vBulletin Help with Rewrite Rules
Discussion in 'Forum software usage' started by Mask, Nov 28, 2014.
  1. Mask
    Mask Active Member
    108
    31
    3:11 PM
    Nginx 1.9.1
    MariaDB 10.0.19
    Hi Guys,
    This is the second server where I am using CentminMod :)
    The main domain has Wordpress installed on root and VB (v4.2.1) installed on directory /forums/. It us using standard mod rewrite rules. (I am attaching my current .htaccess from inside forums directory).
    When I use rules as stated on Nginx and vBulletin 4.1.x inbuilt Friendly Urls It keeps downloading php files. Please help me here.
    55,927
    8:11 PM
    not sure i understand, Nginx doesn't support htaccess any all so it's expected any .htaccess requirements won't work with Centmin Mod
  3. Mask
    Mask Active Member
    108
    31
    3:11 PM
    Nginx 1.9.1
    MariaDB 10.0.19
    Sorry I think I didn't make it clear first. I am using VB forum on sub-domain (domain.com/fourms/) and with Apache I was using the above rewrite rules for using VB SEO friendly URLs. (i.e. That comes standard with VB, No VBSeo hack)
    But when move this forum to Nginx (using CentminMod) and following instructions given at Nginx and vBulletin 4.1.x inbuilt Friendly Urls It's not working. As soon as I access domain.com/fourms/ it downloads the php file.
    So I need help getting VB Seo Friendly URL working.
    55,927
    8:11 PM
    post your nginx vhost conf file contents for your forums here (in CODE tags)
  5. Mask
    Mask Active Member
    108
    31
    3:11 PM
    Nginx 1.9.1
    MariaDB 10.0.19
    Here it is.
    #server {
    #            listen   80;
    #            server_name domain.com;
      # ssi  on;
      access_log /home/nginx/domains/domain.com/log/access.log combined buffer=32k;
      access_log /var/log/nginx/access.cache.log cache;
      #autoindex  on;
      #autoindex_localtime on;
      #try_files            $uri $uri/ /index.php;
    #Added for WP-Install at Root
    #Permalink
    #Wp-Cache
    include /usr/local/nginx/conf/phpwpcache.conf;
    include /usr/local/nginx/conf/wpcache.conf;
      location /forums {
            try_files $uri $uri/ @rewrite;
    location @rewrite {
            # Forum
            rewrite /forums/threads/.*                          /forums/showthread.php?$uri&$args      last;
            rewrite /forums/forums/.*                           /forums/forumdisplay.php?$uri&$args    last;
            rewrite /forums/members/.*                          /forums/member.php?$uri&$args          last;
            rewrite /forums/blogs/.*                            /forums/blog.php?$uri&$args            last;
            rewrite /forums/entries/.*                          /forums/entry.php?$uri&$args           last;
            # MVC
            rewrite ^/forums/(?:(.*?)(?:/|$))(.*|$)$            /forums/$1.php?r=$2                    last;
    Other than standard install, I have only added "Advanced Nginx Wordpress configuration + fastcgi_cache + Nginx Helper plugin" without the plugin from Nginx Wordpress Configuration Examples for rewrite rules & FastCGI Caching
    55,927
    8:11 PM
    i believe it's because you commented out the php.conf include line
    try this
      location /forums {
  7. Mask
    Mask Active Member
    108
    31
    3:11 PM
    Nginx 1.9.1
    MariaDB 10.0.19
    Errr .. That was a stupid mistake :(
    Retracing my steps, I believe I commented it out since I am using fastcgi_cache from wp-config page and have /usr/local/nginx/conf/phpwpcache.conf instead.
    Should have thought of it ..
    Works perfectly now :)
    You are awesome .. :)
