  1. Josephm
    Josephm Active Member
    132
    44
    5:14 AM
    1.9.5
    10.0.21
    I tested Centos 6.5 with stable script and everything is good at turnkey cloud. Seems we have more thing to make centminmod beta compatible in centos 7...
  2. Andy
    Andy Active Member
    546
    90
    5:14 PM
    Got same issue on Linode and DigitalOcean centos 7 and latest centminmod beta 8.
    I didn't have this problem before so I suspect this may be related to some nginx changes that George made to the code.
    Weird enough, this issue only appears on brand new server that we install from centminmod menu 1. I have 2 existing server that use latest beta 8 code without issue with updating nginx, etc.
    59,946
    12,556
    8:14 AM
    would need the santised initial install log via gist or pastebin as per How to troubleshoot Centmin Mod initial install issues to further diagnose the problem
  4. Andy
    Andy Active Member
    546
    90
    5:14 PM
    59,946
    12,556
    8:14 AM
    ah might need to reverse i change i did in nginx.conf changing it back
    from
    pid        nginx.pid;
    to
    pid         logs/nginx.pid;
    run command to kill all nginx processes before restarting with nginx.conf changes
    kill -9 $(pidof nginx)
  6. JarylW
    JarylW Active Member
    216
    41
    Singapore
    6:14 AM
    59,946
    12,556
    8:14 AM
    Might want to santise and filter out passwords in the log at very bottom of log too as per How to troubleshoot Centmin Mod initial install issues | Centmin Mod Community
    i see the error with CSF Firewall,
    [1;33;40m--------------------------------------------------------
    (B[m[1;33;40mCheck CSF Firewall Version:
    (B[m[1;33;40m--------------------------------------------------------
    (B[mYou have an unresolved error when starting csf:
    Error: IPSET: [ipset v6.19: Cannot open session to kernel.], at line 4363 in /usr/sbin/csf
    You need to restart csf successfully to remove this warning, or delete /etc/csf/csf.error
    are you using VPS ? what type OpenVZ, KVM, Xen, VMware ?
    made a fix in latest .08 beta at fix CSF firewall IPSET check for non-OpenVZ systems only · 1995994 · centminmod/centminmod · GitHub as missing OpenVZ check..
    so only if you use OpenVZ VPS should disable IPSET in CSF Firewall using commands below
    rm -rf /etc/csf/csf.error
    sed -i 's/LF_IPSET = "1"/LF_IPSET = "0"/g' /etc/csf/csf.conf
    csf -r
  8. JarylW
    216
    41
    Singapore
    6:14 AM
    Hi, thanks for replying. I'm afraid it's already 'sanitized'(?) - I've changed the password to random characters manually - they do not reflect real values.
    Indeed, I am using OpenVZ. and running your suggested commands seemed to have fixed it. Will future centminmod autoinstaller script on openvz vps require running the commands too?
    59,946
    12,556
    8:14 AM
  10. JarylW
    216
    41
    Singapore
    6:14 AM
    Oh sorry, because commit was named for non-OpenVZ systems - it confused me
    Anwyay, I wiped test VPS and re-run
    curl -sL https://gist.github.com/centminmod/dbe765784e03bc4b0d40/raw/installer.sh | bash
    I still get that same csf error. Even after running your commands, once the vps is rebooted, it becomes inaccesible, and the only way to access it again is to rebuild the vm. Wondering what's going on :(
    59,946
    12,556
    8:14 AM
    what does commands output
    grep LF_IPSET /etc/csf/csf.conf
    yum -q list ipset*
  12. JarylW
    216
    41
    Singapore
    6:14 AM
    $ grep LF_IPSET /etc/csf/csf.conf
    LF_IPSET = "1"
    $ yum -q list ipset*
    Installed Packages
    ipset.x86_64 6.19-4.el7 @base
    ipset-devel.x86_64 6.19-4.el7 @base
    ipset-libs.x86_64 6.19-4.el7 @base
    59,946
    12,556
    8:14 AM
    so for some reason LF_IPSET is still set to 1 for OpenVZ systems... i use /proc/user_beancounters to determine if OpenVZ is used.. do you have that file ?
    ls -lah /proc/user_beancounters
    -r-------- 1 root root 0 Dec 15 08:00 /proc/user_beancounters
  14. JarylW
    216
    41
    Singapore
    6:14 AM
    Yes I do.
