  1. Oxide
    Oxide Active Member
    534
    29
    8:34 AM
    I can't wait to get lua module on my server now, however is this CentOS 7+ only, not 6?
    59,946
    12,556
    8:34 AM
  3. Oxide
    Oxide Active Member
    534
    29
    8:34 AM
    Ok, just referering to the tag you made here.
    If i were to re-install the server with the latest Centmin version. What would you suggest me to choose, in matter of OS?
    I have 2GB Ram & 8 Cores.
    59,946
    12,556
    8:34 AM
    This is still beta for .08 beta 03 so for peace of mine CentOS 6.6 is a safer bet. CentOS 7.1 if you're adventerous and don't mind troubleshooting issues more often and more updates for centmin mod. But yes CentOS 7.1 performs better than CentOS 6.6
    Simple fact is CentOS 7.1 and Centmin Mod stability is tied into how much testing and feedback folks give during this beta testing phase ;)
  5. Oxide
    Oxide Active Member
    534
    29
    8:34 AM
    I'm more of a user, and hate when errors appears (panic attack).
    In other words, CentOS 6 should be more stable with Centminmod?
    When do you think centmin lua modules etc will be out of BETA? or is it ok to use them for a live site now
    59,946
    12,556
    8:34 AM
    yes CentOS 6 more stable as CentOS 7.x has too many drastic system changes under the hood so only time will tell what else comes up.
    Everything in .08 beta03 is beta so treat it as such - point of beta is to test and report bugs :) So whether you use it on live site is up to you :)
    59,946
    12,556
    8:34 AM
    59,946
    12,556
    8:34 AM
    Added tools/gitsetup.sh which just automates the steps outlined at Upgrade - Working with git command line for updating Centmin Mod local copies to switch centmin mod locally installed code base to one that is maintained via git command line
    example of output
    cd /usr/local/src/centminmod-123.08beta03/tools
    chmod +x gitsetup.sh
    ./gitsetup.sh
    setup Centmin Mod git sourced install...
    download github.com centmin mod 123.08beta03 branch repo
    Cloning into 'centminmod-123.08beta03'...
    remote: Counting objects: 3811, done.
    remote: Compressing objects: 100% (83/83), done.
    remote: Total 3811 (delta 43), reused 0 (delta 0), pack-reused 3726
    Receiving objects: 100% (3811/3811), 959.69 KiB | 273.00 KiB/s, done.
    Resolving deltas: 100% (2672/2672), done.
    Branch 123.08beta03 set up to track remote branch 123.08beta03 from origin.
    Switched to a new branch '123.08beta03'
    list all available local branches
            git branch -a
    * 123.08beta03
      master
      remotes/origin/123.06stable
      remotes/origin/123.07stable
      remotes/origin/123.08beta03
      remotes/origin/123.08centos7beta01
      remotes/origin/123.08centos7beta02
      remotes/origin/123.08livestats
      remotes/origin/123.08lua
      remotes/origin/123.08zerodown
      remotes/origin/HEAD -> origin/master
      remotes/origin/master
    list git log last commit
            git log -a
    commit 2d41a72a7de261ba0b792bf19eb526a382ea1b57
    Author: George Liu <EMAIL>
    Date:   Sun May 31 14:19:14 2015 +1000
        switch cmdir command shortcut back to using alias cmd
    to update centmin mod 123.08beta03 branch repo via git
            git stash
            git pull
            chmod +x centmin.sh
    59,946
    12,556
    8:34 AM
    coming soon I hope - centmin.sh menu option 23 = Update Centmin Mod Code Base (via git) :)
                       Centmin Mod Menu
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    11). MariaDB 5.2, 5.5, 10, 10.1 Upgrade Sub-Menu
    14). SELinux disable
    16). Change SSHD Port Number
    20). NSD Re-install
    24). Exit
    Enter option [ 1 - 24 ] 23
            Centmin Mod Updater Sub-Menu
    1). Setup Centmin Mod Github Environment
    2). Update Centmin Mod Current Branch
