command for quick server summary for support for ssl.conf files generated by new nginx vhost SSL generator and also added support for getting server's geographical location too :)
    June 26th commits Commits · centminmod/centminmod · GitHub
    Centmin Mod Quick Info:
    Server Location Info
      ip: IPADDRESS
      city: Los Angeles
      region: California
      country: US
    Processors physical = 1, cores = 4, virtual = 4, hyperthreading = no
          4  3300.117
          4  Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz
          4  8192 KB
    System Uptime:         up 4 days, 8:18,
    MySQL Server Started   2015-06-21 20:29:04
    MySQL Uptime:          3 days 20 hours 55 min 2 sec
    MySQL Uptime (secs):   334502
    Server Type:           openvz
    CentOS Version:        6.6
    Centmin Mod:           1.2.3-eva2000.08
    Nginx PageSpeed:       OFF
    Nginx Version:         1.9.2
    PHP-FPM Version:       5.4.42
    MariaDB Version:       10.0.20
    CSF Firewall:          v7.69
    Memcached Server:      1.4.24
    NSD Version:           3.2.18
    Siege Version:         3.1.0
    Maldet Version:        not installed
    ClamAV Version:        not installed
    ElasticSearch:         not installed
    Site Nginx Vhost Accounts:
    * sky1.newdomain.com - /home/nginx/domains/sky1.newdomain.com
    * sky2.newdomain.com - /home/nginx/domains/sky2.newdomain.com
    * sky3.newdomain.com - /home/nginx/domains/sky3.newdomain.com
    * sky4.newdomain.com - /home/nginx/domains/sky4.newdomain.com
    * sky5.newdomain.com - /home/nginx/domains/sky5.newdomain.com
    Site Nginx Vhost Config Files:
    * /usr/local/nginx/conf/conf.d/sky1.newdomain.com.conf
    * /usr/local/nginx/conf/conf.d/sky1.newdomain.com.ssl.conf
    * /usr/local/nginx/conf/conf.d/sky2.newdomain.com.conf
    * /usr/local/nginx/conf/conf.d/sky2.newdomain.com.ssl.conf
    * /usr/local/nginx/conf/conf.d/sky3.newdomain.com.conf
    * /usr/local/nginx/conf/conf.d/sky3.newdomain.com.ssl.conf
    * /usr/local/nginx/conf/conf.d/sky4.newdomain.com.conf
    * /usr/local/nginx/conf/conf.d/sky4.newdomain.com.ssl.conf
    * /usr/local/nginx/conf/conf.d/sky5.newdomain.com.conf
    * /usr/local/nginx/conf/conf.d/sky5.newdomain.com.ssl.conf
    MySQL Databases:
    * mysql [idx: 0.12 MB data: 0.58 MB]
    System User Ids >81:
    nobody:x:99:99:Nobody:/:/sbin/nologin
    saslauth:x:499:76:Saslauthd user:/var/empty/saslauth:/sbin/nologin
    dbus:x:81:81:System message bus:/:/sbin/nologin
    500:x:500:500::/home/500:/sbin/nologin
    nginx:x:501:501::/home/nginx:/sbin/nologin
    mysql:x:498:499:MySQL server:/var/lib/mysql:/sbin/nologin
    postfix:x:89:89::/var/spool/postfix:/sbin/nologin
    nsd:x:502:502::/home/nsd:/sbin/nologin
    Pure-FTP Virtual FTP Info:
    Nginx Configuration:
    nginx version: nginx/1.9.2
    built with LibreSSL 2.2.0
    TLS SNI support enabled
    configure arguments: --with-ld-opt='-lrt -ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib' --with-cc-opt='-m64 -mtune=native -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wno-deprecated-declarations -Wno-unused-parameter -Wno-unused-const-variable -Wno-conditional-uninitialized -Wno-mismatched-tags -Wno-c++11-extensions -Wno-sometimes-uninitialized -Wno-parentheses-equality -Wno-tautological-compare -Wno-self-assign -Wno-deprecated-register -Wno-deprecated -Wno-invalid-source-encoding -Wno-pointer-sign -Wno-parentheses -Wno-enum-conversion' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_ssl_module --with-http_gzip_static_module --with-http_stub_status_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module --with-http_secure_link_module --with-http_realip_module --with-http_geoip_module --with-openssl-opt=enable-tlsext --add-module=../ngx-fancyindex-ngx-fancyindex --add-module=../ngx_cache_purge-2.3 --add-module=../nginx-accesskey-2.0.3 --add-module=../nginx-http-concat-master --add-module=../openresty-memc-nginx-module-1518da4 --add-module=../openresty-srcache-nginx-module-ffa9ab7 --add-module=../ngx_devel_kit-0.2.19 --add-module=../set-misc-nginx-module-0.28 --add-module=../echo-nginx-module-0.57 --add-module=../lua-nginx-module-0.9.16rc1 --add-module=../lua-upstream-nginx-module-0.02 --add-module=../lua-upstream-cache-nginx-module-0.1.1 --add-module=../nginx_upstream_check_module-0.3.0 --add-module=../nginx-module-vts --add-module=../headers-more-nginx-module-0.25 --with-openssl=../libressl-2.2.0 --with-libatomic --with-threads --with-stream --with-stream_ssl_module --with-pcre=../pcre-8.37 --with-pcre-jit --with-http_spdy_module --add-module=../ngx_pagespeed-release-1.9.32.3-beta
    Nginx Settings:
    user              nginx nginx;
    worker_processes 2;
    worker_priority -10;
    worker_rlimit_nofile 260000;
    timer_resolution 100ms;
    pcre_jit on;
            tcp_nopush  on;
            tcp_nodelay on;
            server_tokens off;
            keepalive_timeout  8;
            keepalive_requests 1000;
            lingering_time 20s;
            lingering_timeout 5s;
            keepalive_disable msie6;
            gzip on;
            gzip_vary   on;
            gzip_disable "MSIE [1-6]\.";
            gzip_static on;
            gzip_min_length   1400;
            gzip_buffers      32 8k;
            gzip_http_version 1.0;
            gzip_comp_level 5;
            gzip_proxied    any;
            gzip_types text/plain text/css text/xml application/javascript application/x-javascript application/xml application/xml+rss application/ecmascript application/json image/svg+xml;
    client_body_buffer_size 256k;
    client_body_in_file_only off;
    client_body_timeout 60s;
    client_header_buffer_size 64k;
    client_header_timeout  8s;
    client_max_body_size 50m;
    connection_pool_size  512;
    directio  4m;
    large_client_header_buffers 8 64k;
    types_hash_max_size 2048;
    server_names_hash_bucket_size 64;
    open_file_cache max=50000 inactive=60s;
    open_file_cache_valid 120s;
    open_file_cache_min_uses 2;
    open_file_cache_errors off;
    open_log_file_cache max=10000 inactive=30s min_uses=2;
    PHP-FPM Configuration:
    Configure Command =>  '../configure'  '--enable-fpm' '--enable-intl' '--enable-pcntl' '--with-mcrypt' '--with-snmp' '--with-mhash' '--with-zlib' '--with-gettext' '--enable-exif' '--enable-zip' '--with-bz2' '--enable-soap' '--enable-sockets' '--enable-sysvmsg' '--enable-sysvsem' '--enable-sysvshm' '--enable-shmop' '--with-pear' '--enable-mbstring' '--with-openssl' '--with-mysql=mysqlnd' '--with-libdir=lib64' '--with-mysqli=mysqlnd' '--with-mysql-sock=/var/lib/mysql/mysql.sock' '--with-curl' '--with-gd' '--with-xmlrpc' '--enable-bcmath' '--enable-calendar' '--enable-ftp' '--enable-gd-native-ttf' '--with-freetype-dir=/usr' '--with-jpeg-dir=/usr' '--with-png-dir=/usr' '--with-xpm-dir=/usr' '--with-vpx-dir=/usr' '--with-t1lib=/usr' '--enable-pdo' '--with-pdo-sqlite' '--with-pdo-mysql=mysqlnd' '--enable-inline-optimization' '--with-imap' '--with-imap-ssl' '--with-kerberos' '--with-readline' '--with-libedit' '--with-gmp' '--with-pspell' '--with-tidy' '--with-enchant' '--with-fpm-user=nginx' '--with-fpm-group=nginx' '--disable-fileinfo' '--with-config-file-scan-dir=/etc/centminmod/php.d'
    PHP-FPM Settings /usr/local/etc/php-fpm.conf:
    log_level = warning
    user = nginx
    group = nginx
    listen = 127.0.0.1:9000
    listen.owner = nginx
    listen.group = nginx
    listen.mode = 0666
    pm = ondemand
    pm.max_children = 16
    pm.start_servers = 8
