    59,946
    12,556
    8:34 AM
    yeah well I fixed it :D
    below times still with usual gcc compiler.. haven't actually switched to clang yet - only done tests privately/locally with great promise :D
    Total YUM Time: 271.613082289 seconds
    Total Source Download Time: 285.316644271 seconds
    Total Nginx First Time Install Time: 322.812503205 seconds
    Total PHP First Time Install Time: 123.437383170 seconds
    Total Centmin Mod Install Time: 914.826975513 seconds
    * Post-Install Check List....
    Check ccache Version:
    ccache version 3.2.2
    Copyright (C) 2009-2015 Joel Rosdahl
    version.
    Check Nginx Version:
    nginx version: nginx/1.9.1
    built by gcc 4.4.7 20120313 (Red Hat 4.4.7-11) (GCC)
    built with OpenSSL 1.0.2a 19 Mar 2015
    TLS SNI support enabled
    configure arguments: --with-ld-opt='-ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib' --with-cc-opt='-m64 -mtune=native -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_ssl_module --with-http_gzip_static_module --with-http_stub_status_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module --with-http_secure_link_module --with-http_flv_module --with-http_realip_module --with-http_geoip_module --with-openssl-opt=enable-tlsext --add-module=../ngx-fancyindex-ngx-fancyindex --add-module=../ngx_cache_purge-2.3 --add-module=../headers-more-nginx-module-0.25 --add-module=../nginx-accesskey-2.0.3 --add-module=../nginx-http-concat-master --with-http_dav_module --add-module=../nginx-dav-ext-module-0.0.3 --add-module=../openresty-memc-nginx-module-1518da4 --add-module=../openresty-srcache-nginx-module-ffa9ab7 --add-module=../ngx_devel_kit-0.2.19 --add-module=../set-misc-nginx-module-0.28 --add-module=../echo-nginx-module-0.57 --add-module=../lua-nginx-module-0.9.16rc1 --add-module=../lua-upstream-nginx-module-0.02 --add-module=../lua-upstream-cache-nginx-module-0.1.1 --add-module=../nginx_upstream_check_module-0.3.0 --add-module=../nginx-module-vts --with-openssl=../openssl-1.0.2a --with-libatomic --with-threads --with-stream --with-stream_ssl_module --with-pcre=../pcre-8.37 --with-pcre-jit --with-http_spdy_module --add-module=../ngx_pagespeed-release-1.9.32.3-beta
    Check PHP-FPM Version:
    PHP 5.4.41 (cli) (built: Jun  9 2015 09:14:05)
    MariaDB-common-10.0.19-1.el6.x86_64
    MariaDB-server-10.0.19-1.el6.x86_64
    MariaDB-compat-10.0.19-1.el6.x86_64
    MariaDB-shared-10.0.19-1.el6.x86_64
    MariaDB-client-10.0.19-1.el6.x86_64
    MariaDB-devel-10.0.19-1.el6.x86_64
    memcached 1.4.24
    Check CSF Firewall Version:
    csf: v7.69 (generic)
    SIEGE 3.1.0
    Copyright (C) 2015 by Jeffrey Fulmer, et al.
    FOR A PARTICULAR PURPOSE.
    pscontrol admin
    pscontrol handler
    pscontrol edit
    pscontrol on
    pscontrol off
    pscontrol statson
    pscontrol statsoff
    Check mysqlreport version:
    Check NSD Bind Version:
    NSD version 3.2.18
    Written by NLnet Labs.
