Beta Branch Help test innodbio.sh for MySQL Tuning
Discussion in 'Beta release code' started by eva2000, Feb 5, 2016.
  1. Ahmad
    Ahmad Active Member
    209
    80
    5:17 AM
    1.9.9
    10.1.10
    Reliable Dedicated server Int. Xeon E3 1240v5//16GB//SSD
    root@server ~]# curl -sL https://gist.github.com/centminmod/01b5ec3ebd394fa9284f/raw/innodbio.sh | bash
    ioping calculated
    19 change to 100
    innodb_io_capacity = 100
    19 change to 100
    innodb_io_capacity = 144
    38 change to 100
    38 change to 100
    30 change to 100
    fio calculated
    Full Reads: 30796
    Full Writes: 19598
    innodb_io_capacity = 391
    innodb_io_capacity = 279
    innodb_io_capacity = 217
    innodb_io_capacity = 178
    Full Reads: 30453
    Full Writes: 19366
    innodb_io_capacity = 387
    innodb_io_capacity = 276
    innodb_io_capacity = 215
    innodb_io_capacity = 176
    innodb_read_io_threads = 4
    innodb_write_io_threads = 4
    RamNode 2GB Premium
    [root@server ~]# curl -sL [URL]https://gist.github.com/centminmod/01b5ec3ebd394fa9284f/raw/innodbio.sh[/URL] | bash
    ioping calculated
    innodb_io_capacity = 444
    innodb_io_capacity = 384
    innodb_io_capacity = 825
    innodb_io_capacity = 700
    innodb_io_capacity = 644
    innodb_io_capacity = 643
    fio calculated
    Full Reads: 54251
    Full Writes: 40354
    innodb_io_capacity = 807
    innodb_io_capacity = 576
    innodb_io_capacity = 448
    innodb_io_capacity = 366
    Full Reads: 35310
    Full Writes: 42010
    innodb_io_capacity = 840
    innodb_io_capacity = 600
    innodb_io_capacity = 466
    innodb_io_capacity = 381
    innodb_read_io_threads = 2
    innodb_write_io_threads = 2
  2. SeaTea
    SeaTea Member
    49
    13
    the Netherlands
    5:17 AM
    Nginx:1.11
    MariaDB-10
    VPS 4GB 2xXeon SSD, server is idle and not optimized just default cenminmod install and test forum (IPB).
    I have 14 error-messages first all like:
    ioping: invalid option -- 'B'
    Usage: ioping [-LCDRq] [-c count] [-w deadline] [-p period] [-i interval]
                   [-s size] [-S wsize] [-o offset] device|file|directory
            ioping -h | -v
          -c <count>      stop after <count> requests
          -w <deadline>   stop after <deadline>
          -p <period>     print raw statistics for every <period> requests
          -i <interval>   interval between requests (1s)
          -s <size>       request size (4k)
          -S <wsize>      working set size (1m)
          -o <offset>     in file offset
          -L              use sequential operations (includes -s 256k)
          -C              use cached I/O
          -D              use direct I/O
          -R              seek rate test (same as -q -i 0 -w 3 -S 64m)
          -q              suppress human-readable output
          -h              display this message and exit
          -v              display version and exit
    Normal output is:
    ioping calculated
    0 change to 100
    0 change to 100
    0 change to 100
    0 change to 100
    0 change to 100
    0 change to 100
    fio calculated
    Full Reads: 3655
    Full Writes: 2578
    innodb_io_capacity = 51
    innodb_io_capacity = 28
    innodb_io_capacity = 23
    innodb_io_capacity = 85
    Full Reads: 3653
    Full Writes: 2579
    59,950
    12,556
    1:17 PM
    thanks @SeaTea looks like you have an older version of ioping
    ioping -h
    Usage: ioping [-LABCDWRq] [-c count] [-w deadline] [-pP period] [-i interval]
                   [-s size] [-S wsize] [-o offset] directory|file|device
            ioping -h | -v
