    59,946
    12,556
    8:34 AM
    Haven't tried specifically with Rackspace, but pretty sure any provider's CentOS 7 offers are similar (besides Vultr who default their CentOS 7 filesystem to EXT4 instead of CentOS 7 default filesystem = XFS Vultr - CentOS 7 now available)
    59,946
    12,556
    8:34 AM
    hmm must be quite a few people waiting or interested in CentOS 7 support - was surprised when I checked the thread view counts :)
  3. hungphutho
    hungphutho Member
    55
    35
    5:34 AM
    1.7.2
    Percona 5.6
    @ eva2000 Congratulations !!! :D Many people are interested centos 7
    59,946
    12,556
    8:34 AM
    Updated all Github branches including .08 betas and .07 zip with new option in centmin.sh, AXIVOREPO_DISABLE=y
    This disables Axivo YUM repo install by default for initial Centmin Mod installs. If you want to enable Axivo YUM repo installation, you must do so BEFORE running initial Centmin Mod installation by editing centmin.sh and setting.
    AXIVOREPO_DISABLE=n
    Then running the initial Centmin Mod installation.
    This change was made due to recent changes to the Axivo YUM repo download url causing instability and thus breaking Centmin Mod initial install process.
    59,946
    12,556
    8:34 AM
    heads seems besides AXIVO YUM repo, the EPEL YUM repo for CentOS 7 is having problems as well right now
    * CentOS 7.x detected installing EPEL Repo
    Error: epel-release-7-0.2.noarch.rpm not found !!! Download now......
    2014-08-24 09:48:20 URL:http://epel.mirror.constant.com/beta/7/x86_64/epel-release-7-0.2.noarch.rpm [12936/12936] -> "epel-release-7-0.2.noarch.rpm" [1]
    Download done.
    http://download-i2.fedoraproject.org/pub/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    Trying other mirror.
    http://mirror.es.its.nyu.edu/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://mirror.cc.columbia.edu/pub/linux/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://csc.mcs.sdsmt.edu/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://mirrors.nebo.edu/public/epel/beta/7/x86_64/repodata/repomd.xml: [Errno 12] Timeout on http://mirrors.nebo.edu/public/epel/beta/7/x86_64/repodata/repomd.xml: (28, 'Connection timed out after 30176 milliseconds')
    http://mirrors.kernel.org/fedora-epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://mirror.ancl.hawaii.edu/linux/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://mirror.pnl.gov/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://mirror.cs.pitt.edu/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://mirrors.cat.pdx.edu/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://linux.mirrors.es.net/fedora-epel/beta/7/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
    http://ftp.linux.ncsu.edu/pub/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://epel.mirror.constant.com/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://mirrors.syringanetworks.net/fedora-epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://mirror.steadfast.net/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://mirror.prgmr.com/pub/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://mirror.symnds.com/distributions/fedora-epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://mirrors.liquidweb.com/fedora-epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://mirror.metrocast.net/fedora/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    ftp://ftp.wallawalla.edu/pub/mirrors/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://dl.fedoraproject.org/pub/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    http://fedora.mirror.nexicom.net/epel/beta/7/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
    ftp://mirror.nexicom.net/pub/fedora/epel/beta/7/x86_64/repodata/repomd.xml: [Errno 14] curl#7 - "Failed connect to mirror.nexicom.net:21; Operation now in progress"
    One of the configured repositories failed (Extra Packages for Enterprise Linux 7 - x86_64),
    and yum doesn't have enough cached data to continue. At this point the only
    safe thing yum can do is fail. There are a few ways to work "fix" this:
         1. Contact the upstream for the repository and get them to fix the problem.
         2. Reconfigure the baseurl/etc. for the repository, to point to a working
            upstream. This is most often useful if you are using a newer
            distribution release than is supported by the repository (and the
            packages for the previous distribution release still work).
         3. Disable the repository, so yum won't use it by default. Yum will then
            just ignore the repository until you permanently enable it again or use
            --enablerepo for temporary usage:
                yum-config-manager --disable epel
         4. Configure the failing repository to be skipped, if it is unavailable.
            Note that yum will try to contact the repo. when it runs most commands,
            so will have to try and fail each time (and thus. yum will be be much
            slower). If it is a very temporary problem though, this is often a nice
            compromise:
                yum-config-manager --save --setopt=epel.skip_if_unavailable=true
    failure: repodata/repomd.xml from epel: [Errno 256] No more mirrors to try.
