Nginx How to change default site to load?
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by runos, Mar 1, 2020.
  1. runos
    runos Member
    44
    14
    9:04 PM
    1.17.6
    Hi! I noticed that if I just change the DNS to my server without setting up a site, it points to a default domain. How do I change this default domain?
    Thanks!
    47,837
    10,910
    11:04 PM
    Default index.html is for main hostname you setup in Getting Started Guide step 1. The index.html is in it's own vhost directory in it's public web root at /usr/local/nginx/html as outlined at Centmin Mod Configuration Files - CentminMod.com LEMP Nginx web stack for CentOS
  3. Rake-GH
    Rake-GH Premium Member Premium Member
    177
    90
    USA
    8:04 AM
    default
    default
    use centmin option 2 to setup a vhost for your real site and that will be served instead of the default vhost, once it completes
    47,837
    10,910
    11:04 PM
    oh yes that is right too
    @runos to setup your site properly see Getting Started Guide at Getting Started Guide - CentminMod.com LEMP Nginx web stack for CentOS particularly for new site setup step 2 of the guide as you generally do not need to change main vhost name default Centmin Mod index.html page.
  5. runos
    runos Member
    44
    14
    9:04 PM
    1.17.6
    Currently I'm not seeing any centmin "default page".
    Whenever I add a new domain to cloudflare and point it to my server, this new domain will point to one of my existing domain page (demo.com) by default before I configure the site using either centmin option 2 or 22.
    Is this a cloudflare only issue or something?
    I also deleted the default demo vhost created with the default centmin installation.
    I don't mind if it's a brand new site but for existing site with traffic, the process of migrating takes a few minutes. So I don't want my client or their visitors to freak out seeing another site loaded.
    47,837
    10,910
    11:04 PM
    That is normal as whenever nginx doesn't have a registered created nginx vhost for a domain, it will redirect to the default Centmin Mod index if no other site exists
    You can setup Cloudflare added site with DNS pointed to old server IP until you setup new server and then change DNS to new Centmin Mod server IP.
    Usually then you'd either create the site on it's own dedicated IP or separate VPS server if you have clients. Usually shouldn't be a problem as Centmin Mod wasn't designed for shared hosting but for a person's own sites see FAQ item 2 at FAQ - CentminMod.com LEMP Nginx web stack for CentOS
