    59,946
    12,556
    8:34 AM
    Added a new update commit fixes postfix bounce email processing for Xenforo 1.4 thanks for @Tracy Perry troubleshooting and insight sharing
    For existing Centmin Mod users, you can fix this running 2 commands in SSH
    postconf -e 'recipient_delimiter = +'
    /etc/init.d/postfix restart
    to confirm if it was set, type this command in SSH
    postconf -n | grep ^recipient_delimiter
    you should return output
    59,946
    12,556
    8:34 AM
    59,946
    12,556
    8:34 AM
  4. Andy
    Andy Active Member
    546
    90
    5:34 PM
    Just created a new server on Rackspace (1GB, Centos 7 PVHM) and run the following command.
    [root@cloud-server-01 ~]# curl -sL https://gist.github.com/centminmod/dbe765784e03bc4b0d40/raw/installer.sh | bash
    SELINUX linux detected
    disabling SELINUX...
    will require a server reboot before running initial install
    SELINUX disabled, please reboot server and rerun install
    tail: cannot open ‘/root/centminlogs/centminmod_yumtimes_*.log’ for reading: No such file or directory
    tail: cannot open ‘/root/centminlogs/*_install.log’ for reading: No such file or directory
    Created command shortcuts:
    * type cmdir to change to Centmin Mod install directory
    at /usr/local/src/centminmod-123.08centos7beta01
    * type centmin call and run centmin.sh
    at /usr/local/src/centminmod-123.08centos7beta01/centmin.sh
    59,946
    12,556
    8:34 AM
    @Andy that's normal, just do what is suggested and reboot server and rerun install :)
  6. Andy
    Andy Active Member
    546
    90
    5:34 PM
    59,946
    12,556
    8:34 AM
  8. Andy
    Andy Active Member
    546
    90
    5:34 PM
    # This file controls the state of SELinux on the system.
    # SELINUX= can take one of these three values:
    #     enforcing - SELinux security policy is enforced.
    #     permissive - SELinux prints warnings instead of enforcing.
    #     disabled - No SELinux policy is loaded.
    SELINUX=permissive
    # SELINUXTYPE= can take one of these two values:
    #     targeted - Targeted processes are protected,
    #     minimum - Modification of targeted policy. Only selected processes are protected.
    #     mls - Multi Level Security protection.
    SELINUXTYPE=targeted
    [root@cloud-server-01 ~]# sestatus
    SELinux status:                 enabled
    SELinuxfs mount:                /sys/fs/selinux
    SELinux root directory:         /etc/selinux
    Loaded policy name:             targeted
    Current mode:                   permissive
    Mode from config file:          permissive
    Policy MLS status:              enabled
    Policy deny_unknown status:     allowed
    Max kernel policy version:      28
    59,946
    12,556
    8:34 AM
  10. Sebastian B.
    Sebastian B. New Member
    25
    12:34 AM
    1.7.2
    5.5
    59,946
    12,556
    8:34 AM
    @Sebastian B. what does the contents of your /etc/yum.conf look like ?
  12. hungphutho
    hungphutho Member
    55
    35
    5:34 AM
    1.7.2
    Percona 5.6
    @Sebastian B I have the same problem on linode centos 7
    Fix
    nano /etc/resolv.conf
    add
    nameserver 8.8.8.8
    nameserver 8.8.4.4
    59,946
    12,556
    8:34 AM
    @hungphutho what does Linode CentOS have for default /etc/resolv.conf ?
    maybe I should make Centmin Mod override /etc/resolv.conf on install ?
  14. hungphutho
    hungphutho Member
    55
    35
    5:34 AM
    1.7.2
    Percona 5.6
    /etc/resolv.conf default linode
    search members.linode.com
    nameserver 106.187.34.20
    nameserver 106.187.35.20
    nameserver 106.187.36.20
  15. hungphutho
    hungphutho Member
    55
    35
    5:34 AM
    1.7.2
    Percona 5.6
    By default, Linodes use DHCP to acquire their IP address :)
    Linux Static IP Configuration - Linode Guides & Tutorials
    59,946
    12,556
    8:34 AM
    strange I have no problems with my Linode and it's assigned nameserver in /etc/resolv.conf
  17. Sebastian B.
    25
    12:34 AM
    1.7.2
    5.5
    Mine looks like:
    # Generated by NetworkManager
    domain members.linode.com
    nameserver 109.74.193.20
    nameserver 109.74.194.20
    nameserver 109.74.192.20
    options rotate
    Adding google NS after the 3 nameservers dont work. Get the same errors. Need I add it on top?
  18. hungphutho
    hungphutho Member
    55
    35
    5:34 AM
    1.7.2
    Percona 5.6
    you remove and replace
    /etc/resolv.conf My current / centos 7 linode
    # No nameservers found; try putting DNS servers into your
    # ifcfg files in /etc/sysconfig/network-scripts like so:
    # DNS1=xxx.xxx.xxx.xxx
    # DNS2=xxx.xxx.xxx.xxx
    # DOMAIN=lab.foo.com bar.foo.com
    nameserver 8.8.8.8
    nameserver 8.8.4.4
    options rotate
    options rotate
    options rotate
    options rotate
    options rotate
    options rotate
    options rotate
    options rotate
    options rotate
    options rotate
    options rotate
    options rotate
    options rotate
    options rotate
    options rotate
    59,946
    12,556
    8:34 AM
    maybe contact Linode support about CentOS 7 error you are getting :)
    also see Linux Static IP Configuration - Linode Guides & Tutorials
  20. hungphutho
    hungphutho Member
    55
    35
    5:34 AM
    1.7.2
    Percona 5.6
    I've switched to Static IP Configuration on linode
    If you want to use the Private IP / LAN IP, you must switch Static IP
