Beta Branch Help test innodbio.sh for MySQL Tuning
Discussion in 'Beta release code' started by eva2000, Feb 5, 2016.
    55,926
    6:45 PM
    Folks, I am tweaking the /etc/my.cnf preset templates and just need some folks to help gather some stats and test out the routine that is going to work out dynamically the optimal settings for each user's server. If you can run this command and post the output you get that would help :)
    curl -sL https://gist.github.com/centminmod/01b5ec3ebd394fa9284f/raw/innodbio.sh | bash
    example output
    innodb_io_capacity = 1800
    real    0m9.011s
    user    0m0.000s
    sys     0m0.003s
    innodb_io_capacity = 1900
    real    0m9.018s
    user    0m0.001s
    sys     0m0.002s
    innodb_io_capacity = 1300
    real    0m9.019s
    user    0m0.000s
    sys     0m0.002s
    innodb_io_capacity = 1200
    real    0m9.019s
    user    0m0.001s
    sys     0m0.002s
    Add tools/setio.sh Script
    Update: Feb 6th, 2016. Just added to Centmin Mod 123.09beta01 branch the new tools/setio.sh standalone tool which can set your MySQL server's /etc/my.cnf innodb_io_capacity variable optimally based on your server's measured disk write I/O performance numbers. This is based on the tests and feedback provided by other Centmin Mod users at Beta Branch - Help test innodbio.sh for MySQL Tuning | Centmin Mod Community
    Will be integrated into 123.09beta01's initial installation setup routine so innodb_io_capacity variable is set optimally for the user's server. You can also re-run tools/setio.sh manually to re-adjust the innodb_io_capacity variable value whenever you need to do it i.e. after upgrading disk configurations or expanding disk configuration which change the underlying disk write I/O performance.
    To run setio.sh it's as easy as running this command and it will update /etc/my.cnf innodb_io_capacity variable with the new measured value and on the fly - dynamically set globally the value on the running MariaDB MySQL server. No need to restart MySQL for the setting to register :)
    SSH command after you update to latest Centmin Mod 123.09beta01 code
    /usr/local/src/centminmod/tools/setio.sh set
    If on Centmin Mod 123.08stable or lower, you can just grab the tools/setio.sh file itself and download to tools directory to run it as well
    wget -O /usr/local/src/centminmod/tools/setio.sh https://github.com/centminmod/centminmod/raw/123.09beta01/tools/setio.sh
    chmod +x /usr/local/src/centminmod/tools/setio.sh
    Commit add tools/setio.sh · centminmod/centminmod@0bbc9be · GitHub
  2. Ahmad
    Ahmad Active Member
    209
    80
    10:45 AM
    1.9.9
    10.1.10
    2GB Premium ramnode
    [root@server ~]# curl -sL https://gist.github.com/centminmod/01b5ec3ebd394fa9284f/raw/innodbio.sh | bash
    innodb_io_capacity = 900
    real    0m9.030s
    user    0m0.019s
    sys     0m0.009s
    innodb_io_capacity = 1000
    real    0m9.035s
    user    0m0.017s
    sys     0m0.010s
    real    0m9.028s
    user    0m0.021s
    sys     0m0.008s
    [root@server ~]#
    55,926
    6:45 PM
    Cheers @Ahmad could you do another run, just updated the code to calculate averages too
  4. pamamolf
    4,101
    428
    11:45 AM
    Nginx-1.26.x
    From my dedicated servers :)
    innodb_io_capacity = 2700
