How to adjust all admin pages to use same creds?
Discussion in 'Centmin Mod Insights' started by jeffwidman, May 18, 2015.
  1. jeffwidman
    jeffwidman Active Member
    152
    27
    10:06 AM
    It's a bit of a pain to log into the various admin status pages:
    - zend opcache
    - memcache
    - php-fpm
    - nginx pagespeed # I did see the note about needing to be IP-protected
    I'm thinking about making life a little easier on myself, as I only just now noticed my opcache was running out of space and I want it to be easy for me to check these pages so I notice sooner next time...
    Had a few questions:
    1) if I want to make them all have the same username/passwords, will this create problems when upgrading nginx or php? Thinking about making a /usr/local/nginx/html/admin.html page that links to the different status pages, and if they all have the same creds, then once I'm in and the cookie is set I can access them all no problem.
    2) Where is the nginx conf file that locks down the memcache_xxx.php file? I grepped but wasn't finding it.
    3) Any reason to not move them to /memcache.php /opcache.php etc? They'll have strong enough passwords, and I'll probably turn on IP-based protection, wasn't sure if there was another security risk I was unaware of with easily guessable paths, or if modifying these paths will create conflicts when upgrading nginx/php.
    50,481
    11,664
    3:06 AM
    fyi, if you bookmark urls as the following format, you auto input the user/pass without needing to enter it
    http://username:password@ipaddress/protectedarea/
    this allows separate user/pass and never having to enter the user/pass ;)
    2) memcached password is set inside memcached.php file itself there's variables for user/pass
  3. jeffwidman
    152
    27
    10:06 AM
    I never bookmark anything honestly. Plus all my passwords are in Lastpass, I like to keep them there and not worry about keeping updated other places as well.
    Any hints on where the memcache_xx.php file gets locked down?
    50,481
    11,664
    3:06 AM
    50,481
    11,664
    3:06 AM
    hmmm wonder if i can move all the stats admin pages under directory link /adminstats with password protection on that so any stats/admin files located there will be password protected under one password
