Wordpress Help with rewrite rules?
Discussion in 'Blogs & CMS usage' started by bruno, Sep 12, 2017.
  1. bruno
    bruno Member
    73
    6
    6:05 AM
    I know this is a very niche question - apologies!
    I have a WordPress install set up on a beautiful centminmod server. I am trying to use the popular Fancy Product Designer plugin but have found an issue. It seems that the centminmod config is stopping a file (/wp-content/plugins/fancy-product-designer/assets/templates/productdesigner.php) from loading (getting a 403 error).
    Does any kind strangerhave any idea how I might allow this php file from running? I've tried chmod 755 and no luck.
    Thanks in advance. Will reward any solutions with a little thank-you donation.
    38,035
    8,356
    4:05 PM
    Centmin Mod values security and puts additional measures in place so that end users are also mindful of security. So in your case, you might need to whitelist or unblock the WP plugins related to your 403 permission denied messages.
    If you used centmin.sh menu option 22 auto installer Wordpress Nginx Auto Installer, the default wpsecure conf file at /usr/local/nginx/conf/wpsecure_${vhostname}.conf where vhostname is your domain name, blocks php scripts from executing in wp-content for security
    Below links you can see examples of setting up specific wordpress location matches to punch a hole in the wpsecure blocking to whitelist specific php files that need to be able to run.
    If on Centmin Mod 123.09beta01, you may have ran into the new tools/autoprotect.sh cronjob feature outlined at Beta Branch - autoprotect.sh - apache .htaccess check & migration to nginx deny all | Centmin Mod Community You uploaded scripts may have .htaccess deny from all type files in their directories which may need bypassing autoprotect. It's a security feature that no other nginx based stack has as far as I know :)
  3. bruno
    bruno Member
    73
    6
    6:05 AM
    i wish there could be more people like @eva2000 in the world!! that's exactly the reply i needed, and i'll get into reading that stuff now!
    thanks again for keeping up such a great project. respect from over here in the UK!
  4. bruno
    bruno Member
    73
    6
    6:05 AM
    ok so i read as much as possible but i think i'm missing something !
    Let's say I wanted to exclude this file path from autoprotect.sh : /wp-content/plugins/fancy-product-designer
    What would be the steps?
    nano  .autoprotect-bypass
    in that directory?
    what would go inside that file?
    then i re-run tools/autoprotect.sh and it should work ?
    thanks again in advance mate!
    38,035
    8,356
    4:05 PM
    cd /fullpathto/wp-content/plugins/fancy-product-designer
    touch .autoprotect-bypass
    /usr/local/src/centminmod/tools/autoprotect.sh
  6. bruno
    bruno Member
    73
    6
    6:05 AM
    Thanks! I tried that and still no change :(
    Here's the link for reference: Small Flag
    Chrome's inspector still shows 403 error for the file in question.
    Any idea how to fix? I'd be happy to hire you to resolve it.
    38,035
    8,356
    4:05 PM
    contents for your
    /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf where domain.com is your domain name ?
    cat /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf
  8. bruno
    bruno Member
    73
    6
    6:05 AM
    Here it is:
    # /home/nginx/domains/flagsilk.faste.st/public/wp-content/plugins/woocommerce-product-designer/includes/tcpdf/tools
    location ~* ^/wp-content/plugins/woocommerce-product-designer/includes/tcpdf/tools/ { allow 127.0.0.1; deny all; }
    # /home/nginx/domains/flagsilk.faste.st/public/wp-content/plugins/wordfence/lib
    location ~* ^/wp-content/plugins/wordfence/lib/ { allow 127.0.0.1; deny all; }
    # /home/nginx/domains/flagsilk.faste.st/public/wp-content/plugins/wordfence/tmp
    location ~* ^/wp-content/plugins/wordfence/tmp/ { allow 127.0.0.1; deny all; }
    # /home/nginx/domains/flagsilk.faste.st/public/wp-content/plugins/woocommerce-jetpack/includes/lib/tcpdf_min/tools
    location ~* ^/wp-content/plugins/woocommerce-jetpack/includes/lib/tcpdf_min/tools/ { allow 127.0.0.1; deny all; }
    # /home/nginx/domains/flagsilk.faste.st/public/wp-content/plugins/fancy-product-designer/admin/inc/tcpdf/tools
    location ~* ^/wp-content/plugins/fancy-product-designer/admin/inc/tcpdf/tools/ { allow 127.0.0.1; deny all; }
    # /home/nginx/domains/flagsilk.faste.st/public/wp-content/uploads/sucuri
    location ~* ^/wp-content/uploads/sucuri/ { allow 127.0.0.1; deny all; }
    # /home/nginx/domains/flagsilk.faste.st/public/wp-content/uploads/woocommerce_uploads
    location ~* ^/wp-content/uploads/woocommerce_uploads/ { allow 127.0.0.1; deny all; }
