Help witch convert htaccess to nginx
Discussion in 'Blogs & CMS usage' started by RootPass, Jan 10, 2018.
  1. RootPass
    RootPass New Member
    25
    3:17 AM
    CentMin
    CentMin
    hey
    im using centminmod and really love it
    i try to get a tool on centmin vhost to work on nginx however it using an htaccess and can't work with the server.
    i tried to talk to the tool support and they telling me that i need to convert the htaccess to nginx to make .php file opened by php (however it's not set as default?)
    the htaccess code:
    RewriteEngine On
    #RewriteCond %{HTTPS} off
    #RewriteRule .* https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
    #RewriteCond %{HTTP_HOST} !^www\.
    #RewriteRule .* http://www.%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
    Options +FollowSymLinks
    Options -Indexes
    RewriteCond %{SCRIPT_FILENAME} !-d
    RewriteCond %{SCRIPT_FILENAME} !-f
    RewriteRule . index.php [L,QSA]
    # Performace optimization
    # BEGIN Compress text files
    <ifModule mod_deflate.c>
      AddOutputFilterByType DEFLATE text/html text/xml text/css text/plain
      AddOutputFilterByType DEFLATE image/svg+xml application/xhtml+xml application/xml
      AddOutputFilterByType DEFLATE application/rdf+xml application/rss+xml application/atom+xml
      AddOutputFilterByType DEFLATE text/javascript application/javascript application/x-javascript application/json
      AddOutputFilterByType DEFLATE application/x-font-ttf application/x-font-otf
      AddOutputFilterByType DEFLATE font/truetype font/opentype
    </ifModule>
    # END Compress text files
    # BEGIN Expire headers
    <ifModule mod_expires.c>
      ExpiresActive On
      ExpiresDefault "access plus 5 seconds"
      ExpiresByType image/x-icon "access plus 31536000 seconds"
      ExpiresByType image/jpeg "access plus 31536000 seconds"
      ExpiresByType image/png "access plus 31536000 seconds"
      ExpiresByType image/gif "access plus 31536000 seconds"
      ExpiresByType application/x-shockwave-flash "access plus 31536000 seconds"
      ExpiresByType text/css "access plus 31536000 seconds"
      ExpiresByType text/javascript "access plus 31536000 seconds"
      ExpiresByType application/javascript "access plus 31536000 seconds"
      ExpiresByType application/x-javascript "access plus 31536000 seconds"
    </ifModule>
    # END Expire headers
    # BEGIN Cache-Control Headers
    <ifModule mod_headers.c>
      <filesMatch ".(ico|jpe?g|png|gif|swf)$">
        Header set Cache-Control "public"
      </filesMatch>
      <filesMatch ".(css)$">
      </filesMatch>
      <filesMatch ".(js)$">
        Header set Cache-Control "private"
      </filesMatch>
      <filesMatch ".(x?html?|php)$">
        Header set Cache-Control "private, must-revalidate"
      </filesMatch>
      <filesMatch ".(woff|woff2|ttf|otf|eot)$">
        Header set Cache-Control "max-age=31536000 private, must-revalidate"
      </filesMatch>
    </ifModule>
    # END Cache-Control Headers
    39,245
    8,656
    10:17 AM
    Centmin Mod is provide as is, so short of scripted related bugs or issues, any further optimisation to the web stack components - nginx, php-fpm, mariadb mysql, csf firewall etc or web app specific configurations are left to the Centmin Mod user to deal with. So I do not provide any free support for such rewrite rules.
    What tool/script ?
    all static/expires is already handled by centmin mod nginx out of box so only relevant part to convert is
    IIRC, which is wordpress permalinks ?
    just edit your domain.com.conf and/or domain.com.ssl.conf and uncomment the wordpress permalink rewrite rule
    try_files $uri $uri/ /index.php?q=$uri&$args;
    then restart nginx + php-fpm
    nprestart
  3. RootPass
    RootPass New Member
    25
    3:17 AM
    CentMin
    CentMin
    Thanks @eva2000 !
    when i uncomment i get this error:
    Restarting nginx (via systemctl): Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.
