    59,946
    12,556
    8:14 AM
    Anyone with a spare 15-20mins want to test out one liner installer for stable .07 and .08 beta builds ? easy as copying and pasting one one below :)
    Video posted at Install - New Centmin Mod One Liner Install testing | Centmin Mod Community
    for .07 stable
    curl -sL http://centminmod.com/stableinstaller.sh | bash
    for .08 beta
    curl -sL http://centminmod.com/betainstaller.sh | bash
    enjoy :D
  2. Mask
    Mask Active Member
    108
    31
    3:14 AM
    Nginx 1.9.1
    MariaDB 10.0.19
    Might seem like a stupid question,
    but is the 123.08 for CentOS 7 only ?? Or can I use it on Centos 6.5 as well?
    59,946
    12,556
    8:14 AM
  4. Mask
    Mask Active Member
    108
    31
    3:14 AM
    Nginx 1.9.1
    MariaDB 10.0.19
    Well in that case,
    works perfectly with CentOS 6.5 :D
    59,946
    12,556
    8:14 AM
    Updated default PHP & OpenSSL versions
    Updated Centmin Mod 1.2.3-eva2000.07 stable github and zip downloads for new defaults for
    Updated Centmin Mod .08 beta02 branch on github with new defaults for
  6. Andy
    Andy Active Member
    546
    90
    5:14 PM
    I need to enable exec().
    How do I do it?
    I don't see the list of exec() in disabled_functions in /usr/local/lib/php.ini
    59,946
    12,556
    8:14 AM
  8. Andy
    Andy Active Member
    546
    90
    5:14 PM
    59,946
    12,556
    8:14 AM
    2nd link is the updated as of now version with exec removed :)
  10. Andy
    Andy Active Member
    546
    90
    5:14 PM
    I updated with latest code and both config/php-fpm/php-fpm.conf and /usr/local/etc/php-fpm.conf still have exec in the last line.
  11. Andy
    Andy Active Member
    546
    90
    5:14 PM
    You probably got some typo in there as well.
    You had php_admin_value[disable_functions] = shell_exe
    but you meant
    php_admin_value[disable_functions] = shell_exec, exec
    You are missing the c after shell_exe.
    59,946
    12,556
    8:14 AM
    ? it's correct centminmod/php-fpm.conf at 123.08centos7beta02 · centminmod/centminmod · GitHub
    you need to edit it on your live /usr/local/etc/php-fpm.conf via cmd short cut fpmconf too
    the linked github versions are only the templates
    59,946
    12,556
    8:14 AM
    Found the cause of this error outlined at Nginx - Nginx update to latest version errors | Centmin Mod Community
    It's due to Centmin Mod .08 beta 02 now defaults to installing GeoIP for Nginx and it's routine changes directory when it installs GeoIP if not detected - so when it comes to Nginx upgrade, it doesn't find the directory the first time. Second time it finds Nginx directory as GeoIP files are detected so doesn't change directories.
    Fix it in latest commit to Centmin Mod .08 beta02 (branch 123.08centos7beta02) fix Nginx upgrade routine due to GeoIP addition for .08 beta 02 · centminmod/centminmod@6abfb98 · GitHub
  14. pamamolf
    4,127
    1:14 AM
  15. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:44 AM
    1.9.x
    5.5
    i installed beta 08 but thats fuc*ked my server and get down . i changed os and 10 $ pay for it :mad:
    59,946
    12,556
    8:14 AM
    ???? please elaborate with examples of what went wrong. More detailed the info the better :)
  17. Cr0w
    Cr0w Member
    165
    9
    Iran
    1:44 AM
    1.9.x
    5.5
    i saw many errors when installing
    for example
    somethinglikethis.h not foud .....................
    error
    and then counting above after a seconds the server get down and never started :|
    59,946
    12,556
    8:14 AM
    you mean yum package not found, those are not errors just notices as to what packages are not found and script proceeds to install them :)
    see these 2 install videos
    Centmin Mod .08 beta SSH one liner install on CentOS 6 + CentOS 7 simultaneously | Centmin Mod Community
    and
    How to install Centmin Mod .08 beta using SSH one liner command | Centmin Mod Community
    Youtube timestamp link to what I think you saw CentOS Nginx Installer (LEMP web stack) - Centmin Mod 1.2.3-eva2000.08 beta install - YouTube ?
    59,946
    12,556
    8:14 AM
    59,946
    12,556
    8:14 AM
    Okay could be related to Github being DDOS attacked when you tried installing GitHub System Status
    and GitHub hit by DDoS attack | Hacker News
    As alot of Centmin Mod's downloaded components are hosted on Github repositories too