    # /home/nginx/domains/flagsilk.faste.st/public/wp-content/uploads/wc-logs
    location ~* ^/wp-content/uploads/wc-logs/ { allow 127.0.0.1; deny all; }
    # /home/nginx/domains/flagsilk.faste.st/public/wp-content/uploads/ezfc-uploads
    location ~* ^/wp-content/uploads/ezfc-uploads/ { allow 127.0.0.1; deny all; }
    # /home/nginx/domains/flagsilk.faste.st/public/wp-content/uploads/ezfc-pdf
    location ~* ^/wp-content/uploads/ezfc-pdf/ { allow 127.0.0.1; deny all; }
    # Nginx - Is it better to add an exeption for 127.0.0.1 for autoprotect rules?
    # /home/nginx/domains/flagsilk.faste.st/public/wp-content/wflogs
    location /wp-content/wflogs/ {
      location ~ ^/wp-content/wflogs/(.+/)?(.+)\.(js)$ { allow all; expires 30d; }
      location ~ ^/wp-content/wflogs/(.+/)?(.+)\.(css)$ { allow all; expires 30d; }
      location ~ ^/wp-content/wflogs/(.+/)?(.+)\.(gif|jpe?g|png|webp|eot|svg|ttf|woff|woff)$ { allow all; expires 30d; }
      location ~ ^/wp-content/wflogs/(.+/)?(.+)\.(php|cgi|pl|php3|php4|php5|php6|phtml|shtml)$ { allow 127.0.0.1; deny all; }
    38,035
    8,356
    4:05 PM
  10. bruno
    bruno Member
    73
    6
    6:05 AM
    My bad! Think I've fixed that now. Does it shed any light on it?
    38,035
    8,356
    4:05 PM
    looks good for that specific plugin you had issues with, what's listed in autoprotect include file for location context matches are directories which have .htaccess which you might need to whitelist too using your best judgement of course
    as per Beta Branch - autoprotect.sh - apache .htaccess check & migration to nginx deny all, autoprotect.sh serves to give folks heads up of potential .htaccess directories you may not what made public and need a nginx rule for and/or whitelisting
    38,035
    8,356
    4:05 PM
    oh you mean fixed the CODE tags, thought you mean the 403 issue.. it's still showing
    so maybe setup .autoprotect-bypass file
    touch /home/nginx/domains/flagsilk.faste.st/public/wp-content/plugins/fancy-product-designer/admin/inc/tcpdf/tools/.autoprotect-bypass
    then re-run tools/autoprotect.sh
    what's contents of /wp-content/plugins/fancy-product-designer/admin/inc/tcpdf/tools/.htaccess ?
    cat /home/nginx/domains/flagsilk.faste.st/public/wp-content/plugins/fancy-product-designer/admin/inc/tcpdf/tools/.htaccess
  13. bruno
    bruno Member
    73
    6
    6:05 AM
    Ah, still no luck unfortunately. Would it be useful for me to repost the /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf
    Thanks again!
    38,035
    8,356
    4:05 PM
    yeah post updated contents after tools/autoprotect.sh run
    you can also quickly rule out autoprotect as the issue by editing your nginx vhost and commenting out the include file for /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf
    #include /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf;
    restart nginx and php-fpm
    nprestart
  15. bruno
    bruno Member
    73
    6
    6:05 AM
    Here it is!
    I then out the autoprotect line as you suggested. Still no luck! Does that mean it's not to do with autoprotect.sh?
    Thanks again!
  16. bruno
    bruno Member
    73
    6
    6:05 AM
    just some more info which might be useful from error.log:
    2017/09/12 20:59:52 [error] 13351#13351: *47 access forbidden by rule, client: 162.158.155.15, server: flagsilk.faste.st, request: "GET
    /wp-content/plugins/fancy-product-designer/assets/templates/productdesigner.php HTTP/1.1", host: "flagsilk.faste.st", referrer:
    "https://flagsilk.faste.st/product/small-flag/" 2017/09/12 21:03:08 [error] 13590#13590: *3 access forbidden by rule, client: 162.158.155.15,
    server: flagsilk.faste.st, request: "GET /wp-content/plugins/fancy-product-designer/assets/templates/productdesigner.php HTTP/1.1", host:
    "flagsilk.faste.st", referrer: "https://flagsilk.faste.st/product/small-flag/" 2017/09/12 21:05:10 [error] 13780#13780: *3 access forbidden by
    "https://flagsilk.faste.st/product/small-flag/" 2017/09/12 21:26:20 [error] 13782#13782: *25 access forbidden by rule, client: 162.158.155.15,
    "flagsilk.faste.st", referrer: "https://flagsilk.faste.st/product/small-flag/" 2017/09/12 21:33:44 [error] 13780#13780: *45 access forbidden
    38,035
    8,356
    4:05 PM
  18. bruno
    bruno Member
    73
    6
    6:05 AM
    yep, tried that earlier by adding # in the
    flagsilk.faste.st.conf
    and
    flagsilk.faste.st.ssl.conf
    files. sadly didn't make a difference. still getting 403 on the inspector for the productdesigner.php
    plugin's faq mentions this rewrite rule for .htaccess
    RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
    but I'm not sure how that would work on an nginx server.
    (source: Getting Started : Fancy Product Designer)
    38,035
    8,356
    4:05 PM
    then it's no autoprotect, it could be the default wpsecure conf file at /usr/local/nginx/conf/wpsecure_${vhostname}.conf where vhostname is your domain name, blocks php scripts from executing in wp-content for security
  20. bruno
    bruno Member
    73
    6
    6:05 AM
    woohoooo ! found the fix!
    i had to go to
    /usr/local/nginx/conf/conf.d/flagsilk.faste.st.conf
    and
    /usr/local/nginx/conf/conf.d/flagsilk.faste.st.ssl.conf
    You may want to update the posts from the links you sent me in the last post, as they mention:
    (maybe that's the old file path from before the beta?)
    I added this code:
    # Whitelist Exception for https://wordpress.org/plugins/whatever-plugin/
    location ~ ^/wp-content/plugins/whatever-plugin/ {
    Now working perfectly.
    Thanks again man!!
