    59,946
    12,556
    8:57 AM
    just download and overwrite the zip completely
    i tried on fresh install and nginx upgrades work
    checking for psol ... found
    the configure stage
    adding module in ../ngx-fancyindex-ngx-fancyindex
    + ngx_http_fancyindex_module was configured
    adding module in ../ngx_cache_purge-2.3
    + ngx_http_cache_purge_module was configured
    adding module in ../headers-more-nginx-module-0.25
    + ngx_http_headers_more_filter_module was configured
    adding module in ../nginx-accesskey-2.0.3
    + ngx_http_accesskey_module was configured
    adding module in ../nginx-http-concat-master
    + ngx_http_concat_module was configured
    adding module in ../nginx-dav-ext-module-0.0.3
    + ngx_http_dav_ext_module was configured
    adding module in ../openresty-memc-nginx-module-1518da4
    + ngx_http_memc_module was configured
    adding module in ../openresty-srcache-nginx-module-ffa9ab7
    + ngx_http_srcache_filter_module was configured
    adding module in ../ngx_devel_kit-0.2.19
    + ngx_devel_kit was configured
    adding module in ../set-misc-nginx-module-0.28
    found ngx_devel_kit for ngx_set_misc; looks good.
    + ngx_http_set_misc_module was configured
    adding module in ../echo-nginx-module-0.57
    + ngx_http_echo_module was configured
    adding module in ../lua-nginx-module-0.9.16rc1
    checking for LuaJIT library in /usr/local/lib and /usr/local/include/luajit-2.1 (specified by the LUAJIT_LIB and LUAJIT_INC env) ... found
    checking for export symbols by default (-E) ... found
    checking for export symbols by default (--export-all-symbols) ... not found
    checking for SO_PASSCRED ... found
    + ngx_http_lua_module was configured
    adding module in ../lua-upstream-nginx-module-0.02
    + ngx_http_lua_upstream_module was configured
    adding module in ../lua-upstream-cache-nginx-module-0.1.1
    + ngx_http_lua_cache_module was configured
    adding module in ../nginx_upstream_check_module-0.3.0
    checking for ngx_http_upstream_check_module ... found
    + ngx_http_upstream_check_module was configured
    adding module in ../nginx-module-vts
    + ngx_http_vhost_traffic_status_module was configured
    adding module in ../ngx_pagespeed-release-1.9.32.3-beta
    mod_pagespeed_dir=../ngx_pagespeed-release-1.9.32.3-beta/psol/include
    build_from_source=false
    List of modules (in reverse order of applicability): ngx_http_write_filter_module ngx_http_header_filter_module ngx_http_chunked_filter_module ngx_http_spdy_filter_module ngx_http_range_header_filter_module ngx_pagespeed_etag_filter ngx_http_gzip_filter_module ngx_pagespeed ngx_http_postpone_filter_module ngx_http_ssi_filter_module ngx_http_charset_filter_module ngx_http_image_filter_module ngx_http_sub_filter_module ngx_http_addition_filter_module ngx_http_userid_filter_module
    + ngx_pagespeed was configured
    checking for zlib library ... found
    checking for GD library ... found
    checking for GeoIP library ... found
    checking for atomic_ops library ... found
    creating objs/Makefile
    Configuration summary
      + using threads
      + using PCRE library: ../pcre-8.37
      + using OpenSSL library: ../portable-2.1.6
      + md5: using OpenSSL library
      + sha1: using OpenSSL library
      + using system zlib library
      + using system libatomic_ops library
      nginx path prefix: "/usr/local/nginx"
      nginx binary file: "/usr/local/sbin/nginx"
      nginx configuration prefix: "/usr/local/nginx/conf"
      nginx configuration file: "/usr/local/nginx/conf/nginx.conf"
      nginx pid file: "/usr/local/nginx/logs/nginx.pid"
      nginx error log file: "/usr/local/nginx/logs/error.log"
      nginx http access log file: "/usr/local/nginx/logs/access.log"
      nginx http client request body temporary files: "client_body_temp"
      nginx http proxy temporary files: "proxy_temp"
      nginx http fastcgi temporary files: "fastcgi_temp"
      nginx http uwsgi temporary files: "uwsgi_temp"
      nginx http scgi temporary files: "scgi_temp"
    Tue Jun  9 16:11:17 UTC 2015
    Success: Nginx configure ok
  2. rdan
    6:57 AM
    Another new error :/
    # ./centmin.sh
    inc/downloads.inc: line 2610: cecho: command not found
    inc/downloads.inc: line 2615: http://samba.org/ftp/ccache/ccache-3.2.2.tar.gz: No such file or directory
    inc/downloads.inc: line 2618: cecho: command not found
    check Centmin Mod log for details at /root/centminlogs/
    Aborting script...