    Error: problem with epel-release-7-0.2.noarch.rpm install.
    59,946
    12,556
    8:34 AM
    59,946
    12,556
    8:34 AM
    59,946
    12,556
    8:34 AM
    Updated latest .08 betas with AUTOOPENSSLCHECK feature update inc/nginx_upgrade.inc AUTOOPENSSLCHECK · 684e6fd · centminmod/centminmod · GitHub
    auto check if static compiled Nginx openssl version matches
    the one defined in centmin.sh OPENSSL_VERSION variable
    if doesn't match then auto recompile the statically set
    OPENSSL_VERSION
    This is what fixed my previous failed attempts to use OpenSSL 1.02 beta 3 with chacha20-poly1305 cipher support as Nginx kept on segfaulting until this check was done Forums switch to chacha20-poly1305 SSL cipher (OpenSSL 1.0.2 beta3) | Centmin Mod Community
  9. hungphutho
    hungphutho Member
    55
    35
    5:34 AM
    1.7.2
    Percona 5.6
    @eva2000 did you for testing nginx boringssl ?
    boringssl always available chacha20-poly1305
    59,946
    12,556
    8:34 AM
    Unsuccessfully tried Nginx and boringSSL right now, so will wait to later to try again :D
  11. hungphutho
    hungphutho Member
    55
    35
    5:34 AM
    1.7.2
    Percona 5.6
    @eva2000 openssl
    openssl/openssl · GitHub 1.0.2-aead branch
    my receive this error at compile time
    poly1305_vec.c:117: error: âuint128_tâ undeclared (first use in this function)
    poly1305_vec.c:117: error: (Each undeclared identifier is reported only once
    poly1305_vec.c:117: error: for each function it appears in.)
    poly1305_vec.c:117: error: expected â)â before âhiâ
    poly1305_vec.c: In function âpoly1305_first_blockâ:
    poly1305_vec.c:257: error: âuint128_tâ undeclared (first use in this function)
    poly1305_vec.c:257: error: expected â;â before âdâ
    poly1305_vec.c:281: error: âdâ undeclared (first use in this function)
    poly1305_vec.c:281: warning: implicit declaration of function âadd128â
    poly1305_vec.c:281: warning: implicit declaration of function âmul64x64_128â
    poly1305_vec.c:285: warning: implicit declaration of function âlo128â
    poly1305_vec.c:285: warning: implicit declaration of function âshr128â
    poly1305_vec.c:286: warning: implicit declaration of function âadd128_64â
    poly1305_vec.c: In function âCRYPTO_poly1305_finishâ:
    poly1305_vec.c:644: error: âuint128_tâ undeclared (first use in this function)
    poly1305_vec.c:644: error: expected â;â before âdâ
    poly1305_vec.c:682: error: âdâ undeclared (first use in this function)
    make[2]: *** [poly1305_vec.o] Error 1
    make[2]: Leaving directory `/svr-setup/openssl-1.0.2-beta3/crypto/poly1305'
    make[1]: *** [subdirs] Error 1
    make[1]: Leaving directory `/svr-setup/openssl-1.0.2-beta3/crypto'
    make: *** [build_crypto] Error 1
    Can you Suggest me :)
    thanks a lot
    59,946
    12,556
    8:34 AM
    Yeah that branch won't work got same errors. I had a custom patched version but private testing right now so not made public yet. In due time :)
    59,946
    12,556
    8:34 AM
    59,946
    12,556
    8:34 AM
    Would also be helpful if folks test this 123.08centos7beta01 branch on CentOS 6.5 systems as well as it is most likely going to the branch that .08 stable will be released from :)
  15. rdan
    6:34 AM
    So 123.08centos7beta01 branch is fully compatible also on CentOS 6.5?
    If yes then I will use it on my Live Server :)
    59,946
    12,556
    8:34 AM
    yes it is, it's the branch i test for CentOS 6.5 and 7.0 support :)
    59,946
    12,556
    8:34 AM
    New commits to this branch to fix up some PHP configuration and compiling routines including preventing PHP 5.5/5.6 upgrades from prompting to install Zend OpCache 7.03 at upgrade time.
    Commits · centminmod/centminmod · GitHub
  18. rdan
    6:34 AM
    Surely I will use this branch for Nginx 1.7.5 upgrade and PHP 5.6.1 ;)
    59,946
    12,556
    8:34 AM
    59,946
    12,556
    8:34 AM
