    1:26 AM
    what do you get from commands
    yum list libmcrypt -q
    php --ri mcrypt
    hmm just checked and indeed mcrypt is not loaded in PHP
    Installed Packages
    libmcrypt.x86_64                                                               2.5.8-13.el7                                                               @epel
    php --ri mcrypt
    Extension 'mcrypt' not present.
  2. GhoHan
    GhoHan Member
    33
    14
    10:26 PM
    Nginx 1.13.X
    MariaDB 10.1.X
    Yes mcrypt is not loaded in PHP
    # yum list libmcrypt -q
    Installed Packages
    # php --ri mcrypt
    1:26 AM
    ah i see, my mistake - in .08 beta line 1191 of centmin.sh i forgot to allow CentOS 7 in the version check - will fix that in a few minutes :D
  4. GhoHan
    GhoHan Member
    33
    14
    10:26 PM
    Nginx 1.13.X
    MariaDB 10.1.X
    yeah you forget add
    $CENTOSVER" == '7.0'
    1:26 AM
  6. GhoHan
    GhoHan Member
    33
    14
    10:26 PM
    Nginx 1.13.X
    MariaDB 10.1.X
    1:26 AM
    You're welcome.. thanks for the feedback and bug report - making Centmin Mod better :D
  8. rdan
    11:26 PM
    From this post: CentOS 7.x - How to help test .08 CentOS 7 Betas with Github code ? | Page 6 | Centmin Mod Community
    So from:
    [remi]
    name=Les RPM de remi pour Enterprise Linux 6 - $basearch
    #baseurl=http://rpms.famillecollet.com/enterprise/6/remi/$basearch/
    mirrorlist=http://rpms.famillecollet.com/enterprise/6/remi/mirror
    enabled=0
    gpgcheck=1
    gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-remi
    [remi-php55]
    name=Les RPM de remi de PHP 5.5 pour Enterprise Linux 6 - $basearch
    #baseurl=http://rpms.famillecollet.com/enterprise/6/php55/$basearch/
    mirrorlist=http://rpms.famillecollet.com/enterprise/6/php55/mirror
    # WARNING: If you enable this repository, you must also enable "remi"
    enabled=0
    gpgcheck=1
    [remi-php56]
    name=Les RPM de remi de PHP 5.6 pour Enterprise Linux 6 - $basearch
    #baseurl=http://rpms.famillecollet.com/enterprise/6/php56/$basearch/
    mirrorlist=http://rpms.famillecollet.com/enterprise/6/php56/mirror
    enabled=0
    gpgcheck=1
    [remi-test]
    name=Les RPM de remi en test pour Enterprise Linux 6 - $basearch
    #baseurl=http://rpms.famillecollet.com/enterprise/6/test/$basearch/
    mirrorlist=http://rpms.famillecollet.com/enterprise/6/test/mirror
    enabled=0
    gpgcheck=1
    [remi-debuginfo]
    name=Les RPM de remi pour Enterprise Linux 6 - $basearch - debuginfo
    baseurl=http://rpms.famillecollet.com/enterprise/6/debug-remi/$basearch/
    enabled=0
    gpgcheck=1
    [remi-php55-debuginfo]
    name=Les RPM de remi de PHP 5.5 pour Enterprise Linux 6 - $basearch - debuginfo
    baseurl=http://rpms.famillecollet.com/enterprise/6/debug-php55/$basearch/
    enabled=0
    gpgcheck=1
    [remi-php56-debuginfo]
    name=Les RPM de remi de PHP 5.6 pour Enterprise Linux 6 - $basearch - debuginfo
    baseurl=http://rpms.famillecollet.com/enterprise/6/debug-php56/$basearch/
    enabled=0
    gpgcheck=1
    [remi-test-debuginfo]
    name=Les RPM de remi en test pour Enterprise Linux 6 - $basearch - debuginfo
    baseurl=http://rpms.famillecollet.com/enterprise/6/debug-test/$basearch/
    enabled=0
    gpgcheck=1
    It will become:
    [remi]
    enabled=0
    gpgcheck=1
    priority=9
    exclude=php* mysql*
    [remi-php55]
    enabled=0
    gpgcheck=1
    [remi-php56]
    enabled=0
    gpgcheck=1
    [remi-test]
    enabled=0
    gpgcheck=1
    [remi-debuginfo]
    enabled=0
    gpgcheck=1
    enabled=0
    gpgcheck=1
    enabled=0
    gpgcheck=1
    enabled=0
    gpgcheck=1
  9. rdan
    11:26 PM
    Looks working fine.