          -P <period>     print raw statistics for every <period> in time
          -o <offset>     working set offset (0)
          -A              use asynchronous I/O
          -C              use cached I/O
          -D              use direct I/O
          -W              use write I/O *DANGEROUS*
          -B              print final statistics in raw format
    updated the script to report the ioping and fio versions and disk layout so have better idea for what the environment is
    System Info
    CPU: 4 x Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz
    2.6.32-042stab112.15
    CentOS release 6.7 (Final)
    Filesystem        Type      Size  Used Avail Use% Mounted on
    /dev/ploop28343p1 ext4       25G   22G  2.2G  91% /
    none              devtmpfs  512M  4.0K  512M   1% /dev
    none              tmpfs     512M     0  512M   0% /dev/shm
    ioping 0.8 calculated (IOPs)
    innodb_io_capacity = 629
    innodb_io_capacity = 829
    innodb_io_capacity = 792
    innodb_io_capacity = 767
    fio-2.0.13 calculated (IOPs)
    Full Reads: 3957
    Full Writes: 119637
    innodb_io_capacity = 2392
    innodb_io_capacity = 1709
    innodb_io_capacity = 1329
    innodb_io_capacity = 1087
    Full Reads: 3413
    Full Writes: 119637
  4. ModeltogTossen
    313
    97
    Denmark
    5:17 AM
    1.9.12
    10.0.23
    Ok - Did one more test for you:
    [root@sarah ~]# curl -sL https://gist.github.com/centminmod/01b5ec3ebd394fa9284f/raw/innodbio.sh | bash
    System Info
    Architecture:          x86_64
    CPU(s):                2
    On-line CPU(s) list:   0,1
    Thread(s) per core:    1
    Core(s) per socket:    2
    Socket(s):             1
    NUMA node(s):          1
    CPU family:            6
    Model:                 45
    Model name:            Intel(R) Xeon(R) CPU E5-1650 0 @ 3.20GHz
    Stepping:              7
    CPU MHz:               3192.307
    BogoMIPS:              6384.61
    Hypervisor vendor:     VMware
    Virtualization type:   full
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              256K
    L3 cache:              12288K
    NUMA node0 CPU(s):     0,1
    3.10.0-327.4.4.el7.x86_64
    CentOS Linux release 7.2.1511 (Core)
    /dev/sda1                             ext4        284G  8.9G  260G   4% /
    devtmpfs                              devtmpfs    3.9G     0  3.9G   0% /dev
    tmpfs                                 tmpfs       3.9G     0  3.9G   0% /dev/shm
    tmpfs                                 tmpfs       3.9G   49M  3.8G   2% /run
    tmpfs                                 tmpfs       3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/sdb1                             ext4        296G   23G  259G   8% /backupstore
    tmpfs                                 tmpfs       783M     0  783M   0% /run/user/0
    root@xxx fuse.sshfs  1.8T  2.3G  1.7T   1% /backupstore/borgremote
    ioping 0.9 calculated (IOPs)
    innodb_io_capacity = 333
    innodb_io_capacity = 621
    innodb_io_capacity = 845
    innodb_io_capacity = 803
    fio-2.2.8 calculated (IOPs)
    Full Reads: 594
    Full Writes: 178
    Full Reads: 818
    Full Writes: 202
    59,950
    12,556
    1:17 PM
    thanks @ModeltogTossen i updated script once again to add a bit more logic to fio tests for systems with <100 iops reported previously
  6. SeaTea
    SeaTea Member
    49
    13
    the Netherlands
    5:17 AM
    Nginx:1.11
    MariaDB-10
    Yes, I have version 0.6
    Is this installed by your script ? It is not updated by yum to a newer version, should I re-run one of the options of the centmin script to update to the latest version ?
