  1. JarylW
    JarylW Active Member
    216
    41
    Singapore
    5:44 AM
    It uses older kernel though, with backports.
  2. xDragonZ
    xDragonZ New Member
    5:44 AM
    By the way OpenSSL 1.0.1k is now available
    59,946
    12,556
    7:44 AM
    darn, here we go again ! thanks for heads up !
  4. xDragonZ
    xDragonZ New Member
    5:44 AM
    Same as nginx pagespeed too '1.9.32.3' , hmm
    59,946
    12,556
    7:44 AM
    59,946
    12,556
    7:44 AM
    ngx_pagespeed 1.9.32.3 update + OpenSSL 1.0.1k
    Updated all Centmin Mod .07 and .08 beta branches to ngx_pagespeed 1.9.32.3 (includes OpenSSL 1.0.1k by default for new Centmin Mod installs.)
    For existing installs
    59,946
    12,556
    7:44 AM
    A few version updates for .08 beta builds - actual commits update libevent 2.0.22, igbinary 1.2.1, memcached server 1.4.22 for .08 ... ยท 6001f84 ยท centminmod/centminmod ยท GitHub
    Haven't tested changes yet but centmin.sh menu option 10 should rebuild them all and may need centmin.sh menu option 5 PHP rebuild for memcached PHP extension and ensure you answer Yes for YUM install checks when you run PHP rebuild via menu option 5..
    edit: hmm libmemcached extension isn't compiling for some reason
    checking for libmemcached... yes, shared
    checking whether to enable memcached session handler support... yes
    checking whether to enable memcached igbinary serializer support... yes
    checking whether to enable memcached json serializer support... yes
    checking whether to enable memcached msgpack serializer support... no
    checking whether to enable memcached sasl support... yes
    checking whether to enable memcached protocol support... no
    checking for ZLIB... yes, shared
    checking for pkg-config... /usr/bin/pkg-config
    checking for zlib location... /usr
    checking for session includes... /usr/local/include/php
    checking for json includes... /usr/local/include/php
    checking for igbinary includes... /usr/local/include/php
    checking for memcached session support... enabled
    checking for memcached igbinary support... enabled
    checking for memcached msgpack support... disabled
    checking for libmemcached location... configure: error: Unable to find memcached.h under /usr
    locate memcached.h
    /svr-setup/libmemcached-1.0.18/libmemcached/memcached.h
    /svr-setup/libmemcached-1.0.18/libmemcached/memcached.hpp
    /svr-setup/libmemcached-1.0.18/libmemcached-1.0/memcached.h
    /svr-setup/libmemcached-1.0.18/libmemcached-1.0/memcached.hpp
    /svr-setup/libmemcached-1.0.18/libmemcached-1.0/struct/memcached.h
    /svr-setup/libmemcached-1.0.18/libtest/memcached.h
    /svr-setup/libmemcached-1.0.18/libtest/memcached.hpp
    /svr-setup/memcached-1.4.20/memcached.h
    /svr-setup/memcached-1.4.22/memcached.h
    /svr-setup/memcached-2.2.0/php_memcached.h
    /usr/local/include/libmemcached/memcached.h
    /usr/local/include/libmemcached/memcached.hpp
    /usr/local/include/libmemcached-1.0/memcached.h
    /usr/local/include/libmemcached-1.0/memcached.hpp
    /usr/local/include/libmemcached-1.0/struct/memcached.h
    PHP-FPM restarts give
    fpmrestart
    Starting php-fpm [14-Jan-2015 08:57:02] NOTICE: PHP message: PHP Warning:  PHP Startup: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20131226/memcached.so' - /usr/local/lib/php/extensions/no-debug-non-zts-20131226/memcached.so: cannot open shared object file: No such file or directory in Unknown on line 0
    done
    edit2: found the problem, I tried updating an old .07 stable install with .08 beta latest code and it was missing Remi YUM repo where libmemcached and libmemcached-devel packages are installed from .08 beta. But my .07 stable doesn't have Remi YUM repo so failed.