    [root@dallas ~]# ls -lah /proc/user_beancounters
    -r-------- 1 nginx root 0 Dec 15 13:02 /proc/user_beancounters
    [root@dallas ~]# cd /proc/
    [root@dallas proc]# ls -a
    .   1    122  18756  21844  21847  21861  22184  22521  28464  29528  3    359  4419  cgroups  cpuinfo  fairsched   filesystems  kmsg     locks    modules  net         self  swaps  sysrq-trigger  uptime             version  vz
    ..  109  125  2      21846  21860  21872  22238  28395  29527  29529  350  363  63    cmdline  devices  fairsched2  fs           loadavg  meminfo  mounts   partitions  stat  sys    sysvipc        user_beancounters  vmstat
    For info also, here is centos version / kernel
    [root@dallas proc]# cat /etc/*-release
    1.2.3-eva2000.08
    CentOS Linux release 7.0.1406 (Core)
    NAME="CentOS Linux"
    VERSION="7 (Core)"
    ID="centos"
    ID_LIKE="rhel fedora"
    VERSION_ID="7"
    PRETTY_NAME="CentOS Linux 7 (Core)"
    ANSI_COLOR="0;31"
    CPE_NAME="cpe:/o:centos:centos:7"
    HOME_URL="https://www.centos.org/"
    BUG_REPORT_URL="https://bugs.centos.org/"
    [root@dallas proc]# uname -a
    Linux dallas.jarylwang.com 2.6.32-042stab094.7 #1 SMP Wed Oct 22 12:43:21 MSK 2014 x86_64 x86_64 x86_64 GNU/Linux
    [root@dallas proc]# cat /proc/version
    Linux version 2.6.32-042stab094.7 (root@kbuild-rh6-x64) (gcc version 4.4.6 20120305 (Red Hat 4.4.6-4) (GCC) ) #1 SMP Wed Oct 22 12:43:21 MSK 2014
    59,946
    12,556
    8:14 AM
  16. JarylW
    216
    41
    Singapore
    6:14 AM
    selinxcheck() {
            # check if selinux is disabled, if not abort and prompt to reboot
            if [[ -z $(sestatus | grep disabled) && -f /etc/selinux/config ]]; then
                    echo "---------------------------------------------------------------"
                    echo "SELINUX linux detected"
                    echo "disabling SELINUX..."
                    echo "will require a server reboot before running initial install"
                    sleep 3
                    sed -i 's/SELINUX=enforcing/SELINUX=disabled/g' /etc/selinux/config && setenforce 0
                    sed -i 's/SELINUX=permissive/SELINUX=disabled/g' /etc/selinux/config && setenforce 0
                    echo
                    echo "SELINUX disabled, please reboot server and rerun install"
                    echo "on reboot you can find the centmin.sh file located at:"
                    echo "echo $(pwd)"
                    exit 0
            fi
    centaltoff() {
            if [[ -f /etc/yum.repos.d/centalt.repo ]]; then
                    sed -i 's/enabled=1/enabled=0/g' /etc/yum.repos.d/centalt.repo
                    yum clean all -q
            fi
    csfipsetcheck() {
            if [ ! -f /proc/user_beancounters ]; then
            if [[ ! -f /usr/sbin/ipset || ! -f /usr/include/libipset/data.h ]]; then
                    yum -y -q install ipset ipset-devel
                    sed -i 's/LF_IPSET = "0"/LF_IPSET = "1"/g' /etc/csf/csf.conf
            fi
            fi
    cpcheck() {
    if [ -f /var/cpanel/cpanel.config ]; then
    echo "WHM/Cpanel detected.. centmin mod NOT compatible"
    echo "aborting script..."
    exit
    fi
    if [ -f /etc/psa/.psa.shadow ]; then
    echo "Plesk detected.. centmin mod NOT compatible"
    exit
    fi
    if [ -f /etc/init.d/directadmin ]; then
    echo "DirectAdmin detected.. centmin mod NOT compatible"
    exit
    fi
    selinxcheck
    centaltoff
    csfipsetcheck
    Apparently it does.
    59,946
    12,556
    8:14 AM
    That suggests you do not have the updated .08 beta code - you missing the csfipsetcheck function seen here in lines 28-35 and line 59 at centminmod/cpcheck.inc at 1995994ec936f05b3695ea5ba84a54c391022f4c · centminmod/centminmod · GitHub
    I've updated .08 beta for further changes see detection improvements for OpenVZ systems and IPSET disabling · 4b5d5d5 · centminmod/centminmod · GitHub
    so suggest you use latest .08 beta code and after download zip AND before running verify if inc/cpcheck.inc and inc/csfinstall.inc have the right contents as per centminmod/cpcheck.inc at 4b5d5d5a2404e621b68dc8e7193ebb59a8093114 · centminmod/centminmod · GitHub and centminmod/csftweaks.inc at 4b5d5d5a2404e621b68dc8e7193ebb59a8093114 · centminmod/centminmod · GitHub
  18. JarylW
    216
    41
    Singapore
    6:14 AM
    I actually checked the file on wrong vps , I've since edited my post, I did have the appropriate lines.
    I will rebuild the VPS again and try. I actually ran the one click installer.sh. I will download , untar and verify before running ./centmin.sh instead.
    Still, even with LF_IPSET=0 set manually, something is borked, and the vps reboot will not allow any sort of connection to the ip address (ping returns no result too).
    EDIT: I mean nothing runs on the VPS after reboot after initial centminmod install (I believe so), since the control panel reflect ram usage at 18 MB :'(
    59,946
    12,556
    8:14 AM
    strange
    try the same installer but with CentOS 6.6 and see.. could be specific to CentOS 7.0 + OpenVZ - a combination I haven't tested yet as all my CentOS 7.0 tests are with Xen or KVM VPS
  20. JarylW
    216
    41
    Singapore
    6:14 AM
    @eva2000
    CentOS 6.6 Install on OpenVZ
    LF_IPSET = 0 <- correct
    yum -q list ipset*
    ipset.x86_64 6.11-3.el6 @base
    ipset-devel.x86_64 6.11-3.el6 @base
    Rebooting the VPS after centminmod install also fine - works as intended out of the box. I guess it is an issue with OpenVZ & CentOS 7.