    59,950
    12,556
    1:17 PM
    what's output of
    which ioping
    ls -lah /usr/local/bin/ioping
    ls -lah /usr/bin/ioping
    /usr/local/bin/ioping -v
    /usr/bin/ioping -v
  8. Ahmad
    Ahmad Active Member
    209
    80
    5:17 AM
    1.9.9
    10.1.10
    [root@server ~]# curl -sL https://gist.github.com/centminmod/01b5ec3ebd394fa9284f/raw/innodbio.sh | bash
    System Info
    CPU(s):                4
    On-line CPU(s) list:   0-3
    Core(s) per socket:    1
    Socket(s):             4
    NUMA node(s):          1
    CPU family:            6
    Model:                 58
    Model name:            Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz
    Stepping:              9
    CPU MHz:               3300.022
    BogoMIPS:              6600.04
    Hypervisor vendor:     KVM
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              4096K
    NUMA node0 CPU(s):     0-3
    3.10.0-327.3.1.el7.x86_64
    Dateisystem    Typ      Größe Benutzt Verf. Verw% Eingehängt auf
    /dev/vda1      ext4       41G     21G   18G   55% /
    devtmpfs       devtmpfs  911M       0  911M    0% /dev
    tmpfs          tmpfs     920M       0  920M    0% /dev/shm
    tmpfs          tmpfs     920M     99M  822M   11% /run
    tmpfs          tmpfs     920M       0  920M    0% /sys/fs/cgroup
    tmpfs          tmpfs     184M       0  184M    0% /run/user/0
    tmpfs          tmpfs     184M       0  184M    0% /run/user/994
    innodb_io_capacity = 609
    innodb_io_capacity = 592
    innodb_io_capacity = 762
    innodb_io_capacity = 747
    Full Reads: 39196
    Full Writes: 35929
    innodb_io_capacity = 1197
    innodb_io_capacity = 898
    innodb_io_capacity = 718
    innodb_io_capacity = 513
    Full Reads: 34859
    Full Writes: 33032
    innodb_io_capacity = 1101
    innodb_io_capacity = 660
    innodb_io_capacity = 471
    System Info
    CPU(s):                8
    On-line CPU(s) list:   0-7
    Thread(s) per core:    2
    Core(s) per socket:    4
    Socket(s):             1
    NUMA node(s):          1
    CPU family:            6
    Model:                 94
    Model name:            Intel(R) Xeon(R) CPU E3-1240 v5 @ 3.50GHz
    Stepping:              3
    CPU MHz:               969.199
    BogoMIPS:              7008.05
    Virtualization:        VT-x
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              256K
    L3 cache:              8192K
    NUMA node0 CPU(s):     0-7
    /dev/mapper/centos_server-root xfs        50G    6,3G   44G   13% /
    devtmpfs                       devtmpfs  7,8G       0  7,8G    0% /dev
    tmpfs                          tmpfs     7,8G       0  7,8G    0% /dev/shm
    tmpfs                          tmpfs     7,8G    249M  7,5G    4% /run
    tmpfs                          tmpfs     7,8G       0  7,8G    0% /sys/fs/cgroup
    /dev/mapper/centos_server-home xfs        54G    482M   53G    1% /home
    /dev/sda1                      xfs       497M    185M  312M   38% /boot
    tmpfs                          tmpfs     1,6G       0  1,6G    0% /run/user/0
    /dev/sdb2                      ext3       52G    731M   49G    2% /var/lib/mysql
    27 change to 100
    27 change to 100
    35 change to 100
    44 change to 100
    Full Reads: 30567
    Full Writes: 19275
    innodb_io_capacity = 642
    innodb_io_capacity = 481
    innodb_io_capacity = 385
    innodb_io_capacity = 275
    innodb_io_capacity = 1927
    Full Reads: 30796
    Full Writes: 19645
    innodb_io_capacity = 654
    innodb_io_capacity = 491
    innodb_io_capacity = 392
    innodb_io_capacity = 280
    innodb_io_capacity = 1964
    System Info
    CPU(s):                2
    Socket(s):             2
    NUMA node(s):          1
    CPU family:            6
    Model:                 63
    Model name:            Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz
    Stepping:              2
    CPU MHz:               2399.998