    # php --ri imagick
    imagick
    imagick module => enabled
    imagick module version => 3.2.0RC1
    imagick classes => Imagick, ImagickDraw, ImagickPixel, ImagickPixelIterator
    ImageMagick version => ImageMagick 6.8.9-10 Q16 x86_64 2014-11-05 http://www.imagemagick.org
    ImageMagick copyright => Copyright (C) 1999-2014 ImageMagick Studio LLC
    ImageMagick release date => 2014-11-05
    ImageMagick number of supported formats:  => 212
    ImageMagick supported formats => 3FR, AAI, AI, ART, ARW, AVI, AVS, BGR, BGRA, BMP, BMP2, BMP3, BRF, CAL, CALS, CANVAS, CAPTION, CIN, CIP, CLIP, CMYK, CMYKA, CR2, CRW, CUR, CUT, DCM, DCR, DCX, DDS, DFONT, DNG, DOT, DPX, DXT1, DXT5, EPDF, EPI, EPS, EPS2, EPS3, EPSF, EPSI, EPT, EPT2, EPT3, ERF, EXR, FAX, FITS, FRACTAL, FTS, G3, GIF, GIF87, GRADIENT, GRAY, GROUP4, GV, HALD, HDR, HISTOGRAM, HRZ, HTM, HTML, ICB, ICO, ICON, INFO, INLINE, IPL, ISOBRL, JNG, JNX, JPEG, JPG, JSON, K25, KDC, LABEL, M2V, M4V, MAC, MAP, MASK, MAT, MATTE, MEF, MIFF, MNG, MONO, MOV, MP4, MPC, MPEG, MPG, MRW, MSL, MSVG, MTV, MVG, NEF, NRW, NULL, ORF, OTB, OTF, PAL, PALM, PAM, PANGO, PATTERN, PBM, PCD, PCDS, PCL, PCT, PCX, PDB, PDF, PDFA, PEF, PES, PFA, PFB, PFM, PGM, PICON, PICT, PIX, PJPEG, PLASMA, PNG, PNG00, PNG24, PNG32, PNG48, PNG64, PNG8, PNM, PPM, PREVIEW, PS, PS2, PS3, PSB, PSD, PTIF, PWP, RADIAL-GRADIENT, RAF, RAS, RAW, RGB, RGBA, RGBO, RGF, RLA, RLE, RMF, RW2, SCR, SCT, SFW, SGI, SHTML, SIX, SIXEL, SPARSE-COLOR, SR2, SRF, STEGANO, SUN, SVG, SVGZ, TEXT, TGA, THUMBNAIL, TIFF, TIFF64, TILE, TIM, TTC, TTF, TXT, UBRL, UIL, UYVY, VDA, VICAR, VID, VIFF, VIPS, VST, WBMP, WEBP, WMF, WMV, WMZ, WPG, X, X3F, XBM, XC, XCF, XPM, XPS, XV, XWD, YCbCr, YCbCrA, YUV
    imagick.locale_fix => 0 => 0
    imagick.progress_monitor => 0 => 0
    1:26 AM
    yup looks good :)
  11. Josephm
    Josephm Active Member
    132
    44
    10:26 PM
    1.9.5
    10.0.21
    Is there any current maintenance your beta script? I can't install from my local pc & my vps server.