    steps to fix it below for .07 stable users trying latest .08 beta and have missing Remi YUM repo
    For CentOS 6 to add missing Remi YUM repo for Centmin Mod .07 or .08 existing installs
    CENTOSSIXREMIFILE="remi-release-6.rpm"
    CENTOSSIXREMI="http://rpms.famillecollet.com/enterprise/${CENTOSSIXREMIFILE}"
    wget ${CENTOSSIXREMI} --tries=3
    rpm -ivh --nosignature ${CENTOSSIXREMIFILE}
    For CentOS 7 to add missing Remi YUM repo for Centmin Mod .07 or .08 existing installs
    CENTOSSEVENREMIFILE="remi-release-7.rpm"
    CENTOSSEVENREMI="http://rpms.famillecollet.com/enterprise/${CENTOSSEVENREMIFILE}"
    wget ${CENTOSSEVENREMI} --tries=3
    rpm -ivh --nosignature ${CENTOSSEVENREMIFILE}
    Then for either CentOS 6 or 7 final step add priority=9 and exclude=php* mysql* to first [remi] group within /etc/yum.repos.d/remi.repo
    [remi]
    name=Les RPM de remi pour Enterprise Linux 6 - $basearch
    #baseurl=http://rpms.famillecollet.com/enterprise/6/remi/$basearch/
    mirrorlist=http://rpms.famillecollet.com/enterprise/6/remi/mirror
    enabled=0
    gpgcheck=1
    gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-remi
    priority=9
    exclude=php* mysql*
    Then install libmemcached and libmemcached-devel from Remi YUM repo which has different naming convention making sure to disable plugin priorities and enable remi YUM repo
    yum list libmemcached-last libmemcached-last-devel -q --disableplugin=priorities --enablerepo=remi
    Available Packages
    libmemcached-last.x86_64                                                            1.0.18-2.el6.remi                                                      remi
    libmemcached-last-devel.x86_64                                                      1.0.18-2.el6.remi                                                      remi
    install
    yum -y install libmemcached-last libmemcached-last-devel -q --disableplugin=priorities --enablerepo=remi
    now working after another centmin.sh menu 10 run to recompile memcached stuff
    fpmrestart
    Starting php-fpm  done
    php --ri memcache
    memcache
    memcache support => enabled
    Version => 3.0.8
    Revision => $Revision: 329835 $
    memcache.allow_failover => 1 => 1
    memcache.max_failover_attempts => 20 => 20
    memcache.default_port => 11211 => 11211
    memcache.chunk_size => 32768 => 32768
    memcache.protocol => ascii => ascii
    memcache.hash_strategy => consistent => consistent
    memcache.hash_function => crc32 => crc32
    memcache.redundancy => 1 => 1
    memcache.session_redundancy => 2 => 2
    memcache.compress_threshold => 20000 => 20000
    memcache.lock_timeout => 15 => 15
    php --ri memcached
    memcached
    memcached support => enabled
    Version => 2.2.0
    libmemcached version => 1.0.18
    SASL support => yes
    Session support => yes
    igbinary support => yes
    json support => yes
    msgpack support => no
    memcached.sess_locking => 1 => 1
    memcached.sess_consistent_hash => 0 => 0
    memcached.sess_binary => 0 => 0
    memcached.sess_lock_wait => 150000 => 150000
    memcached.sess_lock_max_wait => 0 => 0
    memcached.sess_lock_expire => 0 => 0
    memcached.sess_prefix => memc.sess.key. => memc.sess.key.
