Nginx How to Connection = keep-alive?
Discussion in 'Centmin Mod Insights' started by rdan, Jul 10, 2014.
    rdan Premium Member Premium Member
    4,444
    1,069
    2:05 AM
    37,710
    8,255
    4:05 AM
    did you enable php.conf include file /usr/local/nginx/conf/php.conf settings to disable php keep alives ?
    # might shave 200+ ms off PHP requests
    # which don't pass on a content length header
    # slightly faster page response time at the
    # expense of throughput / scalability
    #sendfile on;
    #tcp_nopush off;
    #keepalive_requests 0;
    i have keep alives enabled as I am using multiple php-fpm pools with upstream keepalive set
  3. rdan
    4,444
    1,069
    2:05 AM
    Here's what I have:
    location ~ \.php$ {
        try_files $uri =404;
        fastcgi_split_path_info ^(.+\.php)(/.+)$;
        fastcgi_pass   127.0.0.1:9000;
        #fastcgi_pass   unix:/tmp/php5-fpm.sock;
        fastcgi_index  index.php;
        #fastcgi_param  SCRIPT_FILENAME  $document_root$fastcgi_script_name;
        fastcgi_param  SCRIPT_FILENAME    $request_filename;
    sendfile on;
    tcp_nopush off;
    fastcgi_connect_timeout 60;
    fastcgi_send_timeout 180;
    fastcgi_read_timeout 180;
    fastcgi_buffer_size 512k;
    fastcgi_buffers 512 16k;
    fastcgi_busy_buffers_size 512k;
    fastcgi_temp_file_write_size 512k;
    fastcgi_intercept_errors on;
    # old pre .03 method
    #fastcgi_param HTTPS on;
    #new .04+ map method
    fastcgi_param HTTPS $server_https;
    # comment out PATH_TRANSLATED line if /usr/local/lib/php.ini sets following:
    # cgi.fix_pathinfo=0
    # as of centminmod v1.2.3-eva2000.01 default is set to cgi.fix_pathinfo=1
    fastcgi_param  PATH_INFO          $fastcgi_path_info;
    fastcgi_param  PATH_TRANSLATED    $document_root$fastcgi_path_info;
    fastcgi_param  QUERY_STRING       $query_string;
    fastcgi_param  REQUEST_METHOD     $request_method;
    fastcgi_param  CONTENT_TYPE       $content_type;
    fastcgi_param  CONTENT_LENGTH     $content_length;
    fastcgi_param  SCRIPT_NAME        $fastcgi_script_name;
    fastcgi_param  REQUEST_URI        $request_uri;
    fastcgi_param  DOCUMENT_URI       $document_uri;
    fastcgi_param  DOCUMENT_ROOT      $document_root;
    fastcgi_param  SERVER_PROTOCOL    $server_protocol;
    fastcgi_param  GATEWAY_INTERFACE  CGI/1.1;
    fastcgi_param  SERVER_SOFTWARE    nginx/$nginx_version;
    fastcgi_param  REMOTE_ADDR        $remote_addr;
    fastcgi_param  REMOTE_PORT        $remote_port;
    fastcgi_param  SERVER_ADDR        $server_addr;
    fastcgi_param  SERVER_PORT        $server_port;
    fastcgi_param  SERVER_NAME        $server_name;
    # PHP only, required if PHP was built with --enable-force-cgi-redirect
    fastcgi_param  REDIRECT_STATUS    200;
                       }location ~ \.php$ {
    sendfile on;
    tcp_nopush off;
    37,710
    8,255
    4:05 AM
    yeah you turned off keepalives to get potentially faster PHP request response times
    I kept keepalives as I am using multiple php-fpm pools in upstream keep alive state
  5. rdan
    4,444
    1,069
    2:05 AM
    Can you please create a tutorial on how to implement this?
    Thanks You very much!
  6. rdan
    4,444
    1,069
    2:05 AM
    Which is better and optimal? Just comment it out?
    Please advice.
    37,710
    8,255
    4:05 AM
    Already answered back on G+ Community at https://plus.google.com/118067102985043487274/posts/jm8rYbs8WuC
    Already mentioned it at https://community.centminmod.com/threads/switch-from-tcp-to-unix-domain-sockets.307/#post-1442 but you're on your own regarding implementing that as Centmin Mod is probably best left using the single PHP-FPM pool for future Centmin Mod upgrade compatibility unless you want to break upgrades and future features that assume a single PHP-FPM pool is in use.
  8. rdan
    4,444
    1,069
    2:05 AM
    With this settings:
    sendfile on;
    tcp_nopush off;
    Equals =
    And with this settings commented out:
    #sendfile on;
    #tcp_nopush off;
    Equals =
    Am I right ?
    37,710
    8,255
    4:05 AM
    reverse them ;)
  10. rdan
    4,444
    1,069
    2:05 AM
    hahah my bad OK :D
    Thanks!
  11. rdan
    4,444
    1,069
    2:05 AM
    37,710
    8,255
    4:05 AM
