    59,946
    12,556
    8:11 AM
    test server is basically same as non-test server. Set up 1 and then do same steps to setup another :)
    I doubt updating Centmin Mod was the cause of high cpu loads given what you explained. See my reply at My service got suspended due CMM updates | Centmin Mod Community
  2. sepulchre
    sepulchre Member
    168
    22
    12:11 AM
    Yeah, but then this poor student needs to spend another penny for a VPS, which of course must have at least 2gb... :p
    And then you must have the time to work on 2 servers... And so on. I am playing it safe :D
    This is exactly what I did. Literally. Used that codes and used the menu only, no other commands or file edits.
    But I remembered later, I forgot to mention during that time, I installed 1 Xenforo add-on which deals with Caching, see bd Cache..
    So, yeah, it might be that. But this is all I did. Anyway, now is everything fine again. (will respond to you on my thread, too)
    59,946
    12,556
    8:11 AM
    Virtualbox Oracle VM VirtualBox is free to download and use and you install it on your own local PC. Think of it has having VPS guest servers you can create and destroy on your own local pc. You can install any linux os in isolation as guest servers. Example of CentOS 7.0 install on Virtualbox CentOS 7.x - CentOS 7.0 Install on VirtualBOX Guest Server | Centmin Mod Community Virtualbox uses snapshots to save guest server states as backups, so you can revert to a previous state so if you mess up, just revert the snapshot.
    example from my CentOS 7 testing
  4. AlekseY
    AlekseY Member
    47
    1:11 AM
    59,946
    12,556
    8:11 AM
    the answer is in the log
    [WARNING] Sorry, cleartext sessions are not accepted on this server.
    pure-ftpd setup i made requires Explicit TLS/SSL enabled with PASV enabled. What FTP client you using ? try filezilla as per images and instructions posted at Centmin Mod .08 beta + pure-ftpd virtual FTP user support | Centmin Mod Community (at bottom of first post there's also a list under Compatible FTP clients for SSL/TLS for compatible FTP clients as not all FTP clients are compatible)
    Using Filezilla FTP Client with FTP Explicit TLS/SSL
    Transfer mode = Passive
  6. AlekseY
    AlekseY Member
    47
    1:11 AM
    eva2000,
    Yummy FTP for Mac
    chose SSL/TSL.
    does not work ((
    through client Filezila - OK
  7. Sebastian B.
    Sebastian B. New Member
    25
    12:11 AM
    1.7.2
    5.5
    Still the build brakes my virtual machines.
    HOSTS(RAM): KVM(1GB), ESXI(1GB, 10GB)
    Before I started to install Centminmod I made a fresh install of Centos 7.1 (and 7.0) and updatet it. I serval times reboted it to be sure its after the CMM install. After the installation I reboot the machine and I end in the rescue mode with the error (2.1836 EXT4-fs (loop0): VFS: Can'T find ext4 filesystem). I tried this serval times always the same. The interesting part is if I give the same vm more ram (about 10GB I tested) CMM works like a charm. So I assume its something with the memcache or this would be my first path to look at
    59,946
    12,556
    8:11 AM
    That info is useful it might be related to lines 731-742 of centmin.sh for centos 7.x - with less than 2GB of memory, centmin.sh attempts to create a 2GB disk based /tmp disk. But CentOS 7 after centmin mod install occupies ~7.5GB of disk space. So that's 9.5GB total. You have 10GB KVM so probably run out of disk space. Try creating KVM instances with minimum 16GB disk space and a see.
    Lines 708-718 of centmin.sh, allows for >8GB memory detection which instead of 2GB disk based /tmp, creates tmpfs ram disk based /tmp so that is why when you raise to 10GB memory, you do not have problems
  9. Sebastian B.
    25
    12:11 AM
    1.7.2
    5.5
    No its just Ram. The machine got enough diskspace that should not be the problem (about 50GB)
    59,946
    12,556
    8:11 AM
    problem is VM disk free space not host system disk free space. Have you actually tried with 16GB disk sized VM yet ?