    59,946
    12,556
    8:57 AM
    honestly not sure on the nginx psol one as the file exists and nothing in the changes i did would touch that
    i see for ccache, the order of download and install and the cecho color functions needs revising
  4. rdan
    6:57 AM
    Will try this again after the above error will be fix.
    Thanks Eva!
    59,946
    12,556
    8:57 AM
    hmmm i've only tested fresh installs for the .08 beta03 latest commits heh, so need to work some stuff out for existing centmin mod installed instances - problem for ccache at least stems from needing to auto detect and switch from ccache 3.1.9 yum install at /usr/bin/ccache to upgrading to ccache 3.2.2 via source compile at /usr/local/bin/ccache. For some reason ccache tarball is getting downloaded to centmin mod base install directory instead of /svr-setup
    edit: okay fixed that part at least for ccache update inc/ccache.inc fix download directory path · centminmod/centminmod@284f783 · GitHub
    59,946
    12,556
    8:57 AM
  7. rdan
    6:57 AM
    OK, Thanks :)
    BRB.
  8. rdan
    6:57 AM
    Wow, fixed now. :)
    Upgrading Nginx now.
  9. rdan
    6:57 AM
    Same error :/
  10. rdan
    6:57 AM
    This is, CentOS release 6.6 (Final) x86
    Kernel 2.6.32-504.16.2.el6.i686
  11. rdan
    6:57 AM
    59,946
    12,556
    8:57 AM
    can you post to gist/pastebin the contents of /svr-setup/nginx-1.9.1/objs/autoconf.err
  13. rdan
    6:57 AM
  14. rdan
    6:57 AM
    File itself,
    59,946
    12,556
    8:57 AM
    looks like there's problems with clang compiler and ngx_pagespeed's psol - might be a 32bit thing as i have no probs with 64bit os if you search that gist file for
    checking for psol
    you can find the start of the reported errors
    e.g.
    checking for psol
    /tmp/autotest-c5f76d.o: In function `_Alloc_hider':
    /usr/bin/../lib/gcc/i686-redhat-linux/4.4.7/../../../../include/c++/4.4.7/bits/basic_string.h:260: undefined reference to `std::string::_Rep::_S_empty_rep_storage'
    /tmp/autotest-c5f76d.o: In function `std::string::_M_rep() const':
    /usr/bin/../lib/gcc/i686-redhat-linux/4.4.7/../../../../include/c++/4.4.7/bits/basic_string.h:232: undefined reference to `std::string::_Rep::_S_empty_rep_storage'
    /usr/bin/../lib/gcc/i686-redhat-linux/4.4.7/../../../../include/c++/4.4.7/bits/basic_string.h:236: undefined reference to `std::string::_Rep::_M_destroy(std::allocator<char> const&)'
    /tmp/autotest-c5f76d.o: In function `__clang_call_terminate':
    objs/autotest.cc:(.text.__clang_call_terminate[__clang_call_terminate]+0xb): undefined reference to `__cxa_begin_catch'
    objs/autotest.cc:(.text.__clang_call_terminate[__clang_call_terminate]+0x10): undefined reference to `std::terminate()'
    /tmp/autotest-c5f76d.o: In function `__cxx_global_var_init':
    /usr/bin/../lib/gcc/i686-redhat-linux/4.4.7/../../../../include/c++/4.4.7/iostream:72: undefined reference to `std::ios_base::Init::Init()'
    /usr/bin/../lib/gcc/i686-redhat-linux/4.4.7/../../../../include/c++/4.4.7/iostream:72: undefined reference to `std::ios_base::Init::~Init()'
    /tmp/autotest-c5f76d.o:(.eh_frame+0x13): undefined reference to `__gxx_personality_v0'
    ../ngx_pagespeed-release-1.9.32.3-beta/psol/lib/Release/linux/ia32/pagespeed_automatic.a(88.message_handler.o.o): In function `net_instaweb::MessageHandler::Format(char const*, char*)':
    might have to make clang a 64bit only option to confirm this
    59,946
    12,556
    8:57 AM
    59,946
    12,556
    8:57 AM
    @RoldanLT if you or anyone else doing tests have a 64bit CentOS test server, would be nice to confirm if clang and psol issues are 32bit specific :)
    59,946
    12,556
    8:57 AM
    @RoldanLT for your 32bit instance, can you also try deleting existing ngx_pagespeed downloads in /svr-setup and then run centmin.sh menu option 4 to upgrade/recompile Nginx
    rm -rf /svr-setup/ngx_pagespeed-release*
    rm -rf /svr-setup/release-1.9.32*
  19. rdan
    6:57 AM
    Same error Eva :sick:
    59,946
    12,556
    8:57 AM