    BogoMIPS:              4799.99
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              4096K
    /dev/vda1      ext4       39G     12G   26G   32% /
    devtmpfs       devtmpfs  912M       0  912M    0% /dev
    tmpfs          tmpfs     920M     98M  823M   11% /run
    tmpfs          tmpfs     184M       0  184M    0% /run/user/993
    innodb_io_capacity = 663
    innodb_io_capacity = 707
    innodb_io_capacity = 695
    innodb_io_capacity = 769
    Full Reads: 70620
    Full Writes: 64000
    innodb_io_capacity = 2133
    innodb_io_capacity = 1600
    innodb_io_capacity = 1280
    innodb_io_capacity = 914
    Full Reads: 76560
    Full Writes: 66601
    innodb_io_capacity = 2220
    innodb_io_capacity = 1665
    innodb_io_capacity = 1332
    innodb_io_capacity = 951
  9. SeaTea
    SeaTea Member
    49
    13
    the Netherlands
    5:17 AM
    Nginx:1.11
    MariaDB-10
    There are 2 versions of ioping :
    [root@dev ~]# ioping -v
    ioping 0.6
    [root@dev ~]# which ioping
    [root@dev ~]# ls -lah /usr/local/bin/ioping
    -rwxr-xr-x 1 root root 37K Feb  5 09:24 /usr/local/bin/ioping
    [root@dev ~]# ls -lah /usr/bin/ioping
    -rwxr-xr-x 1 root root 25K Jul 16  2015 /usr/bin/ioping
    [root@dev ~]# /usr/local/bin/ioping -v
    ioping 0.6
    [root@dev ~]# /usr/bin/ioping -v
    ioping 0.9
    The one dated today I just re-installed via iopingcentmin.sh 0.9.8
    When I look at this script, inside is :
    #!/bin/bash
    # Copyright (C) 2011
    # Program: iopingcentmin.sh
    # Shell script wrapper for ioping code.google.com/p/ioping/
    # disk I/O latency measuring tool
    # Updated: September 6th, 2011 AEST
    DESC='shell wrapper script'
    AUTHOR='by George Liu (eva2000)'
    NAME='iopingcentmin'
    SCRIPT="$NAME.sh"
    SCRIPTURL='code.google.com/p/ioping/'
    VER='0.9.8'
    URL='http://vbtechsupport.com/1239/'
    IOPINGVER='0.6'
    REQUESTSIZE='4 32 64 256'
    # Set paths
    MAKE="$(which make 2>/dev/null)"
    SEEKER="$(which seeker 2>/dev/null)"
    So it seems to install version 0.6 ??
    59,950
    12,556
    1:17 PM
    @SeaTea yeah centmin.sh menu 13 was outdated with my old ioping script which installed 0.60
    just updated 123.09beta01 centmin.sh menu 13 to use EPEL yum version of ioping at update centmin.sh menu option 13 · centminmod/centminmod@5c202d4 · GitHub
    Also updated the script to use /usr/bin/ioping specifically so should work now
    System Info
    /dev/ploop28343p1 ext4       25G   18G  5.7G  76% /
    innodb_io_capacity = 939
    innodb_io_capacity = 1201
    innodb_io_capacity = 855
    innodb_io_capacity = 818
    Full Reads: 3786
    Full Writes: 117928
    innodb_io_capacity = 3930
    innodb_io_capacity = 2948
    innodb_io_capacity = 2358
    innodb_io_capacity = 1684
    Full Reads: 3716
    Full Writes: 116267
    innodb_io_capacity = 3875
    innodb_io_capacity = 2906
    innodb_io_capacity = 2325
    innodb_io_capacity = 1660
  11. dorobo
    dorobo Active Member
    420
    104
    11:17 AM
    latest
    latest
    System Info
    CPU: 2 x Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz
    2.6.32-42-pve
    /dev/simfs     simfs      15G   12G  3.7G  76% /
    devtmpfs       devtmpfs  512M     0  512M   0% /dev
    tmpfs          tmpfs     512M     0  512M   0% /dev/shm
    tmpfs          tmpfs     512M  160K  512M   1% /run
    tmpfs          tmpfs     512M     0  512M   0% /sys/fs/cgroup
    tmpfs          tmpfs     103M     0  103M   0% /run/user/994
    tmpfs          tmpfs     103M     0  103M   0% /run/user/0
    innodb_io_capacity = 1415
    90 change to 100
    innodb_io_capacity = 1060
    innodb_io_capacity = 597
    Full Reads: 24380
    Full Writes: 56109
    innodb_io_capacity = 1870
    innodb_io_capacity = 1402
    innodb_io_capacity = 1122
    innodb_io_capacity = 801
    Full Reads: 13149
    Full Writes: 57690
    innodb_io_capacity = 1923
