Letsencrypt Help with error. Can't get letsencrypt to work
Discussion in 'Domains, DNS, Email & SSL Certificates' started by Itworx4me, Mar 22, 2020.
  1. Itworx4me
    344
    35
    9:37 AM
    Nginx 1.27.4
    MariaDB 10.6.21
    I got this when reissuing:
    acmetool.sh is in beta testing phase
    please read & provide bug reports &
    feedback for this tool via the forums
    https://centminmod.com/acmetool
    continue [y/n] ? y
    updating acme.sh client...
    Cloning into 'acme.sh'...
    [Sun Mar 22 20:05:57 UTC 2020] It is recommended to install socat first.
    [Sun Mar 22 20:05:57 UTC 2020] We use socat for standalone server if you use standalone mode.
    [Sun Mar 22 20:05:57 UTC 2020] If you don't use standalone mode, just ignore this warning.
    [Sun Mar 22 20:05:57 UTC 2020] Installing to /root/.acme.sh
    [Sun Mar 22 20:05:57 UTC 2020] Installed to /root/.acme.sh/acme.sh
    [Sun Mar 22 20:05:58 UTC 2020] Installing alias to '/root/.bashrc'
    [Sun Mar 22 20:05:58 UTC 2020] OK, Close and reopen your terminal to start using acme.sh
    [Sun Mar 22 20:05:58 UTC 2020] Installing alias to '/root/.cshrc'
    [Sun Mar 22 20:05:58 UTC 2020] Installing alias to '/root/.tcshrc'
    [Sun Mar 22 20:05:58 UTC 2020] Installing cron job
    19 0 * * * "/root/.acme.sh"/acme.sh --cron --home "/root/.acme.sh" > /dev/null
    [Sun Mar 22 20:05:58 UTC 2020] Good, bash is found, so change the shebang to use bash as preferred.
    https://github.com/acmesh-official/acme.sh
    v2.8.6
    acme.sh updated
    grep 'root' /usr/local/nginx/conf/conf.d/insidepromod.com.ssl.conf
      root /home/nginx/domains/insidepromod.com/public;
    reissue & install letsencrypt ssl certificate for insidepromod.com
    /root/.acme.sh/acme.sh --force --createDomainKey -d insidepromod.com -d www.insidepromod.com -k 2048 --useragent centminmod-centos7-acmesh-webroot
    [Sun Mar 22 20:05:59 UTC 2020] Creating domain key
    [Sun Mar 22 20:05:59 UTC 2020] The domain key is here: /root/.acme.sh/insidepromod.com/insidepromod.com.key
    testcert value = live
    /root/.acme.sh/acme.sh --force --issue -d insidepromod.com -d www.insidepromod.com --days 60 -w /home/nginx/domains/insidepromod.com/public -k 2048 --useragent centminmod-centos7-acmesh-webroot --log /root/centminlogs/acmetool.sh-debug-log-220320-200551.log --log-level 2
    [Sun Mar 22 20:05:59 UTC 2020] Multi domain='DNS:insidepromod.com,DNS:www.insidepromod.com'
    [Sun Mar 22 20:06:00 UTC 2020] Getting domain auth token for each domain
    [Sun Mar 22 20:06:02 UTC 2020] Getting webroot for domain='insidepromod.com'
    [Sun Mar 22 20:06:02 UTC 2020] Getting webroot for domain='www.insidepromod.com'
    [Sun Mar 22 20:06:02 UTC 2020] Verifying: insidepromod.com
    [Sun Mar 22 20:06:06 UTC 2020] insidepromod.com:Verify error:Invalid response from http://insidepromod.com/.well-known/acme-challenge/5HdtNCsmQX0142STaMivTNvyNwN3WTDr2wG5dbnojhQ [2606:4700:3030::681c:186d]:
    [Sun Mar 22 20:06:06 UTC 2020] Please check log file for more details: /root/centminlogs/acmetool.sh-debug-log-220320-200551.log
    LECHECK = 1
    log files saved at /root/centminlogs
    -rw-r--r-- 1 root root 3.1K Mar 22 20:05 cmm-login-git-checks_220320-200521.log
    -rw-r--r-- 1 root root  44K Mar 22 20:06 acmetool.sh-debug-log-220320-200551.log
    -rw-r--r-- 1 root root 3.0K Mar 22 20:06 acmesh-reissue-only_220320-200551.log
    60,468
    12,614
    3:37 AM
    oh yeah uncomment and restore the server{} context which has 302 redirect from non-https to https and restart nginx service before doing re-issuance
  3. Itworx4me
    344
    35
    9:37 AM
    Nginx 1.27.4
    MariaDB 10.6.21
    Finally success. Do I need to go in and change the ssl.conf lines to this now?
    From this:
    ssl_certificate      /usr/local/nginx/conf/ssl/insidepromod.com/insidepromod.com.crt;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/insidepromod.com/insidepromod.com.key;
      #resolver_timeout 10s;
      #ssl_stapling on;
      #ssl_stapling_verify on;
      #ssl_trusted_certificate /usr/local/nginx/conf/ssl/insidepromod.com/insidepromod.com-trusted.crt;
    To this:
    ssl_certificate      /usr/local/nginx/conf/ssl/insidepromod.com/insidepromod.com-acme.cer;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/insidepromod.com/insidepromod.com-acme.key;
      ssl_stapling on;
      ssl_trusted_certificate /usr/local/nginx/conf/ssl/insidepromod.com/insidepromod.com-fullchain-acme.key;
    Thanks,
    Itworx4me
    60,468
    12,614
    3:37 AM
    You can do that though it will still work with self-signed ssl as CF Full non-strict SSL allows self-signed SSL certs on nginx origin. But for letsencrypt, yes change it, so if you ever need to disable Cloudflare proxy orange cloud, your Centmin Mod Nginx origin letsencrypt SSL will still be valid for HTTPS