    pm.min_spare_servers = 4
    pm.max_spare_servers = 12
    pm.max_requests = 1000
    rlimit_files = 65536
    rlimit_core = 0
    pm.status_path = /phpstatus
    ping.path = /phpping
    ping.response = pong
    PHP-FPM Extensions Loaded:
    [PHP Modules]
    bcmath
    bz2
    calendar
    Core
    ctype
    curl
    date
    dom
    enchant
    ereg
    exif
    filter
    ftp
    gd
    geoip
    gettext
    gmp
    hash
    iconv
    igbinary
    imagick
    imap
    intl
    json
    libxml
    mbstring
    mcrypt
    memcache
    memcached
    mhash
    mongo
    mysql
    mysqli
    mysqlnd
    openssl
    pcntl
    pcre
    PDO
    pdo_mysql
    pdo_sqlite
    Phar
    posix
    pspell
    readline
    redis
    Reflection
    session
    shmop
    SimpleXML
    snmp
    soap
    sockets
    SPL
    sqlite3
    standard
    sysvmsg
    sysvsem
    sysvshm
    tidy
    tokenizer
    xml
    xmlreader
    xmlrpc
    xmlwriter
    Zend OPcache
    zip
    zlib
    [Zend Modules]
    Zend OPcache
    59,946
    12,556
    8:34 AM
  6. pamamolf
    4,127
    1:34 AM
    How can i benefit from multiple fpm pools?
    I mean if i can set a big enough pool why setting a second one will help for performance?
  7. rdan
    6:34 AM
    If you have a powerful CPU like having 3.5ghz with 8 cores and above, you can cater more PHP request at a time I think.
  8. rdan
    6:34 AM
    Right now, I'm still on Linode.
    So multiple pool is not applicable for me as Linode has only 2.8ghz CPU and running more PHP Pools will mostly kill my CPU.
  9. pamamolf
    4,127
    1:34 AM
    On my server i have 32 cores and 128gb ram :)
    But having one pool that it can accept for example 10.000 requests and having a second one with extra 10.000 connections how it can be faster if i have only 7.000 requests?
    Does it works in parallel/split way or something that really helps..... ?
    59,946
    12,556
    8:34 AM
    Google and research.. the reason why you should use them should be decided and researched by yourself. I only provide the tools, how and why you use them is up to you :D If you read PHP-FPM - WARNING: [pool www] server reached max_children setting (50), consider raising it | Centmin Mod Community you will get an idea of when it might be useful (in non-upstream ways) especially for php tasks that hog the time (i.e. uploads/attachments etc).
  11. pamamolf
    4,127
    1:34 AM
    Raising the max children if using only one pool doesn't sound like a problem....at least for me...
    Now if you mean that a php task will delay/kill the one and only pool and a second pool will help for this then is super :)
    59,946
    12,556
    8:34 AM
    Yup... been doing this on this very forum since last year :D
  13. pamamolf
    4,127
    1:34 AM
    How the requests will split between pools?
    I mean it will share the php requests equal or using another way?
    Is there a way to automatically know which pool is better to use when a pool has a big delay or something?
    59,946
    12,556
    8:34 AM
    59,946
    12,556
    8:34 AM
    59,946
    12,556
    8:34 AM
    Latest test run for .08 beta 03 on CentOS 7.1 OpenVZ
    Total Curl Installer YUM Time: 102.5837 seconds
    Total YUM Time: 67.950614920 seconds
    Total YUM + Source Download Time: 98.6413
    Total Nginx First Time Install Time: 126.1287
    Total PHP First Time Install Time: 158.7469
    Download Zip From Github Time: 3.7874
    Total Time Other eg. source compiles: 221.2703
    Total Centmin Mod Install Time: 604.7871
    Total Install Time (curl yum + cm install + zip download): 711.1582 seconds
    * Post-Install Check List....
    Check ccache Version:
    ccache version 3.2.2
    Copyright (C) 2009-2015 Joel Rosdahl
    version.
