how to ensure ngx-pagespeed is not running?
Discussion in 'Install & Upgrades or Pre-Install Questions' started by tonmo, Jan 1, 2020.
  1. tonmo
    tonmo Member
    36
    10:55 AM
    1.17.1
    5.5.5 (10.3.16-MariaDB)
    Hi, how can I best uninstall or ensure ngx-pagespeed is not running? I think I installed it some months back but I'm now on cloudflare and would like to ensure it's disabled on my server.
    • CentOS Version: CentOS 7.7
    • Nginx Version Installed: 1.17.7
    • PHP Version Installed: 7.4.1
    • MariaDB MySQL Version Installed: 10.3.21
    • When was last time updated Centmin Mod code base ? : yesterday
      Post output in CODE tags.
    LOL i think step above told me what I need to do
    LETSENCRYPT_DETECT='y'
    NGINX_PAGESPEED=y
  2. pamamolf
    3,826
    370
    5:55 PM
    Nginx-1.17.x
    Hello tonmo :)
    Happy new year :)
    To disable it you can run from ssh:
    pscontrol off
    At your custom config you can remove that line or set it to "n" :
    NGINX_PAGESPEED=n
    Also check at your domain config file:
    /usr/local/nginx/conf/conf.d/yourdomain.com.conf
    for any pagespeed include files and if yes then comment them as:
    Then restart nginx and php:
    nprestart
    44,743
    10,201
    12:55 AM
    ngx_pagespeed isn't enabled by default unless you recompiled Nginx with it enabled as outlined at https://centminmod.com/nginx_ngx_pagespeed.html with NGINX_PAGESPEED='y' enabled in persistent config file at /etc/centminmod/custom_config.inc
    what's output of
    nginx -V
  4. Nik
    Nik Member
    67
    10:55 AM
    Fresh 7 day old centmin install using beta-latest.sh and seems like nginx_pagespeed is set to y by default.
    Just FYI.
    44,743
    10,201
    12:55 AM
    yes betainstaller-latest.sh enables ngx_pagespeed by default as intended = latest
    if you don't want ngx_pagespeed use betainstaller.sh or betainstaller73.sh for php 7.3