    memcached.sess_number_of_replicas => 0 => 0
    memcached.sess_randomize_replica_read => 0 => 0
    memcached.sess_remove_failed => 0 => 0
    memcached.sess_connect_timeout => 3000 => 3000
    memcached.sess_sasl_username => no value => no value
    memcached.sess_sasl_password => no value => no value
    memcached.compression_type => fastlz => fastlz
    memcached.compression_factor => 1.3 => 1.3
    memcached.compression_threshold => 2000 => 2000
    memcached.serializer => igbinary => igbinary
    memcached.use_sasl => 0 => 0
    memcached.store_retry_count => 2 => 2
    and igbinary 1.2.1
    php --ri igbinary
    igbinary
    igbinary support => enabled
    igbinary version => 1.2.1
    igbinary APC serializer ABI => 0
    igbinary session support => yes
    igbinary.compact_strings => On => On
    Memcached 1.4.22 server
    memcached -V
    memcached 1.4.22
    Looks like I need to add to .08 beta a check for Remi YUM repo's existence and if not installed, install it.
    I already added a manual check that covers this though when you run PHP and Nginx upgrades you always get prompted for YUM install checks from inc/yumskip.inc which if you answer YES = y to, will run yuminstall function from inc/yuminstall.inc which calls yumcentossixdownload or yumcentossevendownload functions depending on detected OS = CentOS 6 or CentOS 7 and call inc/sdownload_centossix.inc or inc/downloads_centosseven.inc - this is where the remi.repo detection check comes in at lines 43 to 79 of inc/downloads_centossix.inc
    Gist of it is, if you answer Yes = y to YUM install checks when you upgrade Nginx via centmin.sh option 4 or PHP via centmin.sh option 5 you will go through a routine to check each YUM repo's .repo file, if missing it will trigger the installation of the repo - in this case remi.repo. So you do not have to go through my above manual Remi YUM repo install steps - although I believe you would have to still do memcached yum install steps above.
  8. rdan
    5:44 AM
    I got: 1.2.2-dev
    # php --ri igbinary
    igbinary
    igbinary version => 1.2.2-dev
    59,946
    12,556
    7:44 AM
    Ah that's right as existing .08 betas prior to above change had in centmin.sh IGBINARYGIT=y set which takes the master github source code for latest dev version which is 1.2.2-dev.
    While on new .08 code IGBINARYGIT=n in centmin.sh so it takes from stable igbinary 1.2.1 :)
    You can choose either IGBINARYGIT=y 1.2.2-dev or IGBINARYGIT=n 1.2.1 stable :D
  10. rdan
    5:44 AM
    59,946
    12,556
    7:44 AM
  12. rdan
    5:44 AM
    Yes.
    59,946
    12,556
    7:44 AM
    what does output from this command produce to see which igbinary tarball and directories exist on your server
    ls -lah /svr-setup/ | grep igbinary
    try restarting PHP-FPM service too
  14. rdan
    5:44 AM
    By the way I changed my svr-setup directory :)
    But still both no output.
    # ls -lah /home/svr-setup/ | grep igbinary
    # ls -lah /svr-setup/ | grep igbinary
    59,946
    12,556
    7:44 AM
    looks like it might be problem with your changed directories not sure yet.. you can use How to troubleshoot Centmin Mod initial install issues | Centmin Mod Community and check your memcached upgrade log in /root/centminlogs for clues
    list logs in ascending date order so it's easier to differentiate more current logs created during centmin.sh menu runs
    ls -lAhrt /root/centminlogs
    would be named in format like
    centminmod_1.2.3-eva2000.0*_*-*_memcached_reinstall.log
    edit: hmm i think the checkigbinary function might not reinstall igbinary if the routine detects igbinary is already installed.. will have to revise that :)
    59,946
    12,556
    7:44 AM
    59,946
    12,556
    7:44 AM
    59,946
    12,556
    7:44 AM
    Edit: made a dedicated thread for discussion and feedback here Centmin Mod .08 beta + pure-ftpd virtual FTP user support | Centmin Mod Community
    Made an update to Centmin Mod .08 which easily added FTP virtual user/pass support to Nginx vhost creation routine on centmin.sh menu option 2 ! This should lock the virtual FTP user into their Nginx vhost directory :D
    Note: This is not the full jailed/chrooted user preview setup I outlined but a much more basic workaround for now.