    real    0m9.029s
    user    0m0.023s
    sys     0m0.010s
    innodb_io_capacity = 2800
    real    0m9.029s
    user    0m0.024s
    sys     0m0.009s
    innodb_io_capacity = 2500
    real    0m9.031s
    user    0m0.026s
    sys     0m0.007s
    real    0m9.031s
    user    0m0.025s
    sys     0m0.008s
    real    0m9.076s
    user    0m0.002s
    sys     0m0.004s
    real    0m9.066s
    user    0m0.002s
    sys     0m0.004s
    innodb_io_capacity = 0
    real    0m9.420s
    user    0m0.002s
    sys     0m0.005s
    innodb_io_capacity = 700
    real    0m9.082s
    user    0m0.002s
    sys     0m0.005s
    real    0m9.062s
    user    0m0.000s
    sys     0m0.000s
    real    0m9.055s
    user    0m0.004s
    sys     0m0.004s
    real    0m9.080s
    user    0m0.000s
    sys     0m0.000s
    real    0m9.121s
    user    0m0.000s
    sys     0m0.000s
    innodb_io_capacity = 800
    real    0m9.110s
    user    0m0.001s
    sys     0m0.003s
    innodb_io_capacity = 300
    real    0m9.126s
    user    0m0.000s
    sys     0m0.006s
    innodb_io_capacity = 500
    real    0m9.131s
    user    0m0.000s
    sys     0m0.005s
    real    0m9.083s
    user    0m0.001s
    sys     0m0.004s
    That's amazing to automate this setting :)
    innodb_io_capacity
    You will automate also the:
    innodb_read_io_threads
    and
    innodb_write_io_threads
  5. Ahmad
    Ahmad Active Member
    209
    80
    10:45 AM
    1.9.9
    10.1.10
    real    0m9.065s
    user    0m0.020s
    sys     0m0.028s
    innodb_io_capacity = 400
    real    0m9.041s
    user    0m0.015s
    sys     0m0.016s
    real    0m9.066s
    user    0m0.018s
    sys     0m0.014s
    real    0m9.046s
    user    0m0.023s
    sys     0m0.003s
    real    0m27.168s
    user    0m0.056s
    sys     0m0.037s
    real    0m27.179s
    user    0m0.079s
    sys     0m0.017s
    [root@server ~]#
    55,926
    6:45 PM
    thanks guys
    @pamamolf the read/write io_threads probably don't need it but shall see
    looks like i also need to account for values = 0 for disk performance is is more contented
    55,926
    6:45 PM
    updated the test script to read/write io threads too
    real    0m4.018s
    user    0m0.000s
    sys     0m0.003s
    innodb_io_capacity = 2000
    real    0m4.018s
    user    0m0.000s
    sys     0m0.003s
    real    0m4.018s
    user    0m0.000s
    sys     0m0.002s
    real    0m4.018s
    user    0m0.000s
    sys     0m0.003s
    real    0m12.053s
    user    0m0.001s
    sys     0m0.006s
    real    0m12.054s
    user    0m0.000s
    sys     0m0.006s
    real    0m12.052s
    user    0m0.000s
    sys     0m0.007s
    real    0m12.053s
    user    0m0.001s
    sys     0m0.006s
    innodb_read_io_threads = 2
    innodb_write_io_threads = 2
  8. pamamolf
    4,101
    428
    11:45 AM
    Nginx-1.26.x
    On three of my servers i got:
    innodb_read_io_threads = 4
    innodb_write_io_threads = 4
    innodb_read_io_threads = 6
    innodb_write_io_threads = 6
  9. rdan
    1,412
    4:45 PM
    4GB / 4 CPU Linode:
    innodb_io_capacity = 1100
    real    0m4.030s
    user    0m0.020s
    sys    0m0.003s
    real    0m4.025s
    user    0m0.017s
    sys    0m0.000s
    0 change to 100
    real    0m4.053s
    user    0m0.020s
    sys    0m0.000s
    0 change to 100
