Sysadmin Help with a solution for video streaming :(
Discussion in 'System Administration' started by KinderOvO, Sep 1, 2018.
    4:42 AM
    This thread has renewed my interestlearning for video encoding/streaming again - it's not something I dabble in much due to how expensive it can get at scale though. Just updated Centmin Mod 123.09beta01's addons/ffmpeg.sh installer with optional AV1 encoder support too Beta Branch - update addons/ffmpeg.sh add AV1 support. From what i read much slower encoding speeds than VP9 webm and H.264/265 but much smaller file sizes due to better compression etc. Some results on AV1 site AV1 Test Results.
    AV1 beats x264 and libvpx-vp9 in practical use case
    So if you're currently streaming H.264 mp4 videos, AV1 encoded could reduce size by upto 50% !
    Enjoy!
  2. gabel
    gabel Member
    68
    38
    7:42 PM
    1.9.9
    MariaDB 10
    kvs makes use of limit_rate_after , here's a post where they explain how this can be done using their script (could be applied to other scripts as well )
    https://www.kernel-video-sharing.com/forum/forum/educational-support/educational-series/34-how-to-save-bandwidth-with-kvs-tube-script
    4:42 AM
    Thanks @gabel definitely interesting and smart approach :)
    Module ngx_http_core_module
  4. KinderOvO
    KinderOvO Member
    92
    4:42 AM
    1.4
    Total DISK READ : 474.02 M/s | Total DISK WRITE : 3.3 M/s
    Actual DISK READ: 477.67 M/s | Actual DISK WRITE: 1.15 M/s
    Is my iotop result
    Thanks all for attention to help-me
    I am currently using 6 gbps full
    I plan to upgrade to 20gbps.
    Being that I disc rate are already high, all my discs are ssds which generates a very high cost.
    I need a lot of space, because I use videos in 3 formats, 720p, 480p and 360p
    because many visitors use 3G and a slow connection.
    What would be the best solution, since nginx is not caching the videos.
    Is there any way to cache the videos and decrease disk usage.
    I currently use 4 x 2TB SSD
    all the disks are already with 70% of use, already I am thinking how I will do to 20gbps, since with 6gbps the reading rate is very high.
    4:42 AM
    Already mentioned in this thread with links to using nginx sliced byte range caching to cache videos :) For disk space usage, re-encode videos for smaller size I guess
  6. KinderOvO
    KinderOvO Member
    92
    4:42 AM
    1.4
    Do I need to format my current server and reinstall centmin? Could you share your vhost? and config for mp4 / webm files.
    4:42 AM
  8. KinderOvO
    KinderOvO Member
    92
    4:42 AM
    1.4
    Got it, have you ever used HLS? would it have an advantage? because I currently have to generate 3 videos, 720p, 480p, 320p - because I have a lot of visitors from areas with slower internet.
    It would be the same process, I looked into generating videos with codec AV1 for hls, but I did not find anything of the type.
  9. KinderOvO
    KinderOvO Member
    92
    4:42 AM
    1.4
    4:42 AM
  11. KinderOvO
    KinderOvO Member
    92
    4:42 AM
    1.4
    My problem is this directive
    limit_traffic_rate rate 1500k;
    nginx not start after add.
    4:42 AM
    check nginx config test output
    nginx -t
  13. KinderOvO
    KinderOvO Member
    92
    4:42 AM
    1.4
    no cache miss or hit :(
    4:42 AM
    Keep trying and testing. It worked for me Sysadmin - Help with a solution for video streaming :(. No free support provided from me - this is usually something my clients pay me to consult for. This is something you need to figure out on your own.
    added conditional headers to track which sliced byte chunks are sliced = 1 and sliced-cache = HIT or MISS. It will only be from cache if you skip back or forth to point in a video's playback the first time and then cached (cache HIT) for subsequent requests for however long you configured cache expiry and cache inactive time. After cache size reached or expiry/inactive time is reached, the cache is cleared so again first time request is cache = MISS
    and sliced = 1 but sliced-cache = MISS
  15. KinderOvO
    KinderOvO Member
    92
    4:42 AM
    1.4
    Thanks for the attention, I will try something different because it did not work for me, it is not caching the .mp4 files.
  16. KinderOvO
    KinderOvO Member
    92
    4:42 AM
    1.4
    Currently
    Network: 698.22 MBit/s
    Iotop: Total DISK READ : 175.79 M/s | Total DISK WRITE : 65.83 K/s
    Cpu: Average: 1.72 1.66 1.57
    When it arrives at 3gbps of use, it is super slow, load of the cpu passes of the 33%, iotop in the heights.
    So my doubt and the next, I can never have a server to stream 5gbps? because currently my hardware is good in my point of view, but I already have these problems using little traffic.
    2x2620v4 + 64GB DDR4 + 4x2TB SSD
  17. Kintaro
    Kintaro Member
    117
    11
    Italy
    8:42 PM
    MariaDB 10
    Just use Pied Piper :whistle:
    p.s. sorry but I couldn't resist.
  18. KinderOvO
    KinderOvO Member
    92
    4:42 AM
    1.4
    4:42 AM
  20. buik
    2,044
    527
    Flanders
    8:42 PM
    @KinderOvO year plus ago when you initially launched you question about:
    'Help with a solution for video streaming'. How is it going and what solution are you using now?