    Check Nginx Version:
    configure arguments: --with-ld-opt='-lrt -ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib' --with-cc-opt='-m64 -mtune=native -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wno-deprecated-declarations -Wno-unused-parameter -Wno-unused-const-variable -Wno-conditional-uninitialized -Wno-mismatched-tags -Wno-c++11-extensions -Wno-sometimes-uninitialized -Wno-parentheses-equality -Wno-tautological-compare -Wno-self-assign -Wno-deprecated-register -Wno-deprecated -Wno-invalid-source-encoding -Wno-pointer-sign -Wno-parentheses -Wno-enum-conversion' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_ssl_module --with-http_gzip_static_module --with-http_stub_status_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module --with-http_secure_link_module --with-http_realip_module --with-http_geoip_module --with-openssl-opt=enable-tlsext --add-module=../ngx-fancyindex-ngx-fancyindex --add-module=../ngx_cache_purge-2.3 --add-module=../nginx-accesskey-2.0.3 --add-module=../nginx-http-concat-master --add-module=../openresty-memc-nginx-module-1518da4 --add-module=../openresty-srcache-nginx-module-ffa9ab7 --add-module=../ngx_devel_kit-0.2.19 --add-module=../set-misc-nginx-module-0.28 --add-module=../echo-nginx-module-0.57 --add-module=../lua-nginx-module-0.9.16rc1 --add-module=../lua-upstream-nginx-module-0.02 --add-module=../lua-upstream-cache-nginx-module-0.1.1 --add-module=../nginx_upstream_check_module-0.3.0 --add-module=../nginx-module-vts --add-module=../headers-more-nginx-module-0.25 --with-openssl=../libressl-2.2.0 --with-libatomic --with-threads --with-stream --with-stream_ssl_module --with-pcre=../pcre-8.37 --with-pcre-jit --with-http_spdy_module --add-module=../ngx_pagespeed-release-1.9.32.4-beta
    Check PHP-FPM Version:
    PHP 5.4.42 (cli) (built: Jun 27 2015 03:44:46)
        with Zend OPcache v7.0.5, Copyright (c) 1999-2015, by Zend Technologies
    MariaDB-common-10.0.20-1.el7.centos.x86_64
    MariaDB-compat-10.0.20-1.el7.centos.x86_64
    MariaDB-client-10.0.20-1.el7.centos.x86_64
    MariaDB-shared-10.0.20-1.el7.centos.x86_64
    MariaDB-devel-10.0.20-1.el7.centos.x86_64
    MariaDB-server-10.0.20-1.el7.centos.x86_64
    memcached 1.4.24
    Check CSF Firewall Version:
    csf: v7.69 (generic)
    SIEGE 3.1.0
    Copyright (C) 2015 by Jeffrey Fulmer, et al.
    FOR A PARTICULAR PURPOSE.
    pscontrol admin
    pscontrol handler
    pscontrol edit
    pscontrol on
    pscontrol off
    pscontrol statson
    pscontrol statsoff
    Check mysqlreport version:
    Check NSD Bind Version:
    NSD version 3.2.18
    Written by NLnet Labs.
    Check pure-ftpd Version:
    pure-ftpd v1.0.36
    Check YUM Repo List
    * base: mirror.lax.hugeserver.com
    * epel: mirror.chpc.utah.edu
    * extras: repos.lax.quadranet.com
    * rpmforge: mirror.webnx.com
    * updates: mirrors.usc.edu
    149 packages excluded due to repository priority protections
    repo id             repo name                                          status
    base/7/x86_64       CentOS-7 - Base                                    6710+1942
    *epel/x86_64        Extra Packages for Enterprise Linux 7 - x86_64      7448+673
    extras/7/x86_64     CentOS-7 - Extras                                        149
    mariadb             MariaDB                                                 10+4
    rpmforge            RHEL 7 - RPMforge.net - dag                           164+81
    updates/7/x86_64    CentOS-7 - Updates                                   701+200
    vz-base             vz-base                                                    1
    vz-updates          vz-updates                                                 0
    repolist: 15183
    mytimes check:
    /usr/bin/mytimes
    Sat Jun 27 03:48:04 UTC 2015    [UTC]
    Sat Jun 27 13:48:04 AEST 2015   [Australia/Brisbane]
    Fri Jun 26 20:48:04 PDT 2015    [America/Los_Angeles]
    Fri Jun 26 22:48:04 CDT 2015    [America/Chicago]
    Fri Jun 26 23:48:04 EDT 2015    [America/New_York]
    Sat Jun 27 04:48:04 BST 2015    [Europe/London]
    59,946
    12,556
    8:34 AM
    Installed .08 beta 03 on 2 cpu Linode KVM VPS instance with CentOS 7.1 64Bit
    Total Curl Installer YUM Time: 73.6201 seconds
    Total YUM Time: 124.928790960 seconds
    Total YUM + Source Download Time: 147.1453
    Total Nginx First Time Install Time: 238.0213
    Total PHP First Time Install Time: 268.4313
    Download Zip From Github Time: 3.4569
    Total Time Other eg. source compiles: 281.5357
    Total Centmin Mod Install Time: 935.1335
    Total Install Time (curl yum + cm install + zip download): 1012.2105 seconds
    version.