    real    0m4.050s
    user    0m0.017s
    sys    0m0.003s
    real    0m12.132s
    user    0m0.063s
    sys    0m0.000s
    real    0m12.127s
    user    0m0.050s
    sys    0m0.010s
    real    0m12.137s
    user    0m0.060s
    sys    0m0.003s
    real    0m12.133s
    user    0m0.047s
    sys    0m0.013s
    1GB / 4 CPU Ramnode Premium KVM
    innodb_io_capacity = 2200
    real    0m4.014s
    user    0m0.000s
    sys    0m0.003s
    real    0m4.022s
    user    0m0.004s
    sys    0m0.023s
    innodb_io_capacity = 2400
    real    0m4.024s
    user    0m0.005s
    sys    0m0.006s
    innodb_io_capacity = 2300
    real    0m4.024s
    user    0m0.001s
    sys    0m0.005s
    real    0m12.056s
    user    0m0.000s
    sys    0m0.009s
    real    0m12.054s
    user    0m0.004s
    sys    0m0.003s
    innodb_io_capacity = 4000
    real    0m12.054s
    user    0m0.001s
    sys    0m0.006s
    innodb_io_capacity = 3600
    real    0m12.058s
    user    0m0.007s
    sys    0m0.011s
    128GB / 12 CPU OVH Dedicated Server
    innodb_io_capacity = 3100
    real    0m4.015s
    user    0m0.000s
    sys    0m0.003s
    innodb_io_capacity = 2600
    real    0m4.013s
    user    0m0.000s
    sys    0m0.003s
    real    0m4.014s
    user    0m0.000s
    sys    0m0.001s
    real    0m4.015s
    user    0m0.000s
    sys    0m0.002s
    innodb_io_capacity = 3200
    real    0m12.028s
    user    0m0.001s
    sys    0m0.005s
    real    0m12.042s
    user    0m0.001s
    sys    0m0.004s
    innodb_io_capacity = 4500
    real    0m12.041s
    user    0m0.002s
    sys    0m0.004s
    real    0m12.039s
    user    0m0.002s
    sys    0m0.002s
    6GB / 6 CPU UltraVPS
    0 change to 100
    real    0m4.307s
    user    0m0.013s
    sys    0m0.020s
    real    0m4.048s
    user    0m0.016s
    sys    0m0.038s
    real    0m4.095s
    user    0m0.006s
    sys    0m0.042s
    real    0m4.068s
    user    0m0.003s
    sys    0m0.014s
    innodb_io_capacity = 1500
    real    0m12.279s
    user    0m0.005s
    sys    0m0.036s
    real    0m12.155s
    user    0m0.007s
    sys    0m0.017s
    real    0m12.166s
    user    0m0.004s
    sys    0m0.028s
    real    0m12.735s
    user    0m0.002s
    sys    0m0.024s
    innodb_read_io_threads = 3
    innodb_write_io_threads = 3
    1GB / 1 CPU Linode
    real    0m4.014s
    user    0m0.003s
    sys    0m0.000s
    real    0m4.010s
    user    0m0.000s
    sys    0m0.000s
    real    0m4.017s
    user    0m0.000s
    sys    0m0.000s
    real    0m4.016s
    user    0m0.000s
    sys    0m0.000s
    real    0m12.042s
    user    0m0.000s
    sys    0m0.003s
    real    0m12.051s
    user    0m0.000s
    sys    0m0.003s
    innodb_io_capacity = 1600
    real    0m12.041s
    user    0m0.000s
    sys    0m0.000s
    innodb_io_capacity = 1700
    real    0m12.041s
    user    0m0.000s
    sys    0m0.003s
    32GB / 12 CPU Linode
    real    0m4.022s
    user    0m0.010s
    sys    0m0.000s
    real    0m4.020s
    user    0m0.010s
    sys    0m0.003s
    real    0m4.043s
    user    0m0.010s
    sys    0m0.003s
    real    0m4.044s
    user    0m0.007s
    sys    0m0.013s
    real    0m12.122s
    user    0m0.037s
    sys    0m0.003s
    real    0m12.131s
    user    0m0.037s
    sys    0m0.010s
    real    0m12.126s
