    59,946
    12,556
    8:57 AM
    those are normal or some not founds are side effects or things happening in a certain order.. or for upgrades it's just that directory may already exist
    you can verify if all is working by the end of install post install check list of version if, if you get nginx version and configure paramters it's okay
    * Post-Install Check List....
    Check ccache Version:
    ccache version 3.2.2
    Copyright (C) 2009-2015 Joel Rosdahl
    version.
    Check Nginx Version:
    nginx version: nginx/1.9.2
    built with LibreSSL 2.2.0
    TLS SNI support enabled
    configure arguments: --with-ld-opt='-lrt -ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib' --with-cc-opt='-m64 -mtune=native -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wno-deprecated-declarations -Wno-unused-parameter -Wno-unused-const-variable -Wno-conditional-uninitialized -Wno-mismatched-tags -Wno-c++11-extensions -Wno-sometimes-uninitialized -Wno-parentheses-equality -Wno-tautological-compare -Wno-self-assign -Wno-deprecated-register -Wno-deprecated -Wno-invalid-source-encoding -Wno-pointer-sign -Wno-parentheses -Wno-enum-conversion' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_ssl_module --with-http_gzip_static_module --with-http_stub_status_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module --with-http_secure_link_module --with-http_realip_module --with-http_geoip_module --with-openssl-opt=enable-tlsext --add-module=../ngx-fancyindex-ngx-fancyindex --add-module=../ngx_cache_purge-2.3 --add-module=../nginx-accesskey-2.0.3 --add-module=../nginx-http-concat-master --add-module=../openresty-memc-nginx-module-1518da4 --add-module=../openresty-srcache-nginx-module-ffa9ab7 --add-module=../ngx_devel_kit-0.2.19 --add-module=../set-misc-nginx-module-0.28 --add-module=../echo-nginx-module-0.57 --add-module=../lua-nginx-module-0.9.16rc1 --add-module=../lua-upstream-nginx-module-0.02 --add-module=../lua-upstream-cache-nginx-module-0.1.1 --add-module=../nginx_upstream_check_module-0.3.0 --add-module=../nginx-module-vts --add-module=../headers-more-nginx-module-0.25 --with-openssl=../portable-2.2.0 --with-libatomic --with-threads --with-stream --with-stream_ssl_module --with-pcre=../pcre-8.37 --with-pcre-jit --with-http_spdy_module --add-module=../ngx_pagespeed-release-1.9.32.3-beta
    Check PHP-FPM Version:
    PHP 5.4.42 (cli) (built: Jun 18 2015 17:06:24)
    MariaDB-compat-10.0.19-1.el6.x86_64
    MariaDB-devel-10.0.19-1.el6.x86_64
    MariaDB-client-10.0.19-1.el6.x86_64
    MariaDB-server-10.0.19-1.el6.x86_64
    MariaDB-common-10.0.19-1.el6.x86_64
    MariaDB-shared-10.0.19-1.el6.x86_64
    memcached 1.4.24
    Check CSF Firewall Version:
    csf: v7.69 (generic)
    SIEGE 3.1.0
    Copyright (C) 2015 by Jeffrey Fulmer, et al.
    FOR A PARTICULAR PURPOSE.
    pscontrol admin
    pscontrol handler
    pscontrol edit
    pscontrol on
    pscontrol off
    pscontrol statson
    pscontrol statsoff
    Check mysqlreport version:
    Check NSD Bind Version:
    NSD version 3.2.18
    Written by NLnet Labs.
    Check pure-ftpd Version:
    pure-ftpd v1.0.30
    Check YUM Repo List
    Loaded plugins: downloadonly, fastestmirror, priorities, security
    * base: linux.mirrors.es.net
    * epel: mirror.sfo12.us.leaseweb.net
    * extras: mirror.hmc.edu
    * rpmforge: mirror.hmc.edu
    * updates: mirror.hmc.edu
    1599 packages excluded due to repository priority protections
    repo id        repo name                                             status
    base           CentOS-6 - Base                                       4,952+1,566
    epel           Extra Packages for Enterprise Linux 6 - x86_64        8,787+2,854
    extras         CentOS-6 - Extras                                              38
    mariadb        MariaDB                                                      12+5
    rpmforge       RHEL 6 - RPMforge.net - dag                           3,199+1,519
    updates        CentOS-6 - Updates                                        933+290
    repolist: 17,921
  2. pamamolf
    4,127
    1:57 AM
    Yes all working but i thik we need a syntax fix for this:
    nginx: [emerg] unknown directive "vhost_traffic_status_zone" in /usr/local/nginx/conf/vts_http.conf:1
    59,946
    12,556
    8:57 AM
    should of already been fixed.. but will see about tidying up the display of errors
  4. pamamolf
    4,127
    1:57 AM
    And for php only one error:
    With ZOPCACHEDFT='y' at the end of upgrade to latest 5.6.10 php i got:
    cat: /root/centminlogs/zendopcache_passfile.txt: No such file or directory
    59,946
    12,556
    8:57 AM
    do you see the file at end of install
    ls -lah /root/centminlogs
    total 6.3M
    drwxr-xr-x 2 root root 4.0K Jun 18 08:36 .
    dr-xr-x--- 6 root root 4.0K Jun 17 22:31 ..