    Commit: add support for pure-ftpd virtual FTP users & TLS FTP (explicit SSL) onl... ยท d0f5c8e ยท centminmod/centminmod ยท GitHub
    It was @Mask question at LEB and StartledPhoenix user's answer which gets all the credit for pointing me onto using pure-ftpd YUM package and virtual user support. Honestly, never looked at pure-ftpd as an option !
    Enabled TLS/SSL
    • I went one step further beyond just adding pure-ftpd virtual user support, I also enabled and forced TLS SSL only mode by creating a self-signed SSL certificate for pure-ftpd. So there's enforced encryption for more secure FTP connection.
    • As such you need to set your FTP client to use FTP explicit SSL mode and enable and check Passive connections (PASV) and connect via your server's ip address for hostname and use FTP port 21. Filezilla users have a guide and info for FTP Explicit SSL/TLS mode. Centmin Mod updated code already creates the self signed certificate, so only thing in Filezilla to do is set In the SSL/TLS settings menu check "allow Explicit SSL/TLS on normal connections" and check "Disallow plain unencrypted FTP" and "Force PROT P to encrypt file transfers in SSL/TLS mode"
    • You also have to disable in your FTP client SSL validation as a self-signed certificate was used.
    • Note passive ports if needed to be set in FTP client are in range between 3000 to 3050 i.e. for Filezilla.
    Sample centmin.sh menu option 2 add Nginx vhost output from Centmin Mod .08 beta below
                       Centmin Mod Menu
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    14). SELinux disable
    16). Change SSHD Port Number
    20). NSD Re-install
    22). Exit
    Enter option [ 1 - 22 ] 2
    Enter vhost domain name you want to add (without www. prefix): domain1.com
    Create FTP username for vhost domain (enter username): ftpuser4
    Create FTP password for ftpuser4 (enter password): pass
    FTP username you entered: ftpuser4
    FTP password you entered: pass
    Password:
    Enter it again:
    service nginx reload
    Reloading nginx:                                           [  OK  ]
    service pure-ftpd restart
    Stopping pure-ftpd:                                        [  OK  ]
    Starting pure-ftpd:                                        [  OK  ]
    FTP hostname : ipaddress
    FTP port : 21
    FTP mode : FTP (explicit SSL)
    FTP Passive (PASV) : ensure is checked/enabled
    FTP username created for domain1.com : ftpuser4
    FTP password created for domain1.com : pass
    vhost for domain1.com created successfully
    vhost conf file for domain1.com created: /usr/local/nginx/conf/conf.d/domain1.com.conf
    upload files to /home/nginx/domains/domain1.com/public
    vhost log files directory is /home/nginx/domains/domain1.com/log
    Current vhost listing at: /usr/local/nginx/conf/conf.d/
    Jan 1   00:37   798    ssl.conf
    Jan 1   00:37   1.1K   demodomain.com.conf
    Jan 1   00:37   1.4K   virtual.conf
    Jan 17  21:53   1.3K   domain1.com.conf
    My SecureFX SFTP/FTP client settings example with FTP/SSL (explicit). Some FTP clients call it FTP over TLS or SSL
    Disable certificate validation due to using self-signed SSL certificate
    TLS secure connection details connected via TLS1.2
    Using Filezilla FTP Client with FTP Explicit TLS/SSL
    Transfer mode = Passive
    Self-signed certificate as expected is unknown to Filezilla so needs to manually allowed. Will need to work on setting SHA2 for signature algorithm etc
    This is a quick implementation in Centmin Mod with only a few hours of testing. So test it out on test VPS servers first and provide feedback and suggestions for improvements here ;) :)
    To be able to use this code, ensure you're using latest updated Centmin Mod .08 beta code. If you have an existing .08 install, see how to update the instance in 1st post of this thread. Or try out the Git command line method outlined here.
    pure-pw commands
    pure-pw command adduser was to add a virtual user. However, there's more commands to delete a user or change passwords etc.