    [FAILED]
    Starting php-fpm done
    39,245
    8,656
    10:17 AM
    Check nginx config via test config command
    nginx -t
    what output do you get ?
    curl -I https://domain.com
    curl -I http://domain.com
    curl -I http://www.domain.com
    wrap output in CODE tags
  5. RootPass
    RootPass New Member
    25
    3:17 AM
    CentMin
    CentMin
    @eva2000 probably the error came from the duplicate try_files command (centmin by default have the first one):
    try_files $uri $uri/ /index.php?$query_string;
    i uncommented the first one and place the wordpress one u said and error is gone but code is still not working (404)
    the tool is Instagram Auto Post & Scheduler
    this is the conf file (replaced domain with domain.com)
    #server {
    #            listen   80;
    #            server_name domain.com;
      # ssi  on;
      access_log /home/nginx/domains/domain.com/log/access.log combined buffer=256k flush=5m;
      include /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.com.conf;
      # server and/or vhost site
      #try_files $uri $uri/ /index.php?$query_string;
      #autoindex  on;
      #autoindex_localtime on;
    curl commands: (not using ssl)
    curl -I domain.com:
    HTTP/1.1 403 Forbidden
    Date: Tue, 09 Jan 2018 20:54:28 GMT
    Connection: keep-alive
    Set-Cookie: __cfduid=d3f535eb6c321ed432fd156ebf8b980431515531268; expires=Wed, 09-Jan-19 20:54:28 GMT; path=/; domain=.domain.com; HttpOnly
    X-Powered-By: CF
    Server: cloudflare
    CF-RAY: 3daa4aba97d52c00-AMS
    curl -I www.domain.com
    Date: Tue, 09 Jan 2018 20:55:03 GMT
    Set-Cookie: __cfduid=d4b5b295cb9dcc0b8fd246fcc079f0b041515531303; expires=Wed, 09-Jan-19 20:55:03 GMT; path=/; domain=.domain.com; HttpOnly
    X-Powered-By: CF
    Server: cloudflare
    CF-RAY: 3daa4b9965027325-AMS
    *I need to mention that the script is not located in domain.com, its in a directory. let me know if i need to change the curl to the directory
    39,245
    8,656
    10:17 AM
    Centmin Mod values security and puts additional measures in place so that end users are also mindful of security. So in your case, you might need to whitelist or unblock the WP plugins related to your 403 permission denied messages.
    If you used centmin.sh menu option 22 auto installer Wordpress Nginx Auto Installer, the default wpsecure conf file at /usr/local/nginx/conf/wpsecure_${vhostname}.conf where vhostname is your domain name, blocks php scripts from executing in wp-content for security
    Below links you can see examples of setting up specific wordpress location matches to punch a hole in the wpsecure blocking to whitelist specific php files that need to be able to run.
    If on Centmin Mod 123.09beta01, you may have ran into the new tools/autoprotect.sh cronjob feature outlined at Beta Branch - autoprotect.sh - apache .htaccess check & migration to nginx deny all | Centmin Mod Community You uploaded scripts may have .htaccess deny from all type files in their directories which may need bypassing autoprotect. It's a security feature that no other nginx based stack has as far as I know :)
  7. RootPass
    RootPass New Member
    25
    3:17 AM
    CentMin
    CentMin
    @eva2000 thanks man i added .autoprotect-bypass
    to the directories that autoprotect found and now the autoprotect file is empty but script still not working :(
    any ideas? thanks so much for ur responses!!!
  8. RootPass
    RootPass New Member
    25
    3:17 AM
    CentMin
    CentMin
    edit:
    after HOURS of trying things and script i FINALLY found the problem (it's the silliest one u'll ever see)
    it was the root missing the folder so i had to change it like this:
    root /home/nginx/domains/domain.com/public/scriptfolder
    when it was
    Thanks @eva2000 !
    39,245
    8,656
    10:17 AM
    so this isn't a wordpress site ? it's fully just this script/tool site ? if it is then
    just revert root path to previous default public and add a new location context for script directory and add the php.conf include file so you can process php
    location /scriptfolder {