    3). Update Centmin Mod Newer Branch
    4). Back to Main menu
    Enter option [ 1 - 4 ]
    submenu option 1 setup github local environment
    Enter option [ 1 - 4 ] 1
            git branch -a
    * 123.08beta03
      master
            git log -a
    commit 0a14b23ee0ec2c7787bdfc6befd58d5fb13475dd
    Date:   Sun May 31 14:40:29 2015 +1000
        add tools/gitsetup.sh to automate steps to switch to git updated code base
        https://community.centminmod.com/threads/working-with-git-command-line-for-updating-centmin-mod-local-copies.2150/
            git stash
            git pull
            chmod +x centmin.sh
    if you try submenu option 2 and you haven't done submenu option 1 yet
    Enter option [ 1 - 4 ] 2
    Error: you do not have git environment setup for github based updates
           run submenu option 1 to setup github environment first
    switching to a new github branch via submenu option 3
    Enter option [ 1 - 4 ] 3
    Update Centmin Mod to newer branch via git
    You need to input the name of the branch
    List of current remote branches by descending date order
    2015-05-31 16:54:41 +1000 4 minutes ago 123.08beta03updater
    2015-05-31 14:40:29 +1000 2 hours ago   123.08beta03
    2015-05-29 20:22:39 +1000 2 days ago    master
    2015-05-28 21:20:39 +1000 3 days ago    123.08livestats
    2015-05-28 15:29:07 +1000 3 days ago    123.08lua
    2015-05-27 15:54:13 +1000 4 days ago    123.08centos7beta02
    2015-05-17 19:25:36 +1000 2 weeks ago   123.07stable
    2015-05-12 00:44:49 +1000 3 weeks ago   123.08centos7mongodb
    2015-05-08 03:36:57 +1000 3 weeks ago   123.08centos7setmisc
    2015-04-13 12:00:17 +1000 7 weeks ago   123.08centos7beta02wp
    2015-04-07 12:33:43 +1000 8 weeks ago   123.08centos6beta02redis
    2015-04-04 05:50:25 +1000 8 weeks ago   123.07stable-fixes
    2015-03-25 03:45:39 +1000 10 weeks ago  123.08zerodown
    2015-03-10 16:52:48 +1000 3 months ago  123.08geoip
    2015-03-10 16:52:37 +1000 3 months ago  123.08centos7beta01
    2015-02-24 22:19:38 +1000 3 months ago  123.07stable_intel
    2015-02-02 00:51:34 +1000 4 months ago  123.08slowfs
    2014-06-23 17:08:44 +1000 11 months ago 123.06stable
    Enter the branch name you want to switch to i.e. 123.08beta03 : 123.08beta03
    dedicated discussion thread at CentOS 7.x - New .08 beta menu option - updating Centmin Mod via git | Centmin Mod Community
  10. Cr0w
    Cr0w Member
    165
    9
    Iran
    2:04 AM
    1.9.x
    5.5
    Greaaaaaaaaaaaaaaaaaaaat , You are my Master George , thanks :D
    its a amazing option and i really need this , thanks :punch:
    59,946
    12,556
    8:34 AM
    59,946
    12,556
    8:34 AM
    Updated .08 beta 03 with some June 1 commits including adding additional time recordings for source downloads and first time initial nginx installation. This is so I can benchmark and improve install times Commits · centminmod/centminmod · GitHub
    cd /root/centminlogs
    tail -1 centminmod_ngxinstalltime_010615-085814.log
    Total Nginx First Time Install Time: 323.873886952 seconds
    tail -1 centminmod_downloadtimes_010615-085814.log
    Total Source Download Time: 314.803762889 seconds
    tail -1 centminmod_yumtimes_010615-085814.log
    Total YUM Time: 303.042528310 seconds
    tail -1 centminmod_1.2.3-eva2000.08_010615-085814_install.log
    Total Centmin Mod Install Time: 911.139768268 seconds
    might have messed something up, so might want to hold off for 24hrs before trying .08 beta03 install as getting some errors on post install check
    inc/centminfinish.inc: line 45: /usr/local/bin/memcached: No such file or directory
    Check CSF Firewall Version:
    inc/centminfinish.inc: line 51: csf: command not found
    inc/centminfinish.inc: line 58: siege: command not found
    weird something is causing centmin.sh to skip the install progress for only memcached, csf and siege !
