Nginx help... wordpress 404 only for post
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by paddy, Nov 27, 2014.
  1. paddy
    paddy New Member
    27
    2:44 PM
    1.7.7
    MariaDB 5.5
    hi , im finished build my vps with centminmod and instruction at WordPress + Super Cache plugin for Centmin Mod Nginx | wp1.centmincache.com
    and i got 404 on all my post only , but not for categories or archive.
    404 only exist when i add /%postname%.html on wordpress permalink.
    but if i use "Post name all went smooth.
    is there any config that i should add on my .conf or change ?
    here is my conf
    #server {
    # listen 80;
    # server_name domain.com;
    # return 301 $scheme://www.domain.com$request_uri;
    include /usr/local/nginx/conf/pagespeedstatslog.conf;
    # ssi on;
    access_log /home/nginx/domains/domain.com/log/access.log combined buffer=32k;
    include /usr/local/nginx/conf/wpsupercache.conf;
    #autoindex on;
    #autoindex_localtime on;
    try_files /wp-content/cache/supercache/$http_host/$cache_uri/index.html $uri $uri/ /index.php;
    thank you before ...
    55,942
    5:44 PM
  3. paddy
    paddy New Member
    27
    2:44 PM
    1.7.7
    MariaDB 5.5
  4. paddy
    paddy New Member
    27
    2:44 PM
    1.7.7
    MariaDB 5.5
    @eva2000 can i use xcache + zen opcache with ngx_pagespeed ? or only ngx_pagespeed ?
    55,942
    5:44 PM
    xcache, apc cache, and zend opcache all do same task of php opcode caching so only one can be used - either xcache or zend opcache not both
    ngx_pagespeed doesn't use any php opcache cacher as it's an nginx module
  6. paddy
    paddy New Member
    27
    2:44 PM
    1.7.7
    MariaDB 5.5
    ok thank u
  7. paddy
    paddy New Member
    27
    2:44 PM
    1.7.7
    MariaDB 5.5
    @eva2000 can u tell me what's wrong with my conf , i got this error on supercache
    Screenshot by Lightshot
    and how to reinstall Zend OpCache
    [root@server centmin-v1.2.3mod]# PHP 5.4.33 (cli) (built: Nov 28 2014 04:41:28)
    with XCache v3.1.0, Copyright (c) 2005-2013, by mOo
    with Zend OPcache v7.0.3, Copyright (c) 1999-2014, by Zend Technologies
    with XCache Cacher v3.1.0, Copyright (c) 2005-2013, by mOo
    55,942
    5:44 PM
    how you manage that ? as Xcache and Zend Opcache install functions will automatically remove other php opcachers via menu options.
    Try running centmin.sh menu option 12 > sub menu option 2 to reinstall Zend Opcache it should remove the Xcache ini file
                       Centmin Mod Menu
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    14). SELinux disable
    16). Change SSHD Port Number
    20). NSD Re-install
    22). Exit
    Enter option [ 1 - 22 ] 12
            Zend OpCache Sub-Menu
    1). Install Zend OpCache for PHP <5.5 or <5.6
    2). Reinstall Zend OpCache for PHP <5.5 or <5.6
    3). Back to Main menu
    Enter option [ 1 - 3 ] 2
