    59,946
    12,556
    8:14 AM
    thanks for testing and confirmation of my suspicions
    looks like something to investigate when I have more free time :)
    59,946
    12,556
    8:14 AM
    Custom PHP .ini Settings
    Heads up, with Centmin Mod .08 beta, PHP custom default values are set in a .ini file at /etc/centminmod/php.d/custom_php.ini. So if you want to set your own custom php.ini settings that survive upgrades, you need to create a custom_php2.ini file at /etc/centminmod/php.d/custom_php2.ini which is alphabetically after custom_php.ini (see here)
    php --ini
    Additional .ini files parsed:      /etc/centminmod/php.d/apcu.ini,
    /etc/centminmod/php.d/custom_php.ini,
    /etc/centminmod/php.d/custom_php2.ini,
    /etc/centminmod/php.d/newrelic.ini,
    59,946
    12,556
    8:14 AM
    Made an update to Centmin Mod .08 beta's inc/phpsededit.inc file to change custom_php.ini to a_customphp.ini file name and make it adjustable via variable PHPINICUSTOM moved default custom PHP .ini settings to custom .ini file alphabeticall... · 42c6419 · centminmod/centminmod · GitHub This would make it more likely that setting your own filename in /etc/centminmod/php.d/yourfile.ini will be listed alphabetically below a_customphp.ini to prevent conflicts and ensure yourfile.ini takes priority and overrides whatever is set in a_customphp.ini.
    php --ini
    59,946
    12,556
    8:14 AM
    Nginx 1.7.9 & ngx_cache_purge compatibility update
    You can either update the .08 beta source code via outlined instructions or manually edit your server's centmin.sh as below.
    ngx_cache_pure 2.3 is out might help FRiCKLE Labs / nginx / ngx_cache_purge
    change log http://labs.frickle.com/nginx_ngx_cache_purge/CHANGES
    in centmin.sh edit
    from
    NGINX_CACHEPURGEVER='2.2'
    to
    NGINX_CACHEPURGEVER='2.3'
    and run centmin.sh menu option 4 to recompile Nginx for 1.7.9
  5. Sebastian B.
    Sebastian B. New Member
    25
    12:14 AM
    1.7.2
    5.5
    I got the same on KVM:
    Error: IPSET: [ipset v6.11: Kernel error received: Invalid argument], at line 4363 in /usr/sbin/csf
    You need to restart csf successfully to remove this warning, or delete /etc/csf/csf.error
    59,946
    12,556
    8:14 AM
    pre-Dec 15th .08 build ?
  7. Sebastian B.
    25
    12:14 AM
    1.7.2
    5.5
    I got it today from github
    59,946
    12,556
    8:14 AM
    what VPS virtualisation and VPS provider ? could be the kernel used doesn't have IPSET support
  9. Sebastian B.
    25
    12:14 AM
    1.7.2
    5.5
    proxmoxx / KVM (filemedia.de). I even installed a different kernel for centos 6 (ELRepo : kernel-lt). Still the same problem
    But with "sed -i 's/LF_IPSET = "1"/LF_IPSET = "0"/g' /etc/csf/csf.conf" it works
    59,946
    12,556
    8:14 AM
    Could be those kernels don't support IPSET IP sets What do you get when you type the commands
    ipset version
    updatedb
    locate kernel/net/netfilter/ipset
    yum -q list ipset ipset-devel
    and command
    lsmod | grep ip_set
    i.e.