    innodb_io_capacity = 1442
    innodb_io_capacity = 1153
    innodb_io_capacity = 824
    59,950
    12,556
    1:17 PM
    @dorobo thanks
    getting there, finding a dynamic formula will need lots of testing to ensure i do not set the value too high or too low across systems :)
  13. SeaTea
    SeaTea Member
    49
    13
    the Netherlands
    5:17 AM
    Nginx:1.11
    MariaDB-10
    Thanks ! Works ok now:
    System Info
    CPU(s):                2
    Socket(s):             2
    NUMA node(s):          1
    CPU family:            6
    Model:                 44
    Model name:            Westmere E56xx/L56xx/X56xx (Nehalem-C)
    Stepping:              1
    CPU MHz:               2199.998
    BogoMIPS:              4399.99
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              4096K
    /dev/mapper/centos_sim-root xfs        50G   12G   39G  23% /
    devtmpfs                    devtmpfs  1.9G     0  1.9G   0% /dev
    tmpfs                       tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs                       tmpfs     1.9G   73M  1.8G   4% /run
    tmpfs                       tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mapper/centos_sim-home xfs        96G  3.7G   92G   4% /home
    /dev/loop0                  ext4      3.7G   20M  3.5G   1% /tmp
    /dev/vda1                   xfs       497M  265M  233M  54% /boot
    tmpfs                       tmpfs     380M     0  380M   0% /run/user/0
    tmpfs                       tmpfs     380M     0  380M   0% /run/user/497
    innodb_io_capacity = 122
    innodb_io_capacity = 242
    innodb_io_capacity = 335
    innodb_io_capacity = 169
    Full Reads: 3653
    Full Writes: 2578
    innodb_io_capacity = 515
    Full Reads: 3653
    Full Writes: 2578
    59,950
    12,556
    1:17 PM
    Cheers fio does look like the better calculator for iops for innodb setting. Added a version number to system info heading so you know when i update the script
    will always be at same url so same running method
    System Info (0.1)
    innodb_io_capacity = 1235
    innodb_io_capacity = 1015
    innodb_io_capacity = 1438
    innodb_io_capacity = 1513
    Full Reads: 3257
    Full Writes: 116267
    innodb_io_capacity = 4650
    Full Reads: 3736
    Full Writes: 114652
    innodb_io_capacity = 3821
    innodb_io_capacity = 2866
    innodb_io_capacity = 2293
    innodb_io_capacity = 1637
    innodb_io_capacity = 4586
    59,950
    12,556
    1:17 PM
    on 2GB DigitalOcean KVM VPS
    System Info (0.1)
    CPU(s):                2
    Socket(s):             2
    NUMA node(s):          1
    CPU family:            6
    Model:                 62
    Model name:            Intel(R) Xeon(R) CPU E5-2630L v2 @ 2.40GHz
    Stepping:              4
    CPU MHz:               2399.998
    BogoMIPS:              4799.99
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              256K
    L3 cache:              15360K
    3.10.0-229.11.1.el7.x86_64
    /dev/vda1      ext4       40G   25G   13G  66% /
    devtmpfs       devtmpfs  993M     0  993M   0% /dev
    tmpfs          tmpfs    1001M     0 1001M   0% /dev/shm
    tmpfs          tmpfs    1001M   25M  977M   3% /run
    tmpfs          tmpfs    1001M     0 1001M   0% /sys/fs/cgroup
    tmpfs          tmpfs     201M     0  201M   0% /run/user/994
    tmpfs          tmpfs     201M     0  201M   0% /run/user/0
    innodb_io_capacity = 601
    innodb_io_capacity = 604
    innodb_io_capacity = 1163
    innodb_io_capacity = 1159
    Full Reads: 75155
    Full Writes: 10317
    innodb_io_capacity = 343
    innodb_io_capacity = 257
    innodb_io_capacity = 206
    innodb_io_capacity = 147
    innodb_io_capacity = 1031
    Full Reads: 78019
    Full Writes: 10395
    innodb_io_capacity = 346
    innodb_io_capacity = 259
    innodb_io_capacity = 207
    innodb_io_capacity = 148
    innodb_io_capacity = 1039
    59,950
    12,556