    I updated .08 beta 02 CentOS 7 Beta Branch - update centmin.sh /tmp creation routine for .08 beta | Centmin Mod Community with also a 1GB memory detection routine for a 1GB /tmp on disk as being smallest size instead of 2GB /tmp on disk for <2GB memory detection. That would give 7.5+1 = ~8.5GB used disk space in theory instead of 9.5GB.
    you can also try these on 1GB VM the following commands manually and post the output and errors you get at each step/cmd
           rm -rf /tmp
           dd if=/dev/zero of=/home/usertmp_donotdelete bs=1024 count=1000000
           echo Y | mkfs.ext4 /home/usertmp_donotdelete
           mkdir -p /tmp
           mount -t ext4 -o loop,rw,noexec,nosuid /home/usertmp_donotdelete /tmp
           chmod 1777 /tmp
           echo "/home/usertmp_donotdelete /tmp ext4 loop,rw,noexec,nosuid 0 0" >> /etc/fstab
           rm -rf /var/tmp
           ln -s /tmp /var/tmp
    could be related to mount with -o loop
    also output from these 2 commands
    losetup -f
    losetup -a
    also what kernel you using ?
    uname -r
    also check these 2 commands
    yum -y install virt-what
    virt-what
  11. sannin
    sannin New Member
    14
    8:11 AM
    1.7.3
    MariaDB 10
    Hey, i am getting this error while trying to install:
    inflating: centminmod-123.08centos7beta02/tools/centminmod_packager.sh
    inflating: centminmod-123.08centos7beta02/tools/cminfo.sh
    inflating: centminmod-123.08centos7beta02/tools/cmupdate.sh
    ./centmin.sh: line 758: syntax error near unexpected token `fi'
    ./centmin.sh: line 758: `fi'
    tail: cannot open ‘/root/centminlogs/centminmod_yumtimes_*.log’ for reading: No such file or directory
    tail: cannot open ‘/root/centminlogs/*_install.log’ for reading: No such file or directory
    Created command shortcuts:
    * type cmdir to change to Centmin Mod install directory
    at /usr/local/src/centminmod-123.08centos7beta02
    * type centmin call and run centmin.sh
    at /usr/local/src/centminmod-123.08centos7beta02/centmin.sh
    59,946
    12,556
    8:11 AM
    good to wrap output in CODE tags in future ;)
    fixed the typo and updated .08 beta 02 update centmin.sh fix misplaced curly bracket for .08 beta · centminmod/centminmod@637e629 · GitHub misplaced curly brace from previous update update /tmp creation routine in centmin.sh correct log path · centminmod/centminmod@2c1502b · GitHub :)
  13. Sebastian B.
    25
    12:11 AM
    1.7.2
    5.5
    We are talking past each other or I'm just stupid :p
    The part is the VM got 50GB Space so about 45GB free space after centos install. But I create auto partition on install. So maybe there is a problem?
    I will try the commands later
  14. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:41 AM
    1.9.x
    5.5
    59,946
    12,556
    8:11 AM
  16. AlekseY
    AlekseY Member
    47
    1:11 AM
    59,946
    12,556
    8:11 AM
    if site is html based, then you need to edit staticfiles.conf or create a separate staticfiles_ssl.conf if you have non-ssl sites sharing same server and comment out staticfiles.conf and use staticfiles_ssl.conf include in your ssl vhost conf file
    and add to html context location the HSTS header
    add_header Strict-Transport-Security "max-age=31536000; includeSubdomains";
    so
        location ~* \.(html|htm|txt)$ {
            add_header Cache-Control "public, must-revalidate, proxy-revalidate";
            access_log off;
            expires 1d;
            break;
  18. AlekseY
    AlekseY Member
    47
    1:11 AM
    eva2000,
    the problem was: dont see add_header Public-Key-Pins
    59,946
    12,556
    8:11 AM
    Public key pinning is left to end user to do SSL - Public Key Pinning HPKP | Centmin Mod Community as it's experimental and according to Mozilla isn't recommended for production sites yet
  20. Matt Williams
    537
    105
    Virginia, USA
    6:11 PM
    latest
    Can exec be enabled somehow? It's required by eww image optimizer and seems to be disabled for 08 beta