    -rw-r--r-- 1 root root 2.7M Jun 17 19:43 centminmod_1.2.3-eva2000.08_170615-153309_install.log
    -rw-r--r-- 1 root root  22K Jun 17 19:43 centminmod_1.2.3-eva2000.08_170615-153309_yum-log.log
    -rw-r--r-- 1 root root  17K Jun 17 19:34 centminmod_1.2.3-eva2000.08_170615-153309_yuminstall_centos6.log
    -rw-r--r-- 1 root root 1.6K Jun 18 08:31 centminmod_1.2.3-eva2000.08_180615-083136_git_envsetup.log
    -rw-r--r-- 1 root root 2.4M Jun 18 08:42 centminmod_1.2.3-eva2000.08_180615-083630_php_upgrade.log
    -rw-r--r-- 1 root root 241K Jun 17 19:35 centminmod_downloadtimes_170615-153309.log
    -rw-r--r-- 1 root root   44 Jun 17 19:36 centminmod_libresslinstalltime_170615-153309.log
    -rw-r--r-- 1 root root 961K Jun 17 19:37 centminmod_ngxinstalltime_170615-153309.log
    -rw-r--r-- 1 root root   58 Jun 17 19:41 centminmod_phpinstalltime_170615-153309.log
    -rw-r--r-- 1 root root   37 Jun 17 19:34 centminmod_profiletimes_170615-153309.log
    -rw-r--r-- 1 root root  62K Jun 17 19:34 centminmod_yumtimes_170615-153309.log
    -rw-r--r-- 1 root root   53 Jun 17 19:43 firstyum_installtime_170615-153135.log
    -rw-r--r-- 1 root root 1.2K Jun 17 19:37 gcc_native.log
    -rw-r--r-- 1 root root   20 Jun 17 19:43 install.utc.time.log
    -rw-r--r-- 1 root root  199 Jun 17 19:35 securedtmp.log
    -rw-r--r-- 1 root root  381 Jun 18 08:36 zendopcache_passfile.txt
  6. pamamolf
    4,127
    1:57 AM
    nope not there :(
  7. pamamolf
    4,127
    1:57 AM
    When i let it run yum checks before Nginx upgrade i got this:
    * CentOS 6.x detected installing EPEL Repo
    Error: rpmforge-release-0.5.3-1.el6.rf.x86_64.rpm not found !!! Download now......
    2015-06-19 01:03:02 URL:http://apt.sw.be/redhat/el6/en/x86_64/rpmforge/RPMS/rpmforge-release-0.5.3-1.el6.rf.x86_64.rpm [12640/12640] -> "rpmforge-release-0.5.3-1.el6.rf.x86_64.rpm" [1]
    Download done.
    Error: Cannot retrieve metalink for repository: epel. Please verify its path and try again
    Error: problem with rpmforge-release-0.5.3-1.el6.rf.x86_64.rpm install.
  8. pamamolf
    4,127
    1:57 AM
    Is not my day:
    Try to upgrade Nginx:
    Download pcre-8.37.tar.gz ...
    --2015-06-19 01:07:19--  http://softlayer-dal.dl.sourceforge.net/project/pcre/pcre/8.37/pcre-8.37.tar.gz
    Resolving softlayer-dal.dl.sourceforge.net... 67.228.157.232
    Connecting to softlayer-dal.dl.sourceforge.net|67.228.157.232|:80... failed: Connection timed out.
    Retrying.
    --2015-06-19 01:07:35--  (try: 2)  http://softlayer-dal.dl.sourceforge.net/project/pcre/pcre/8.37/pcre-8.37.tar.gz
    Retrying.
    --2015-06-19 01:07:52--  (try: 3)  http://softlayer-dal.dl.sourceforge.net/project/pcre/pcre/8.37/pcre-8.37.tar.gz
    Giving up.
    Error: pcre-8.37.tar.gz download failed.
    check Centmin Mod log for details at /root/centminlogs/
    Aborting script...
