Sysadmin Help with changing permalinks > nginx rewrite
Discussion in 'System Administration' started by upgrade81, Oct 16, 2019.
  1. upgrade81
    266
    16
    Italy
    11:56 AM
    1.17
    10.3
    Someone would be kind to tell me the necessary rewrite for nginx, to change the permalinks
    /%category%/%postname%/%post_id%
    to:
    /%category%/%postname%-%post_id%
    Thanks to those who give me the tip
    45,977
    10,444
    8:56 PM
    For wordpress ? try_files in place takes care of all variations of permalinks so no changes needed.
  3. upgrade81
    266
    16
    Italy
    11:56 AM
    1.17
    10.3
    Hi yes I know this, but I changed the structure of the permalinks replacing / with - at the end of url
    So I was looking for the rule to apply on the nginx vhost configuration.
  4. upgrade81
    266
    16
    Italy
    11:56 AM
    1.17
    10.3
    I should have succeeded for those who need it here is the regex.
    rewrite "^/([a-zA-Z0-9-]+)\/([a-zA-Z0-9-]+)/([0-9]+)" https://domain.com/$1/$2-$3 permanent;
    45,977
    10,444
    8:56 PM
    so try_files natively doesn't work ? or you mean you want to redirect old permalinks to the new permalinks format ?
    I thought you meant for existing links only !