    Check pure-ftpd Version:
    pure-ftpd v1.0.30
    Check YUM Repo List
    Loaded plugins: downloadonly, fastestmirror, priorities, security
    * base: centos.mirrors.hoobly.com
    * epel: mirror.sfo12.us.leaseweb.net
    * extras: mirror.chpc.utah.edu
    * rpmforge: mirror.webnx.com
    * updates: mirror.1stclasshosting.com
    1607 packages excluded due to repository priority protections
    repo id         repo name                                            status
    base            CentOS-6 - Base                                      4,952+1,566
    epel            Extra Packages for Enterprise Linux 6 - x86_64       8,764+2,848
    extras          CentOS-6 - Extras                                             38
    mariadb         MariaDB                                                     12+5
    rpmforge        RHEL 6 - RPMforge.net - dag                          3,197+1,521
    updates         CentOS-6 - Updates                                       881+274
    vz-base         vz-base                                                        3
    vz-updates      vz-updates                                                   2+6
    repolist: 17,849
    59,946
    12,556
    8:34 AM
    testing Nginx compiled using clang instead of gcc
    59,946
    12,556
    8:34 AM
    Created a new experimental beta branch - merging 123.08beta03libressl + 123.08beta03clang to create 123.08beta03-libresslclang which is basically Nginx compilation defaulting to LibreSSL instead of OpenSSL 1.0.2a + switching from gcc compiler to clang compiler. So Nginx compile time is sped up from LibreSSL's support of parallel make + speed from clang being faster than gcc.
    The result is very nice improvement in install times from ~900-914 seconds to ~775 seconds or Nginx first time install from 322 seconds down to 202 seconds = 120 seconds faster :D
    Total YUM Time: 259.985710180 seconds
    Total Source Download Time: 274.436665805 seconds
    Total Nginx First Time Install Time: 202.205311094 seconds
    Total PHP First Time Install Time: 120.040153161 seconds
    Total Centmin Mod Install Time: 775.525732588 seconds
    version.
    built with LibreSSL 2.1.6
    configure arguments: --with-ld-opt='-lrt -ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib' --with-cc-opt='-m64 -mtune=native -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -Wno-deprecated-declarations -Wno-unused-parameter -Wno-unused-const-variable -Wno-conditional-uninitialized -Wno-mismatched-tags -Wno-c++11-extensions -Wno-sometimes-uninitialized -Wno-parentheses-equality -Wno-tautological-compare -Wno-self-assign' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_ssl_module --with-http_gzip_static_module --with-http_stub_status_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module --with-http_secure_link_module --with-http_flv_module --with-http_realip_module --with-http_geoip_module --with-openssl-opt=enable-tlsext --add-module=../ngx-fancyindex-ngx-fancyindex --add-module=../ngx_cache_purge-2.3 --add-module=../headers-more-nginx-module-0.25 --add-module=../nginx-accesskey-2.0.3 --add-module=../nginx-http-concat-master --with-http_dav_module --add-module=../nginx-dav-ext-module-0.0.3 --add-module=../openresty-memc-nginx-module-1518da4 --add-module=../openresty-srcache-nginx-module-ffa9ab7 --add-module=../ngx_devel_kit-0.2.19 --add-module=../set-misc-nginx-module-0.28 --add-module=../echo-nginx-module-0.57 --add-module=../lua-nginx-module-0.9.16rc1 --add-module=../lua-upstream-nginx-module-0.02 --add-module=../lua-upstream-cache-nginx-module-0.1.1 --add-module=../nginx_upstream_check_module-0.3.0 --add-module=../nginx-module-vts --with-openssl=../portable-2.1.6 --with-libatomic --with-threads --with-stream --with-stream_ssl_module --with-pcre=../pcre-8.37 --with-pcre-jit --with-http_spdy_module --add-module=../ngx_pagespeed-release-1.9.32.3-beta
    PHP 5.4.41 (cli) (built: Jun  9 2015 12:02:51)
    memcached 1.4.24
    SIEGE 3.1.0
    pscontrol admin
    pscontrol handler
    pscontrol edit
    pscontrol on
    pscontrol off
    pscontrol statson
    pscontrol statsoff
    NSD version 3.2.18
    pure-ftpd v1.0.30
    Check YUM Repo List
    * base: mirror.lax.hugeserver.com
    * extras: mirrors.kernel.org
    * updates: mirrors.kernel.org
    vz-base         vz-base                                                        3
    repolist: 17,849
    slightly faster when switching LibreSSL compile from gcc to clang too
    Total YUM Time: 247.231576863 seconds
    Total Source Download Time: 265.909223715 seconds
    Total Nginx First Time Install Time: 186.191045374 seconds
    Total PHP First Time Install Time: 121.413174882 seconds
    Total Centmin Mod Install Time: 757.018868253 seconds
    disabling LibreSSL make check shaved off another 36 seconds :D
    Total YUM Time: 241.718806246 seconds
    Total Source Download Time: 259.387719680 seconds
    Total Nginx First Time Install Time: 163.796472260 seconds
    Total PHP First Time Install Time: 120.822582486 seconds
    Total Centmin Mod Install Time: 721.978282063 seconds
    59,946
    12,556
    8:34 AM
    Merged 123.08beta03-libresslclang branch into official 123.08beta03 branch so everyone can have some fun beta testing the much faster install and more secure Nginx compiled with LibreSSL by default with chacha20_poly1305 cipher support natively included in LibreSSL :D
    June 10th commits Commits · centminmod/centminmod · GitHub
    test it guys !!! see if we can be on track for .08 stable release by end of this month :D
  5. rdan
    6:34 AM
    Surely I will use this on my main server :)
    59,946
    12,556
    8:34 AM
    might want to do some tests on a test server first :D ;)
  7. rdan
    6:34 AM
    Yes, doing this on my Ramnode VPS now :)
  8. rdan
    6:34 AM
    I think this is a problem?