    1:17 PM
    On SoYouStart E3-1245v2 3x120GB SSD
    System Info (0.1)
    CPU(s):                8
    Socket(s):             1
    NUMA node(s):          1
    CPU family:            6
    Model:                 58
    Model name:            Intel(R) Xeon(R) CPU E3-1245 V2 @ 3.40GHz
    Stepping:              9
    CPU MHz:               3798.968
    BogoMIPS:              6784.60
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              256K
    L3 cache:              8192K
    /dev/md1       xfs        20G  9.2G   11G  47% /
    devtmpfs       devtmpfs   16G     0   16G   0% /dev
    tmpfs          tmpfs      16G     0   16G   0% /dev/shm
    tmpfs          tmpfs      16G  493M   16G   4% /run
    tmpfs          tmpfs      16G     0   16G   0% /sys/fs/cgroup
    /dev/md2       xfs        86G 1001M   85G   2% /home
    tmpfs          tmpfs     3.2G     0  3.2G   0% /run/user/0
    innodb_io_capacity = 464
    474 change to 200
    innodb_io_capacity = 200
    Full Reads: 34859
    Full Writes: 7494
    innodb_io_capacity = 249
    innodb_io_capacity = 149
    innodb_io_capacity = 107
    innodb_io_capacity = 936
    Full Reads: 35158
    Full Writes: 7536
    innodb_io_capacity = 251
    innodb_io_capacity = 188
    innodb_io_capacity = 150
    innodb_io_capacity = 942
    59,950
    12,556
    1:17 PM
    4GB Linode KVM VPS
    System Info (0.1)
    CPU(s):                4
    Socket(s):             4
    NUMA node(s):          1
    CPU family:            6
    Model:                 63
    Stepping:              2
    CPU MHz:               2499.996
    BogoMIPS:              5001.32
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              256K
    L3 cache:              30720K
    4.1.5-x86_64-linode61
    /dev/sda       ext4    70G   25G   44G  37% /
    tmpfs          tmpfs  2.0G  128K  2.0G   1% /dev/shm
    tmpfs          tmpfs  2.0G  7.3M  2.0G   1% /tmp
    innodb_io_capacity = 596
    innodb_io_capacity = 550
    innodb_io_capacity = 1009
    innodb_io_capacity = 1082
    Full Reads: 49136
    Full Writes: 47716
    innodb_io_capacity = 1590
    innodb_io_capacity = 1192
    innodb_io_capacity = 954
    innodb_io_capacity = 681
    innodb_io_capacity = 3181
    Full Reads: 54668
    Full Writes: 58964
    innodb_io_capacity = 1965
    innodb_io_capacity = 1474
    innodb_io_capacity = 1179
    innodb_io_capacity = 842
    59,950
    12,556
    1:17 PM
    768MB Vultr older 3.6Ghz KVM VPS
    System Info (0.1)
    CPU(s):                1
    Socket(s):             1
    NUMA node(s):          1
    CPU family:            6
    Model:                 60
    Stepping:              1
    CPU MHz:               3600.016
    BogoMIPS:              7200.03
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              4096K
    2.6.32-573.1.1.el6.x86_64
    /dev/vda1      ext4    15G   12G  2.9G  80% /
    tmpfs          tmpfs  372M     0  372M   0% /dev/shm
    tmpfs          tmpfs  372M   44K  372M   1% /tmp
    innodb_io_capacity = 731
    innodb_io_capacity = 713
    innodb_io_capacity = 1181
    innodb_io_capacity = 1221
    Full Reads: 27334
    Full Writes: 20134
    innodb_io_capacity = 671
    innodb_io_capacity = 503
    innodb_io_capacity = 402
    innodb_io_capacity = 287
    innodb_io_capacity = 2013
    Full Reads: 23997
    Full Writes: 21497
    innodb_io_capacity = 716
    innodb_io_capacity = 537
    innodb_io_capacity = 429
    innodb_io_capacity = 307
    innodb_io_capacity = 2149
    59,950
    12,556
    1:17 PM
    newer but slower clocked 768MB Vultr 2.4Ghz KVM VPS
    here ioping shows difference between old and new Vultr instance above
    System Info (0.1)
    CPU(s):                1
    Socket(s):             1
    NUMA node(s):          1
    CPU family:            6
    Model:                 60
    Model name:            Virtual CPU e7da7129d3ee
    Stepping:              1