    PHP 5.4.42 (cli) (built: Jun 27 2015 23:34:02)
    memcached 1.4.24
    SIEGE 3.1.0
    pscontrol admin
    pscontrol handler
    pscontrol edit
    pscontrol on
    pscontrol off
    pscontrol statson
    pscontrol statsoff
    NSD version 3.2.18
    pure-ftpd v1.0.36
    Check YUM Repo List
    * base: mirrors.linode.com
    * epel: mirror.sfo12.us.leaseweb.net
    * extras: mirrors.linode.com
    * updates: mirrors.linode.com
    base/7/x86_64      CentOS-7 - Base                                   6,710+1,942
    epel/x86_64        Extra Packages for Enterprise Linux 7 - x86_64      7,456+673
    repolist: 15,190
    mytimes check:
    /usr/bin/mytimes
    Sat Jun 27 23:38:13 UTC 2015    [UTC]
    Sun Jun 28 09:38:13 AEST 2015   [Australia/Brisbane]
    Sat Jun 27 16:38:13 PDT 2015    [America/Los_Angeles]
    Sat Jun 27 18:38:13 CDT 2015    [America/Chicago]
    Sat Jun 27 19:38:13 EDT 2015    [America/New_York]
    Sun Jun 28 00:38:13 BST 2015    [Europe/London]
  18. wiwat
    wiwat New Member
    7
    Thailand
    5:34 AM
    1.9.2
    10.0.20
    inc/php_upgrade.inc: line 512: syntax error in conditional expression
    inc/php_upgrade.inc: line 512: syntax error near `;'
    inc/php_upgrade.inc: line 512: `if [[ "$zendopcacheon" = [yY] && "$OLD_OPCACHEPHP" != [yY] ]; then'
    Created command shortcuts:
    * type cmdir to change to Centmin Mod install directory
      at /usr/local/src/centminmod-123.08beta03
    * type centmin call and run centmin.sh
      at /usr/local/src/centminmod-123.08beta03/centmin.sh
    bash: line 128: /root/centminlogs/firstyum_installtime_290615-044143.log: No such file or directory
    bash: line 130: /root/centminlogs/firstyum_installtime_290615-044143.log: No such file or directory
    tail: cannot open ‘/root/centminlogs/firstyum_installtime_*.log’ for reading: No such file or directory
    tail: cannot open ‘/root/centminlogs/centminmod_yumtimes_*.log’ for reading: No such file or directory
    tail: cannot open ‘/root/centminlogs/centminmod_downloadtimes_*.log’ for reading: No such file or directory
    tail: cannot open ‘/root/centminlogs/centminmod_ngxinstalltime_*.log’ for reading: No such file or directory
    tail: cannot open ‘/root/centminlogs/centminmod_phpinstalltime_*.log’ for reading: No such file or directory
    tail: cannot open ‘/root/centminlogs/*_install.log’ for reading: No such file or directory
    awk: fatal: cannot open file `/root/centminlogs/firstyum_installtime_*.log' for reading (No such file or directory)
    awk: fatal: cannot open file `/root/centminlogs/*_install.log' for reading (No such file or directory)
    (standard_in) 1: syntax error
    Total YUM + Source Download Time: 0.0000
    Total Nginx First Time Install Time: 0.0000
    Total PHP First Time Install Time: 0.0000
    Download Zip From Github Time: 9.6526
    Total Time Other eg. source compiles: 0.0000
    Total Centmin Mod Install Time: 0.0000
    Total Install Time (curl yum + cm install + zip download): 0.0000 seconds
    Can not install on CentsOS 7 Digitalocean
    59,946
    12,556
    8:34 AM
    unlucky, you ran into a bug from an update I made 2hrs ago.. just fixed it Commits · centminmod/centminmod · GitHub so if you try again on fresh OS reload, should work :) Bug was due to auto correct that sublime text editor can do when you type stuff heh
  20. wiwat
    wiwat New Member
    7
    Thailand
    5:34 AM
    1.9.2
    10.0.20
