How to get a backup of a box running?
Discussion in 'System Administration' started by MyWin, Jan 26, 2021.
  1. MyWin
    MyWin New Member
    5
    11:34 AM
    I want to test an upgrade using a backup of my box.
    I've disabled the firewall (csf -x) and after getting a bind() to (production ip) edited the conf file to remove the SSL stuff, IP stuff and redirects
    But I can't seem to connect to it with putty/browser or ftp.
    The only error I get is worker process exited on signal 9
    Is there something more I should be doing in order to get the backup working for test purposes?
    thanks
    55,796
    12,271
    8:34 PM
    Do not disable CSF Firewall as that can prevent some predefined ports from being whitelisted. Instead whitelist the remote server IP in CSF Firewall CSF Firewall - CentminMod.com LEMP Nginx web stack for CentOS and if remote backup server runs Centmin Mod/CSF Firewall, then whitelist source server IP on remote server's CSF Firewall.
  3. MyWin
    MyWin New Member
    5
    11:34 AM
    Thanks that's useful to know!
    Sadly I don't think it's the firewall stopping the droplet restored from a backup working though, will keep investigating :)
    EDIT, that along with wiping the production stuff from the conf file has worked. Thanks so much @eva2000 :D
    55,796
    12,271
    8:34 PM
    Glad to hear :)