    lsmod | grep ip_set
    ip_set_hash_net        31664  2
    ip_set                 36629  2 ip_set_hash_net,xt_set
    nfnetlink              14606  1 ip_set
  11. Sebastian B.
    25
    12:14 AM
    1.7.2
    5.5
    [root@de ~]# ipset version
    ipset v6.11, protocol version: 6
    [root@de ~]# updatedb
    [root@de ~]# locate kernel/net/netfilter/ipset
    /lib/modules/2.6.32-504.3.3.el6.x86_64/kernel/net/netfilter/ipset
    /lib/modules/2.6.32-504.3.3.el6.x86_64/kernel/net/netfilter/ipset/ip_set.ko
    /lib/modules/2.6.32-504.3.3.el6.x86_64/kernel/net/netfilter/ipset/ip_set_bitmap_ip.ko
    /lib/modules/2.6.32-504.3.3.el6.x86_64/kernel/net/netfilter/ipset/ip_set_bitmap_ipmac.ko
    /lib/modules/2.6.32-504.3.3.el6.x86_64/kernel/net/netfilter/ipset/ip_set_bitmap_port.ko
    /lib/modules/2.6.32-504.3.3.el6.x86_64/kernel/net/netfilter/ipset/ip_set_hash_ip.ko
    /lib/modules/2.6.32-504.3.3.el6.x86_64/kernel/net/netfilter/ipset/ip_set_hash_ipport.ko
    /lib/modules/2.6.32-504.3.3.el6.x86_64/kernel/net/netfilter/ipset/ip_set_hash_ipportip.ko
    /lib/modules/2.6.32-504.3.3.el6.x86_64/kernel/net/netfilter/ipset/ip_set_hash_ipportnet.ko
    /lib/modules/2.6.32-504.3.3.el6.x86_64/kernel/net/netfilter/ipset/ip_set_hash_net.ko
    /lib/modules/2.6.32-504.3.3.el6.x86_64/kernel/net/netfilter/ipset/ip_set_hash_netport.ko
    /lib/modules/2.6.32-504.3.3.el6.x86_64/kernel/net/netfilter/ipset/ip_set_list_set.ko
    /lib/modules/3.10.63-1.el6.elrepo.x86_64/kernel/net/netfilter/ipset
    /lib/modules/3.10.63-1.el6.elrepo.x86_64/kernel/net/netfilter/ipset/ip_set.ko
    /lib/modules/3.10.63-1.el6.elrepo.x86_64/kernel/net/netfilter/ipset/ip_set_bitmap_ip.ko
    /lib/modules/3.10.63-1.el6.elrepo.x86_64/kernel/net/netfilter/ipset/ip_set_bitmap_ipmac.ko
    /lib/modules/3.10.63-1.el6.elrepo.x86_64/kernel/net/netfilter/ipset/ip_set_bitmap_port.ko
    /lib/modules/3.10.63-1.el6.elrepo.x86_64/kernel/net/netfilter/ipset/ip_set_hash_ip.ko
    /lib/modules/3.10.63-1.el6.elrepo.x86_64/kernel/net/netfilter/ipset/ip_set_hash_ipport.ko
    /lib/modules/3.10.63-1.el6.elrepo.x86_64/kernel/net/netfilter/ipset/ip_set_hash_ipportip.ko
    /lib/modules/3.10.63-1.el6.elrepo.x86_64/kernel/net/netfilter/ipset/ip_set_hash_ipportnet.ko
    /lib/modules/3.10.63-1.el6.elrepo.x86_64/kernel/net/netfilter/ipset/ip_set_hash_net.ko
    /lib/modules/3.10.63-1.el6.elrepo.x86_64/kernel/net/netfilter/ipset/ip_set_hash_netiface.ko
    /lib/modules/3.10.63-1.el6.elrepo.x86_64/kernel/net/netfilter/ipset/ip_set_hash_netport.ko
    /lib/modules/3.10.63-1.el6.elrepo.x86_64/kernel/net/netfilter/ipset/ip_set_list_set.ko
    [root@de ~]# yum -q list ipset ipset-devel
    Installierte Pakete
    ipset.x86_64                             6.11-3.el6                        @base
    ipset-devel.x86_64                       6.11-3.el6                        @base
    and
    [root@de ~]# lsmod | grep ip_set
    ip_set_hash_net        26431  0
    ip_set                 30946  2 xt_set,ip_set_hash_net
    59,946
    12,556
    8:14 AM
    strange indeed should work then !
    tried rebooting server ?
    could be something specific to Proxmox setup ?
    59,946
    12,556
    8:14 AM
    If you deliberately set LF_IPSET=1 in csf.conf and restart, what does the content of /etc/csf/csf.error have ?
  14. Sebastian B.
    25
    12:14 AM
    1.7.2
    5.5
    Now LF_IPSET=1 works. Strange but seems still bugy. I need on bootup reactivate and then disable csf that i can connect via ssh to the server
    59,946
    12,556
    8:14 AM
    check /etc/csf/ directories files content in csf.deny to double check if your ip address is blocked and also you can grep and search your ip address to see if there's any matches in iptables
    csf -g youripaddress
    can also remove the ip from csf.deny via
    csf -dr youripaddress
    see the help commands for more info
    csf -h
  16. JarylW
    JarylW Active Member
    216
    41
    Singapore
    6:14 AM
    Did anything change recently? With bash installer or decompress method both seem to land my vultr instance without the centmin commands. Something not copying to the bin folder?
    I need to go to /root/centminmod/centmin.sh
    Other than that all seems to work .
    Edit: forgot to mention this is on their CentOS 7 template. 1GB japan location
    59,946
    12,556
    8:14 AM
    try logging out and back in after initial install as centmin shortcut only works after that step - always has been that way :)
    for other shortcut commands they should work
    59,946
    12,556
    8:14 AM
  19. JarylW
    216
    41
    Singapore
    6:14 AM
    59,946
    12,556
    8:14 AM
    thanks for the feedback and testing.. guess still need more time to investigating for OpenVZ
