Wordpress How to fix 404 not found nginx problem with webp
Discussion in 'Blogs & CMS usage' started by kinhatula, Oct 8, 2017.
  1. kinhatula
    kinhatula New Member
    7
    8:48 AM
    This code in conf file, Please help me, Domain: hangmygiasi.net
    # For HTTP/2 SSL Setup
    # server {
    #       listen   80;
    #       server_name hangmygiasi.net www.hangmygiasi.net;
    #       return 302 https://$server_name$request_uri;
      listen 443 ssl http2;
      include /usr/local/nginx/conf/ssl/hangmygiasi.net/hangmygiasi.net.crt.key.conf;
      http2_max_field_size 16k;
      http2_max_header_size 32k;
      # mozilla recommended
      ssl_ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS;
      #spdy_headers_comp 5;
      ssl_buffer_size 1369;
      ssl_session_tickets on;
      # enable ocsp stapling
      resolver_timeout 10s;
      ssl_stapling on;
      ssl_stapling_verify on;
      # ssi  on;
      access_log /home/nginx/domains/hangmygiasi.net/log/access.log combined buffer=256k flush=5m;
      error_log /home/nginx/domains/hangmygiasi.net/log/error.log;
      include /usr/local/nginx/conf/autoprotect/hangmygiasi.net/autoprotect-hangmygiasi.net.conf;
      root /home/nginx/domains/hangmygiasi.net/public;
      # server and/or vhost site
      location /wp-content/uploads/ {
      #pagespeed off;
      autoindex off;
      #add_header X-Robots-Tag "noindex, nofollow";
      location ~* ^/wp-content/uploads/.+\.(png|jpe?g)$ {
        expires 30d;
        add_header Vary "Accept-Encoding";
        add_header Cache-Control "public, no-transform";
        try_files $uri$webp_extension $uri =404;
      include /usr/local/nginx/conf/pre-staticfiles-local-hangmygiasi.net.conf;
  2. Jon Snow
    Jon Snow Active Member
    368
    60
    10:48 PM
    Nginx 1.13.9
    MariaDB 10.1.31
    Seems like you've already solved the issue.
  3. kinhatula
    7
    8:48 AM
    solved, thank You.
    35,049
    7,738
    11:48 AM
    might help other folks too if you provide the fix/solution too :)
