Sysadmin How to add a IPv4 Failover Range to CentOS 7?
Discussion in 'System Administration' started by Oxide, Sep 13, 2016.
  1. Oxide
    Oxide Active Member
    534
    29
    7:11 PM
    Hello.
    How can I do this properly on my OVH? I own a IP Range. I added manually each one, by copying eth0 into eth0:1 etc.
    DEVICE="eth0:7"
    BOOTPROTO=static
    IPADDR=1
    NETMASK=255.255.255.255
    ONBOOT=yes
    BROADCAST=1
    1 = is my ip, just removed it though
    54,860
    12,239
    7:11 PM
  3. pamamolf
    4,086
    428
    11:11 AM
    Nginx-1.25.x
    Just to get it right :)
    Now i have:
    and i should create a second file there:
    and add inside:
    DEVICE="eth0:1"
    BOOTPROTO=static
    IPADDR="secondiphere"
    NETMASK="255.255.255.255"
    BROADCAST="providers broadcast"
    ONBOOT=yes
    and just :
    and for a third ip repeat it and add a new file name ifcfg-eth0:2 and so on?
    After restart that will be up again or i must run again ifup eth0:1 ?
    Other than that i should change also the A record for the new ip?
    Can i use two A records with the two ip's that i would set?
    54,860
    12,239
    7:11 PM
    try and see, you can script it with a for sequence loop
    this one just echo/displays the output not create the files themselves nor does it insert contents of files, you can do that if you rewrite the for sequence loop yourself
    example IP range 192.168.2.2 to 192.168.2.10
    for i in {2..10}; do echo -e "\n/etc/sysconfig/network-scripts/ifcfg-eth0:${i}"; echo "
    DEVICE="eth0:$i"
    BOOTPROTO=static
    IPADDR="192.168.2.$i"
    BROADCAST="xxx.xxx.xxx.xxx"
    ONBOOT=yes";
    echo -e "\nifup eth0:${i}";
    done
    gives following display only output
    /etc/sysconfig/network-scripts/ifcfg-eth0:2
    DEVICE=eth0:2
    BOOTPROTO=static
    IPADDR=192.168.2.2
    BROADCAST=xxx.xxx.xxx.xxx
    ONBOOT=yes
    ifup eth0:2
    /etc/sysconfig/network-scripts/ifcfg-eth0:3
    DEVICE=eth0:3
    BOOTPROTO=static
    IPADDR=192.168.2.3
    ONBOOT=yes
    ifup eth0:3
    /etc/sysconfig/network-scripts/ifcfg-eth0:4
    DEVICE=eth0:4
    BOOTPROTO=static
    IPADDR=192.168.2.4
    ONBOOT=yes
    ifup eth0:4
    /etc/sysconfig/network-scripts/ifcfg-eth0:5
    DEVICE=eth0:5
    BOOTPROTO=static
    IPADDR=192.168.2.5
    ONBOOT=yes
    ifup eth0:5
    /etc/sysconfig/network-scripts/ifcfg-eth0:6
    DEVICE=eth0:6
    BOOTPROTO=static
    IPADDR=192.168.2.6
    ONBOOT=yes
    ifup eth0:6
    /etc/sysconfig/network-scripts/ifcfg-eth0:7
    DEVICE=eth0:7
    BOOTPROTO=static
    IPADDR=192.168.2.7
    ONBOOT=yes
    ifup eth0:7
    /etc/sysconfig/network-scripts/ifcfg-eth0:8
    DEVICE=eth0:8
    BOOTPROTO=static
    IPADDR=192.168.2.8
    ONBOOT=yes
    ifup eth0:8
    /etc/sysconfig/network-scripts/ifcfg-eth0:9
    DEVICE=eth0:9
    BOOTPROTO=static
    IPADDR=192.168.2.9
    ONBOOT=yes
    ifup eth0:9
    /etc/sysconfig/network-scripts/ifcfg-eth0:10
    DEVICE=eth0:10
    BOOTPROTO=static
    IPADDR=192.168.2.10
    ONBOOT=yes
    ifup eth0:10
    54,860
    12,239
    7:11 PM
    What you trying to accomplish ? I never used OVH failover IPs, if you have same A record for same dns record then you'd be doing dns round robin.
  6. pamamolf
    4,086
    428
    11:11 AM
    Nginx-1.25.x
    Great thanks :)
  7. pamamolf
    4,086
    428
    11:11 AM
    Nginx-1.25.x
    If the ip fail like getting attacked to use another ip but if it is possible to be automated...
    If it is possible...
    54,860
    12,239
    7:11 PM
  9. SeaTea
    SeaTea Member
    49
    13
    the Netherlands
    10:11 AM
    Nginx:1.11
    MariaDB-10
    If you just need more ip-addresses you do not need to use separate alias files (eth0:x) in Centos-7. You could just use one ifcfg-eth0 file with more "IPADDR" lines with a number.
    Example:
    IPADDR0=123.45.67.89
    PREFIX0=24
    GATEWAY0=123.45.67.1
    IPADDR1=124.56.78.9
    PREFIX1=24
    GATEWAY1=124.56.78.1
    IPADDRx=.....
    PREFIXx=....
    GATEWAYx=....
    54,860
    12,239
    7:11 PM
    indeed you can for CentOS 7 at least Linux Basics: Assign Multiple IP Addresses To Single Network Interface Card On CentOS 7 | Unixmen though trickier to automate like my above for sequence loop if you want to auto insert and create the files :)
    but if you just want to output the line syntax and manually copy and paste with same above example IP range 192.168.2.2 to 192.168.2.10
    for i in {2..10}; do echo "IPADDR${i}=\"192.168.2.${i}\""; done
    Output would be
    IPADDR2="192.168.2.2"
    IPADDR3="192.168.2.3"
    IPADDR4="192.168.2.4"
    IPADDR5="192.168.2.5"
    IPADDR6="192.168.2.6"
    IPADDR7="192.168.2.7"
    IPADDR8="192.168.2.8"
    IPADDR9="192.168.2.9"
    IPADDR10="192.168.2.10"
    54,860
    12,239
    7:11 PM