    CPU MHz:               2399.996
    BogoMIPS:              4799.99
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              4096K
    3.10.0-229.14.1.el7.x86_64
    /dev/vda1      ext3       20G   12G  6.9G  64% /
    devtmpfs       devtmpfs  489M     0  489M   0% /dev
    tmpfs          tmpfs     497M     0  497M   0% /dev/shm
    tmpfs          tmpfs     497M   51M  447M  11% /run
    tmpfs          tmpfs     497M     0  497M   0% /sys/fs/cgroup
    /dev/loop0     ext4      3.7G   16M  3.5G   1% /tmp
    tmpfs          tmpfs     100M     0  100M   0% /run/user/994
    tmpfs          tmpfs     100M     0  100M   0% /run/user/0
    98 change to 100
    210 change to 150
    innodb_io_capacity = 573
    Full Reads: 26859
    Full Writes: 23206
    innodb_io_capacity = 773
    innodb_io_capacity = 580
    innodb_io_capacity = 331
    innodb_io_capacity = 2320
    Full Reads: 27675
    Full Writes: 23339
    innodb_io_capacity = 777
    innodb_io_capacity = 583
    innodb_io_capacity = 2333
    59,950
    12,556
    1:17 PM
    from my cenminmod.com cluster of VPS servers
    1GB Cloudshard OpenVZ
    System Info (0.1)
    CPU: 2 x Intel(R) Xeon(R) CPU E3-1271 v3 @ 3.60GHz
    2.6.32-042stab106.4
    /dev/simfs     simfs      20G   12G  8.3G  59% /
    innodb_io_capacity = 963
    innodb_io_capacity = 1047
    innodb_io_capacity = 1497
    innodb_io_capacity = 1410
    Full Reads: 14381
    Full Writes: 117928
    innodb_io_capacity = 4717
    Full Reads: 10104
    Full Writes: 117928
    2GB Wable OpenVZ
    System Info (0.1)
    CPU: 2 x Intel(R) Xeon(R) CPU E5-2643 v3 @ 3.40GHz
    2.6.32-042stab108.5
    /dev/simfs     simfs      20G   12G  8.2G  60% /
    none           devtmpfs  1.0G  4.0K  1.0G   1% /dev
    none           tmpfs     1.0G     0  1.0G   0% /dev/shm
    innodb_io_capacity = 1831
    innodb_io_capacity = 1888
    innodb_io_capacity = 3885
    innodb_io_capacity = 2951
    Full Reads: 8205
    Full Writes: 90714
    innodb_io_capacity = 3023
    innodb_io_capacity = 2267
    innodb_io_capacity = 1814
    innodb_io_capacity = 1295
    innodb_io_capacity = 4535
    Full Reads: 3859
    Full Writes: 99457
    innodb_io_capacity = 3315
    innodb_io_capacity = 2486
    innodb_io_capacity = 1989
    innodb_io_capacity = 1420
    innodb_io_capacity = 4972
    512MB Ramnode CKVM
    System Info (0.1)
    CPU(s):                2
    Socket(s):             2
    NUMA node(s):          1
    CPU family:            6
    Model:                 13
    Stepping:              3
    CPU MHz:               2600.000
    BogoMIPS:              5200.00
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              4096K
    2.6.32-573.12.1.el6.x86_64
    /dev/vda1            ext4    49G   18G   29G  39% /
    tmpfs                tmpfs  246M     0  246M   0% /dev/shm
    /home/usertmp_donotdelete
                         ext4   3.7G  7.7M  3.5G   1% /tmp
    innodb_io_capacity = 683
    innodb_io_capacity = 673
    innodb_io_capacity = 1452
    innodb_io_capacity = 1560
    Full Reads: 57727
    Full Writes: 55402
    innodb_io_capacity = 1846
    innodb_io_capacity = 1385
    innodb_io_capacity = 1108
    innodb_io_capacity = 791
    innodb_io_capacity = 3693
    Full Reads: 48558
    Full Writes: 53603
    innodb_io_capacity = 1786
    innodb_io_capacity = 1340
    innodb_io_capacity = 1072
    innodb_io_capacity = 765
    innodb_io_capacity = 3573
    2GB Linode KVM Singapore
    System Info (0.1)
    CPU(s):                1
    Socket(s):             1
    NUMA node(s):          1
    CPU family:            6
    Model:                 62
    Model name:            Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz
    Stepping:              4
    CPU MHz:               2800.000
    BogoMIPS:              5602.33
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              256K
    L3 cache:              25600K