    59,946
    12,556
    8:34 AM
    okay fixed csf, memcached and siege installs
    note sure why download source times so long though as i have now bundled in downloads/svr-setup.zip most of the source required packages (ok ccache yum install is included in those source download times so could be it)
    these times only show up with method 2 or 3 installs outlined in 1st post.
    Total YUM Time: 303.990078889 seconds
    Total Source Download Time: 314.983260884 seconds
    Total Centmin Mod Install Time: 966.573120914 seconds
    tail -1 centminlogs/centminmod_ngxinstalltime_010615-104356.log
    Total Nginx First Time Install Time: 318.100219997 seconds
    * Post-Install Check List....
    Check ccache Version:
    ccache version 3.1.6
    Copyright (C) 2009-2011 Joel Rosdahl
    version.
    Check Nginx Version:
    nginx version: nginx/1.9.1
    built by gcc 4.4.7 20120313 (Red Hat 4.4.7-11) (GCC)
    built with OpenSSL 1.0.2a 19 Mar 2015
    TLS SNI support enabled
    configure arguments: --with-ld-opt=-Wl,-rpath,/usr/local/lib --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_ssl_module --with-http_gzip_static_module --with-http_stub_status_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module --with-http_secure_link_module --with-http_flv_module --with-http_realip_module --with-http_geoip_module --with-openssl-opt=enable-tlsext --add-module=../ngx-fancyindex-ngx-fancyindex --add-module=../ngx_cache_purge-2.3 --add-module=../headers-more-nginx-module-0.25 --add-module=../nginx-accesskey-2.0.3 --add-module=../nginx-http-concat-master --with-http_dav_module --add-module=../nginx-dav-ext-module-0.0.3 --add-module=../openresty-memc-nginx-module-1518da4 --add-module=../openresty-srcache-nginx-module-ffa9ab7 --add-module=../ngx_devel_kit-0.2.19 --add-module=../set-misc-nginx-module-0.28 --add-module=../echo-nginx-module-0.57 --add-module=../lua-nginx-module-0.9.16rc1 --add-module=../lua-upstream-nginx-module-0.02 --add-module=../lua-upstream-cache-nginx-module-0.1.1 --add-module=../nginx_upstream_check_module-0.3.0 --add-module=../nginx-module-vts --with-openssl=../openssl-1.0.2a --with-libatomic --with-threads --with-stream --with-stream_ssl_module --with-pcre=../pcre-8.37 --with-pcre-jit --with-http_spdy_module --add-module=../ngx_pagespeed-release-1.9.32.3-beta
    Check PHP-FPM Version:
    PHP 5.4.41 (cli) (built: Jun  1 2015 14:57:05)
    MariaDB-compat-10.0.19-1.el6.x86_64
    MariaDB-shared-10.0.19-1.el6.x86_64
    MariaDB-common-10.0.19-1.el6.x86_64
    MariaDB-client-10.0.19-1.el6.x86_64
    MariaDB-server-10.0.19-1.el6.x86_64
    MariaDB-devel-10.0.19-1.el6.x86_64
    memcached 1.4.24
    csf: v7.69 (generic)
    SIEGE 3.0.9
    Copyright (C) 2014 by Jeffrey Fulmer, et al.
    FOR A PARTICULAR PURPOSE.
    pscontrol admin
    pscontrol handler
    pscontrol edit
    pscontrol on
    pscontrol off
    pscontrol statson
    pscontrol statsoff
    Check mysqlreport version:
    Check NSD Bind Version:
    NSD version 3.2.18
    Written by NLnet Labs.