    [root@centos7test centminmod-123.08centos7beta01]# ./centmin.sh
    inc/memcheck.inc: line 12: bc: command not found
    inc/memcheck.inc: line 13: bc: command not found
    installing lynx...
    bc not found !!
    installing bc
    bc installed
    aborting script...
    please re-run centmin.sh again for install
    1:26 AM
    See last line, tells you to re-run centmin.sh now ;)
    if you ran it via command line installer, bc package would automatically be installed
    curl -sL https://gist.github.com/centminmod/dbe765784e03bc4b0d40/raw/installer.sh | bash
    if you ran install via manual method outlined at centminmod/centminmod at 123.08centos7beta01 · GitHub you would of manually installed bc via yum ;)
  13. Josephm
    132
    44
    10:26 PM
    1.9.5
    10.0.21
    Sorry eva2000, I pasted wrong section in my local pc.
    However, I bought one cloud vps at turnkeyinternet with blackfriday deal. The funny thing happened, when I entered "
    ./centmin.sh install". It hung! nothing shown even error. I checked top command, /var/log/ but nothing too. I suspect their give-away is so hassle.
    SELINUX=disabled currently.
    Do you have any commands to track if the script running or stuck somewhere? Or the log in the system?
    They used Xen PV for virtualization.
    1:26 AM
    it should run you can open a 2nd ssh window while first one is hung and type
    ps aufx
    and see what centmin.sh processes are doing could be a slow YUM mirror etc
  15. Josephm
    132
    44
    10:26 PM
    1.9.5
    10.0.21
    I successfully installed centminmod in my turnkeyinternet cloud.
    [root@zeus centminlogs]# tail centminmod_1.2.3-eva2000.08_031214-031634_install.log
    unsupported source language  61
    autoconf compile/link  544
    unsupported compiler option  14
    no input file  122
    files in cache  5716
    cache size  144.8 Mbytes
    max cache size  2.0 Gbytes
    Total Centmin Mod Install Time: 2704.647919091 seconds
    The problem came from the lynx/fedoraproject request yesterday:
    [root@zeus centminmod-123.08centos7beta01]# ./centmin.sh install
    setting up /svr-setup on tmpfs ramdisk for initial install
    Filesystem  Type  Size  Used Avail Use% Mounted on
    /dev/xvda1  ext3  40G  1.1G  37G  3% /
    devtmpfs  devtmpfs  2.0G  0  2.0G  0% /dev
    tmpfs  tmpfs  2.0G  0  2.0G  0% /dev/shm
    tmpfs  tmpfs  2.0G  17M  2.0G  1% /run
    tmpfs  tmpfs  2.0G  0  2.0G  0% /sys/fs/cgroup
    tmpfs  tmpfs  2.2G  0  2.2G  0% /svr-setup
    installing lynx...
    root  9425  0.0  0.1 133740  5212 ?  Ss  02:46  0:00  \_ sshd: root@pts/0
    root  9427  0.0  0.0  11744  1856 pts/0  Ss  02:46  0:00  |  \_ -bash
    root  9518  0.1  0.0  9904  1736 pts/0  S+  02:52  0:00  |  \_ /bin/sh ./centmin.sh install
    root  9582  0.0  0.0  9904  968 pts/0  S+  02:52  0:00  |  \_ /bin/sh ./centmin.sh install
    root  9583  0.1  0.0  46408  2924 pts/0  S+  02:52  0:00  |  \_ lynx -dump -listonly http://download.fedoraproject.org/pub/epel/7/x86_64/repoview/e
    root  9586  0.0  0.0  0  0 pts/0  Z+  02:52  0:00  |  |  \_ [lynx] <defunct>
    root  9584  0.0  0.0  9032  676 pts/0  S+  02:52  0:00  |  \_ grep rpm
    root  9585  0.0  0.0  9872  728 pts/0  S+  02:52  0:00  |  \_ awk -F  {print $2}
    Now unfortunately, I have another issue with nginx service, I can't use command 'nprestart'
    I check the log and saw nginx start failed but I can access the homepage, not sure why...
    [root@zeus centminlogs]# nprestart
    Restarting nginx (via systemctl):  Job for nginx.service failed. See 'systemctl status nginx.service' and 'journalctl -xn' for details.