    pure-pw manual is here and http://download.pureftpd.org/pub/pure-ftpd/doc/README.Virtual-Users
    pure-pw userdel login [-f passwd_file] [-F puredb_file] [-m]
    pure-pw passwd login [-f passwd_file] [-F puredb_file] [-m]
    pure-pw show login [-f passwd_file] [-m]
    pure-pw mkdb [<puredb_database_file> [-f passwd_file]] [-F puredb_file]
    pure-pw list [-f passwd_file]
    list all pure-ftpd created virtual FTP users
    pure-pw list
    to delete virtual FTP user
    pure-pw userdel FTPUSERNAME
    pure-pw mkdb
    change virtual FTP user's password
    pure-pw passwd FTPUSERNAME
    pure-pw mkdb
    show full details for an specific pure-ftpd virtual FTP user
    pure-pw show FTPUSERNAME
    Existing Centmin Mod Nginx vhosts
    For folks with existing Centmin Mod setups with already created Nginx vhosts, you can manually instally pure-ftpd using following commands:
    CNIP=$(ip route get 8.8.8.8 | awk 'NR==1 {print $NF}')
    yum -q -y install pure-ftpd
    chkconfig pure-ftpd on
    sed -i 's/LF_FTPD = "10"/LF_FTPD = "3"/g' /etc/csf/csf.conf
    sed -i 's/PORTFLOOD = \"\"/PORTFLOOD = \"21;tcp;5;300\"/g' /etc/csf/csf.conf
    sed -i 's/# UnixAuthentication  /UnixAuthentication  /' /etc/pure-ftpd/pure-ftpd.conf
    sed -i 's/VerboseLog                  no/VerboseLog                  yes/' /etc/pure-ftpd/pure-ftpd.conf
    sed -i 's/# PureDB                        \/etc\/pure-ftpd\/pureftpd.pdb/PureDB                        \/etc\/pure-ftpd\/pureftpd.pdb/' /etc/pure-ftpd/pure-ftpd.conf
    sed -i 's/#CreateHomeDir               yes/CreateHomeDir               yes/' /etc/pure-ftpd/pure-ftpd.conf
    sed -i 's/# TLS                      1/TLS                      2/' /etc/pure-ftpd/pure-ftpd.conf
    sed -i 's/# PassivePortRange          30000 50000/PassivePortRange    3000 3050/' /etc/pure-ftpd/pure-ftpd.conf
    mkdir -p /etc/ssl/private
    openssl req -x509 -days 7300 -sha256 -nodes -subj "/C=US/ST=California/L=Los Angeles/O=Default Company Ltd/CN==$CNIP" -newkey rsa:1024 -keyout /etc/ssl/private/pure-ftpd.pem -out /etc/ssl/private/pure-ftpd.pem
    chmod 600 /etc/ssl/private/*.pem
    openssl x509 -in /etc/ssl/private/pure-ftpd.pem -text -noout
    csf -r
    Once pure-ftpd is installed, create your FTP username via command below which will lock and jail the YOURFTPUSERNAME to directory path specified by -d /home/nginx/domains/YOURDOMAINVHOST. So you can also lock specific virtual FTP users to other directory paths to if you want.
    pure-pw useradd YOURFTPUSERNAME -u nginx -g nginx -d /home/nginx/domains/YOURDOMAINVHOST
    pure-pw mkdb
    • where YOURFTPUSERNAME is your FTP username, you will be prompted to create password
    • where YOURDOMAINVHOST is your existing Nginx vhost domain name you already setup
    Compatible FTP clients for SSL/TLS
  19. Omer
    Omer New Member
    12:44 AM
    Nginx 1.7.5
    MariaDB 5.5
  20. Mask
    Mask Active Member
    108
    31
    2:44 AM
    Nginx 1.9.1
    MariaDB 10.0.19
    Thanks George :)
    I set it up yesterday after StartledPhoenix suggested it and was just about to update the thread here. You beat me to it :)
    It works perfectly ...