    59,946
    12,556
    8:34 AM
    nah those errors can be ignored
    ${CUR_DIR} & ${CM_INSTALLDIR}
    /usr/local/src/centmin-v1.2.3mod
    inc/ccache.inc: line 10: cd: ccache-3.2.2/: No such file or directory
    make: *** No rule to make target `clean'. Stop.
    inc/ccache.inc: line 12: ./configure: No such file or directory
    make: *** No targets specified and no makefile found. Stop.
    make: *** No rule to make target `install'. Stop.
    but i'll fix it up in a minute :)
  10. rdan
    6:34 AM
    59,946
    12,556
    8:34 AM
    59,946
    12,556
    8:34 AM
  13. rdan
    6:34 AM
    No.
    I have this:
    NGINX_PAGESPEED=y # Install ngx_pagespeed
    NGINX_PAGESPEEDGITMASTER=n # Install ngx_pagespeed from official github master instead
    NGXPGSPEED_VER='1.9.32.3-beta'
    NGINX_PAGESPEEDPSOL_VER='1.9.32.3'
    59,946
    12,556
    8:34 AM
    okay i see the problem for ccache part, not quite ready for existing install upgrades.. the latest commits are for fresh installs first
    as to nginx failed upgrade,
    checking for psol ... not found
    ./configure: error: module ngx_pagespeed requires the pagespeed optimization library.
    Look in objs/autoconf.err for more details.
    psol didn't download.. try again and see
  15. rdan
    6:34 AM
    I need to grab the latest code from github?
    59,946
    12,556
    8:34 AM
    Can you first list contents of /svr-setup/ngx_pagespeed-release-1.9.32.3-beta/
    1.9.32.3.tar.gz = psol download
    ls -lah /svr-setup/ngx_pagespeed-release-1.9.32.3-beta/
    total 108M
    drwxrwxr-x  6 root   root 4.0K Jun  9 15:39 .
    drwxr-xr-x 60 root   root  12K Jun  9 15:46 ..
    -rw-rw-r--  1 root   root   30 Dec 22 15:10 .gitignore
    -rw-r--r--  1 root   root 108M Jan  6 22:00 1.9.32.3.tar.gz
    -rw-rw-r--  1 root   root  12K Dec 22 15:10 LICENSE
    -rw-rw-r--  1 root   root 1.5K Dec 22 15:10 README.md
    -rw-rw-r--  1 root   root 7.2K Dec 22 15:10 config
    -rw-rw-r--  1 root   root 2.9K Dec 22 15:10 cpp_feature
    drwxr-x---  4 245878 5000 4.0K Dec 22 15:03 psol
    drwxrwxr-x  2 root   root 4.0K Dec 22 15:10 scripts
    drwxrwxr-x  2 root   root 4.0K Dec 22 15:10 src
    drwxrwxr-x  2 root   root 4.0K Dec 22 15:10 test
  17. rdan
    6:34 AM
    I mean here:
    59,946
    12,556
    8:34 AM
    strange it looks like it exists... try updating to latest .08 beta03 i made some adjustments for ccache on upgrade releases might be related
  19. rdan
    6:34 AM
  20. rdan
    6:34 AM
    I just did:
    rm -rf /svr-setup/*
    Then re run menu 4 now.
    Same error.