      [FAILED]
    Gracefully shutting down php-fpm  done
    Starting php-fpm  done
    [root@zeus centminlogs]# systemctl status nginx.service
    nginx.service - SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server
      Loaded: loaded (/etc/rc.d/init.d/nginx)
      Active: failed (Result: timeout) since Wed 2014-12-03 04:12:34 UTC; 25s ago
      Process: 1497 ExecStart=/etc/rc.d/init.d/nginx start (code=exited, status=0/SUCCESS)
      CGroup: /system.slice/nginx.service
      ├─1218 nginx: master process /usr/local/sbin/nginx -c /usr/local/nginx/conf/nginx....
      └─1219 nginx: worker process
    Dec 03 04:07:34 zeus.com systemd[1]: Starting SYSV: Nginx is an HTTP(S) server, HTTP(S) re......
    Dec 03 04:07:34 zeus.com systemd[1]: PID file /usr/local/nginx/logs/nginx.pid not readable...rt.
    Dec 03 04:12:34 zeus.com systemd[1]: nginx.service operation timed out. Terminating.
    Dec 03 04:12:34 zeus.com systemd[1]: Failed to start SYSV: Nginx is an HTTP(S) server, HTT...er.
    Dec 03 04:12:34 zeus.com systemd[1]: Unit nginx.service entered failed state.
    Hint: Some lines were ellipsized, use -l to show in full.
    My centminmod log before:
    Check Nginx Version:
    nginx version: nginx/1.7.8
    built by gcc 4.8.2 20140120 (Red Hat 4.8.2-16) (GCC)
    TLS SNI support enabled
    configure arguments: --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_ssl_module --with-http_gzip_static_module --with-http_stub_status_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module --with-http_secure_link_module --with-http_flv_module --with-http_realip_module --with-openssl-opt=enable-tlsext --add-module=../ngx-fancyindex-ngx-fancyindex --add-module=../ngx_cache_purge-2.1 --add-module=../headers-more-nginx-module-0.25 --add-module=../nginx-accesskey-2.0.3 --add-module=../nginx-http-concat-master --with-http_dav_module --add-module=../nginx-dav-ext-module-0.0.3 --add-module=../openresty-memc-nginx-module-1518da4 --add-module=../openresty-srcache-nginx-module-ffa9ab7 --add-module=../nginx-sticky-module-1.2.5 --add-module=../nginx_upstream_check_module-0.1.9 --with-openssl=../openssl-1.0.1j --with-libatomic --with-pcre=../pcre-8.36 --with-pcre-jit --with-http_spdy_module --add-module=../ngx_pagespeed-release-1.9.32.2-beta
    unmount /svr-setup tmpfs ramdisk & copy back to disk
    service nginx stop
    Stopping nginx (via systemctl):  [  OK  ]
    service php-fpm stop
    service memcached stop
    Memcached server stopped
    service nginx start
    Starting nginx (via systemctl):  Job for nginx.service failed. See 'systemctl status nginx.service' and 'journalctl -xn' for details.
    [FAILED]
    service php-fpm start
    service memcached start
    Memcached server started
    Thanks for your advice.
    1:26 AM
    fedora link must of had issues to slow your previous attempt
    so service nginx restart works ? or just ngxrestart and nprestart also don't work ?
    try killing all nginx processes and a restart
  17. Josephm
    132
    44
    10:26 PM
    1.9.5
    10.0.21
    I tried to stop all nginx services but ps command still showing it:
    [root@zeus centminmod-123.08centos7beta01]# service nginx stop
    [root@zeus centminlogs]# ps auxf|grep nginx
    root  2478  0.0  0.0  9032  676 pts/1  S+  04:48  0:00  \_ grep --color=auto nginx
    root  2417  0.0  0.0 118600  2728 ?  Ss  04:46  0:00 nginx: master process /usr/local/sbin/nginx -c /usr/local/nginx/conf/nginx.conf
    nginx  2418  0.0  0.1 128960  7408 ?  S<l  04:46  0:00  \_ nginx: worker process
    nginx  2419  0.0  0.1 128960  7408 ?  S<l  04:46  0:00  \_ nginx: worker process
    [root@zeus centminlogs]# kill -9 2417
    [root@zeus centminlogs]# kill -9 2418
    [root@zeus centminlogs]# kill -9 2419
    Then I start by ngxstart, it hung for long time then failed. However, new processes were appeared in ps tree.