    Check pure-ftpd Version:
    pure-ftpd v1.0.30
    Check YUM Repo List
    Loaded plugins: downloadonly, fastestmirror, priorities, security
    * base: centos.mirror.ndchost.com
    * epel: mirror.hmc.edu
    * extras: mirror.hmc.edu
    * rpmforge: mirror.webnx.com
    * updates: mirror.hostduplex.com
    1605 packages excluded due to repository priority protections
    repo id         repo name                                            status
    base            CentOS-6 - Base                                      4,952+1,566
    epel            Extra Packages for Enterprise Linux 6 - x86_64       8,740+2,833
    extras          CentOS-6 - Extras                                             38
    mariadb         MariaDB                                                     12+5
    rpmforge        RHEL 6 - RPMforge.net - dag                          3,199+1,519
    updates         CentOS-6 - Updates                                       875+272
    vz-base         vz-base                                                        3
    vz-updates      vz-updates                                                   2+6
    repolist: 17,821
    edit: hmm spoke too soon
    service memcached status
    memcached: unrecognized service
    edit fixed memcached init.d setup at update inc/memcached_install.inc · centminmod/centminmod@3a36ea0 · GitHub another side affect of downloads profile timing and some variables being skipped
    59,946
    12,556
    8:34 AM
    on a roll with centmin mod .08 beta03 updates for June 2, 2015 Commits · centminmod/centminmod · GitHub
    times don't seem to add up though > 956s i think the system timezone changes later in centmin mod install might have some affect ?
    Total YUM Time: 296.284933915 seconds
    Total Source Download Time: 311.721833809 seconds
    Total Nginx First Time Install Time: 326.078525220 seconds
    Total PHP First Time Install Time: 121.114101306 seconds
    Total Centmin Mod Install Time: 956.416774540 seconds
    verifying nginx is now using jemalloc for memory management
    lsof -n | grep jemalloc
    nginx      5896    root  mem       REG         182,565105    210024     535012 /usr/lib64/libjemalloc.so.1
    nginx      5897   nginx  mem       REG         182,565105    210024     535012 /usr/lib64/libjemalloc.so.1
    nginx      5898   nginx  mem       REG         182,565105    210024     535012 /usr/lib64/libjemalloc.so.1
    Wordpress 7 site is first site to switch to .08 beta03's latest Nginx configuration and working vhost traffic stats :)
    59,946
    12,556
    8:34 AM
  16. pamamolf
    4,127
    1:34 AM
    Do we have to do any changes if we use a key file created by Puttygen to authenticate as if i am not wrong the creation is related to Openssh?
  17. rdan
    6:34 AM
    Not related at all.
    59,946
    12,556
    8:34 AM
    no the change for LibreSSL is only for Nginx's support of SSL for SSL certificates/https
    59,946
    12,556
    8:34 AM
    June 9th commit bugs
    Just heads up seem somewhere in my commits today (June 9th) Commits · centminmod/centminmod · GitHub I might have introduced a bug for when using curl one liner Centmin Mod installs.. the $CUR_DIR variable in centmin.sh which determines where the downloaded Centmin Mod zip file's extracted path seems to get overridden so some files don't end up where they're suppose to me i.e. /etc/init.d/nginx start/stop script ends up missing.
    Looking into it now :eek: :)
    Background for June 9th Commits
    It all started when i added clang compiler support as an alternative to gcc clang support · centminmod/centminmod@13cb474 · GitHub as it potentially is faster for compiling via source i.e. nginx can be up to 120 seconds faster. However, needed to update ccache 3.2.2 (from 3.1.9) for clang so that's where the bug was introduced as ccache was previously installed via YUM EPEL repo but 3.2.2 is only available via source compile so switched to ccache 3.2.2 via source compile :)
    Fixed
    I believe I found a permanent fix to the introduced bug above update centmin.sh for .08 beta03 · centminmod/centminmod@abdaa39 · GitHub :)
  20. Steve Tozer
    Steve Tozer Member
    70
    42
    South Wales, UK
    11:34 PM
    1.91
    10.0.19
    I like a bit of testing for bugs, from time to time ;)