    /dev/root      ext4       20G   14G  5.1G  74% /
    devtmpfs       devtmpfs  494M     0  494M   0% /dev
    tmpfs          tmpfs     496M     0  496M   0% /dev/shm
    tmpfs          tmpfs     496M   58M  438M  12% /run
    tmpfs          tmpfs     496M     0  496M   0% /sys/fs/cgroup
    /dev/loop0     ext4      3.7G   17M  3.5G   1% /tmp
    innodb_io_capacity = 624
    innodb_io_capacity = 623
    innodb_io_capacity = 121
    462 change to 200
    Full Reads: 56109
    Full Writes: 46282
    innodb_io_capacity = 1542
    innodb_io_capacity = 1157
    innodb_io_capacity = 925
    innodb_io_capacity = 661
    innodb_io_capacity = 3085
    Full Reads: 56109
    Full Writes: 43807
    innodb_io_capacity = 1460
    innodb_io_capacity = 1095
    innodb_io_capacity = 876
    innodb_io_capacity = 625
    innodb_io_capacity = 2920
    2GB Dediserve Xen Sydney VPS
    System Info (0.1)
    CPU(s):                4
    Socket(s):             4
    NUMA node(s):          1
    CPU family:            6
    Model:                 62
    Stepping:              4
    CPU MHz:               2200.000
    BogoMIPS:              4400.00
    Hypervisor vendor:     Xen
    Virtualization type:   para
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              256K
    L3 cache:              25600K
    2.6.32-504.12.2.el6.x86_64
    /dev/xvda1           ext4    49G   17G   30G  36% /
    tmpfs                tmpfs  935M     0  935M   0% /dev/shm
    innodb_io_capacity = 1365
    innodb_io_capacity = 1373
    Full Reads: 27334
    Full Writes: 43219
    innodb_io_capacity = 1440
    innodb_io_capacity = 1080
    innodb_io_capacity = 864
    innodb_io_capacity = 617
    innodb_io_capacity = 2881
    Full Reads: 34111
    Full Writes: 26373
    innodb_io_capacity = 879
    innodb_io_capacity = 659
    innodb_io_capacity = 527
    innodb_io_capacity = 376
    innodb_io_capacity = 2637
    512MB Buyvm.net OpenVZ NJ
    System Info (0.1)
    CPU: 2 x Intel(R) Xeon(R) CPU E5-2630L 0 @ 2.00GHz
    2.6.32-openvz-042stab104.1-amd64
    /dev/simfs     simfs      50G   13G   38G  25% /
    none           devtmpfs  256M  4.0K  256M   1% /dev
    none           tmpfs     256M     0  256M   0% /dev/shm
    innodb_io_capacity = 415
    innodb_io_capacity = 526
    482 change to 200
    Full Reads: 2608
    Full Writes: 29066
    innodb_io_capacity = 968
    innodb_io_capacity = 726
    innodb_io_capacity = 581
    Full Reads: 2719
    Full Writes: 30917
    innodb_io_capacity = 1030
    innodb_io_capacity = 772
    innodb_io_capacity = 618
    innodb_io_capacity = 441
    innodb_io_capacity = 3091
    1GB SecureDragon OpenVZ Los Angeles
    System Info (0.1)
    CPU: 4 x Intel(R) Xeon(R) CPU L5640 @ 2.27GHz
    2.6.32-042stab105.14
    /dev/simfs     simfs      25G   14G   12G  54% /
    tmpfs          tmpfs      24G     0   24G   0% /sys/fs/cgroup
    devtmpfs       devtmpfs   24G     0   24G   0% /dev
    tmpfs          tmpfs      24G     0   24G   0% /dev/shm
    tmpfs          tmpfs      24G  588K   24G   1% /run
    innodb_io_capacity = 847
    innodb_io_capacity = 1335
    innodb_io_capacity = 2534
    innodb_io_capacity = 2620
    Full Reads: 21005
    Full Writes: 64000
    innodb_io_capacity = 3200
    Full Reads: 24526
    Full Writes: 67147
    innodb_io_capacity = 2238
    innodb_io_capacity = 1678
    innodb_io_capacity = 1342
    innodb_io_capacity = 959
    innodb_io_capacity = 3357
    1GB TheSkySpace Xen VPS Los Angeles
    System Info (0.1)
    /dev/ploop20169p1 ext4       25G   14G  9.3G  61% /
    tmpfs             tmpfs     512M  276K  512M   1% /run
    innodb_io_capacity = 1136
    innodb_io_capacity = 1275
    innodb_io_capacity = 1351
    Full Reads: 3211
    Full Writes: 112219
    innodb_io_capacity = 3740
    innodb_io_capacity = 2805
    innodb_io_capacity = 2244
    innodb_io_capacity = 1603
    innodb_io_capacity = 4488
    Full Reads: 3195
    Full Writes: 112219