    [root@zeus centminlogs]# ngxstart
      [FAILED]
      Active: failed (Result: timeout) since Wed 2014-12-03 04:54:48 UTC; 29s ago
      Process: 2528 ExecStart=/etc/rc.d/init.d/nginx start (code=exited, status=0/SUCCESS)
    Dec 03 04:49:48 zeus.com systemd[1]: Starting SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server...
    Dec 03 04:49:48 zeus.com nginx[2528]: Starting nginx: [  OK  ]
    Dec 03 04:49:48 zeus.com systemd[1]: PID file /usr/local/nginx/logs/nginx.pid not readable (yet?) after start.
    Dec 03 04:54:48 zeus.com systemd[1]: nginx.service operation timed out. Terminating.
    Dec 03 04:54:48 zeus.com systemd[1]: Failed to start SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server.
    Dec 03 04:54:48 zeus.com systemd[1]: Unit nginx.service entered failed state.
    [root@zeus centminmod-123.08centos7beta01]# ps auxf|grep nginx
    root  2671  0.0  0.0  9032  676 pts/0  S+  04:55  0:00  |  \_ grep --color=auto nginx
    root  2535  0.0  0.0 118600  2732 ?  Ss  04:49  0:00 nginx: master process /usr/local/sbin/nginx -c /usr/local/nginx/conf/nginx.conf
    nginx  2536  0.0  0.1 128960  7412 ?  S<l  04:49  0:00  \_ nginx: worker process
    nginx  2537  0.0  0.1 128960  7412 ?  S<l  04:49  0:00  \_ nginx: worker process
    Guess the system said failed but nginx is still working. My homepage still working too.
    1:26 AM
    try
    killall nginx
  19. Josephm
    132
    44
    10:26 PM
    1.9.5
    10.0.21
    Still same issue, will test another installation:
    [root@zeus centminmod-123.08centos7beta01]# killall nginx
    root  7974  0.0  0.0  9032  672 pts/0  S+  06:16  0:00  |  \_ grep --color=auto nginx
    [root@zeus centminmod-123.08centos7beta01]# ngxstart
      [FAILED]
    root  8124  0.0  0.0  9032  672 pts/0  S+  06:22  0:00  |  \_ grep --color=auto nginx
    root  7999  0.0  0.0 118600  2732 ?  Ss  06:16  0:00 nginx: master process /usr/local/sbin/nginx -c /usr/local/nginx/conf/nginx.conf
    nginx  8000  0.0  0.1 128960  7412 ?  S<l  06:16  0:00  \_ nginx: worker process
    nginx  8001  0.0  0.1 128960  7412 ?  S<l  06:16  0:00  \_ nginx: worker process
  20. Josephm
    132
    44
    10:26 PM
    1.9.5
    10.0.21
    Just come back for confirmation; I tried to install many times and saw that my local vmware ran smoothly without nginx service problem. Not sure why turnkey internet cloud had problem ( I re-installed many times too), suspect their centos 7 template have problem or hardware incompatible with nginx?
    when I added vhost:
      Centmin Mod Menu
    1).  Centmin Install
    2).  Add Nginx vhost domain
    22). Exit
    Enter option [ 1 - 22 ] 2
    Enter vhost domain name you want to add (without www. prefix): testdomain.com
    service nginx reload
    Reloading nginx configuration (via systemctl):  Job for nginx.service failed. See 'systemctl status nginx.service' and 'journalctl -xn' for details.
    [FAILED]
    vhost for testdomain.com created successfully
    vhost conf file for testdomain.com created: /usr/local/nginx/conf/conf.d/testdomain.com.conf
    upload files to /home/nginx/domains/testdomain.com/public
    vhost log files directory is /home/nginx/domains/testdomain.com/log
    Current vhost listing at: /usr/local/nginx/conf/conf.d/
    I uploaded my installation log, I found nothing for the reason. Hope you will find something interesting
    https://gist.github.com/josephmike2...minmod_1.2.3-eva2000.08_051214-102548_install
    Note that even restart/stop/start command for nginx hung with error. The webpage is working anyway....