    59,946
    12,556
    8:57 AM
    looks like you VPS internet connectivity had issues
    59,946
    12,556
    8:57 AM
  11. pamamolf
    4,127
    1:57 AM
    I am using and ovh dedicated but thanks for your recommendation :)
  12. pamamolf
    4,127
    1:57 AM
    I can't ping it from my pc also so it seems a problem with the link:
    Pinging 67.228.157.232 with 32 bytes of data:
    Request timed out.
    59,946
    12,556
    8:57 AM
    indeed looks like http://softlayer-dal.dl.sourceforge.net/project/pcre/pcre/8.37/pcre-8.37.tar.gz is down
    looks like most of sourceforge's usa mirrors are removed or gone from listing at http://sourceforge.net/projects/pcre/files/pcre/8.37/pcre-8.37.tar.gz/download ? maybe maintenance ?
    however that shouldn't matter as .08 beta03 now includes initial install source files in /downloads/svr-setup.zip so should by pass downloads for initial install..
    see example all downloads skipped
    Download ccache-3.2.2.tar.gz ...
    ccache 3.2.2 Archive found, skipping download...
    ccache-3.2.2.tar.gz valid file.
    install ccache 3.2.2+
    make: *** No rule to make target `clean'.  Stop.
    completed update to ccache 3.2.2+
    Set cache size limit to 2.2 GB
    Download csf.tgz ...
    csf Archive found, skipping download...
    csf.tgz valid file.
    Download siege-3.1.0.tar.gz ...
    siege-3.1.0.tar.gz found, skipping download...
    siege-3.1.0.tar.gz valid file.
    Download sproxy-latest.tar.gz ...
    sproxy-latest found, skipping download...
    sproxy-latest.tar.gz valid file.
    Download nginx-1.9.2.tar.gz ...
    nginx-1.9.2.tar.gz found, skipping download...
    nginx-1.9.2.tar.gz valid file.
    Download ngx-fancyindex-0.3.1.tar.gz ...
    ngx-fancyindex 0.3.1 Archive found, skipping download...
    ngx-fancyindex-0.3.1.tar.gz valid file.
    Download ngx_cache_purge-2.3.tar.gz ...
    ngx_cache_purge 2.3 Archive found, skipping download...
    ngx_cache_purge-2.3.tar.gz valid file.
    Download Nginx-accesskey-2.0.3.tar.gz ...
    Nginx-accesskey 2.0.3 Archive found, skipping download...
    Nginx-accesskey-2.0.3.tar.gz valid file.
    Download nginx-http-concat-master.tar.gz ...
    nginx-http-concat-master.tar.gz Archive found, skipping download...
    nginx-http-concat-master.tar.gz valid file.
    Download headers-more-v0.25.tar.gz ...
    headers-more-v0.25.tar.gz Archive found, skipping download...
    headers-more-v0.25.tar.gz valid file.
    Download nginx-sticky-1.2.5.tar.gz ...
    nginx-sticky-1.2.5.tar.gz Archive found, skipping download...
    nginx-sticky-1.2.5.tar.gz valid file.
    Download nginx-upstream-check-0.3.0.tar.gz ...
    nginx-upstream-check-0.3.0.tar.gz Archive found, skipping download...
    nginx-upstream-check-0.3.0.tar.gz valid file.
    pcre-8.37.tar.gz Archive found, skipping download...
    pcre-8.37.tar.gz valid file.
    Download nginx-dav-ext-module-0.0.3.tar.gz ...
    nginx-dav-ext-module-0.0.3.tar.gz Archive found, skipping download...
    nginx-dav-ext-module-0.0.3.tar.gz valid file.
    Download release-1.9.32.3-beta.tar.gz ...
    release-1.9.32.3-beta.tar.gz Archive found, skipping download...
    release-1.9.32.3-beta.tar.gz valid file.
    make sure you're using latest version of .08 beta03
  14. rdan
    6:57 AM
    sourceforge has a lot of issue recently, injecting malware/adware to some known apps like Filezilla.
    So I should stay away from them.
  15. pamamolf
    4,127
    1:57 AM
    We need a fast and stable link for Centminmod :)
    59,946
    12,556
    8:57 AM
    interesting although it shouldn't be a problem for initial install as mentioned above that source files in /downloads/svr-setup.zip are included on download initially
    i.e. centminmod/downloads at 123.08beta03 · centminmod/centminmod · GitHub
  17. pamamolf
    4,127
    1:57 AM
    Yup but it doesn't work :(
    59,946
    12,556
    8:57 AM
  19. pamamolf
    4,127
    1:57 AM
    Remind me the easy way to update centminmod please....
    59,946
    12,556
    8:57 AM