    user    0m0.043s
    sys    0m0.000s
    real    0m12.134s
    user    0m0.037s
    sys    0m0.020s
    55,926
    6:45 PM
    thanks looks like i need to work on the formula for those 100 iops values
    55,926
    6:45 PM
    @RoldanLT fixed the formula for those 100 iops values :)
  12. rdan
    1,412
    4:45 PM
    Do you want me to run on every server? :D
    55,926
    6:45 PM
    maybe just ones which reported 100 iops
  14. rdan
    1,412
    4:45 PM
    4GB / 4 CPU Linode:
    innodb_io_capacity = 1160
    real    0m3.025s
    user    0m0.017s
    sys    0m0.007s
    innodb_io_capacity = 976
    real    0m3.025s
    user    0m0.017s
    sys    0m0.000s
    innodb_io_capacity = 138
    real    0m3.043s
    user    0m0.020s
    sys    0m0.000s
    innodb_io_capacity = 135
    real    0m3.044s
    user    0m0.020s
    sys    0m0.000s
    innodb_io_capacity = 140
    real    0m9.143s
    user    0m0.060s
    sys    0m0.003s
    innodb_io_capacity = 122
    real    0m9.136s
    user    0m0.057s
    sys    0m0.003s
    innodb_io_capacity = 222
    real    0m9.138s
    user    0m0.057s
    sys    0m0.007s
    innodb_io_capacity = 198
    real    0m9.146s
    user    0m0.053s
    sys    0m0.007s
    innodb_io_capacity = 1222
    real    0m3.040s
    user    0m0.006s
    sys    0m0.028s
    innodb_io_capacity = 516
    real    0m3.029s
    user    0m0.002s
    sys    0m0.021s
    real    0m3.066s
    user    0m0.007s
    sys    0m0.022s
    innodb_io_capacity = 992
    real    0m3.071s
    user    0m0.009s
    sys    0m0.008s
    innodb_io_capacity = 930
    real    0m9.414s
    user    0m0.007s
    sys    0m0.053s
    innodb_io_capacity = 1096
    real    0m9.117s
    user    0m0.005s
    sys    0m0.040s
    innodb_io_capacity = 1262
    real    0m9.186s
    user    0m0.012s
    sys    0m0.046s
    innodb_io_capacity = 1775
    real    0m9.192s
    user    0m0.001s
    sys    0m0.039s
    55,926
    6:45 PM
    looks more accurate though that linode seems low for iops - though could be your forum is much busier disk I/O wise :)
    here's this forum's 4GB Linode
    innodb_io_capacity = 685
    real    0m3.011s
    user    0m0.000s
    sys     0m0.003s
    innodb_io_capacity = 932
    real    0m3.008s
    user    0m0.000s
    sys     0m0.000s
    innodb_io_capacity = 825
    real    0m3.016s
    user    0m0.000s
    sys     0m0.003s
    innodb_io_capacity = 842
    real    0m3.014s
    user    0m0.000s
    sys     0m0.000s
    innodb_io_capacity = 832
    real    0m9.048s
    user    0m0.000s
    sys     0m0.003s
    innodb_io_capacity = 910
    real    0m9.043s
    user    0m0.000s
    sys     0m0.007s
    innodb_io_capacity = 1458
    real    0m9.046s
    user    0m0.003s
    sys     0m0.000s
    innodb_io_capacity = 1496
    real    0m9.040s
    user    0m0.003s
    sys     0m0.000s
  16. rdan
    1,412
    4:45 PM
    Yes, all of those server I have tested has busy sites hosted running Live :D.
    55,926
    6:45 PM
    i'll adjust the formula down a bit as it will be applied on fresh installs so no load so need to account for load
    55,926
    6:45 PM
    updated the formula to not set it so high
    on 4GB Linode
    innodb_io_capacity = 298
    real    0m2.009s
    user    0m0.000s
    sys     0m0.003s
    innodb_io_capacity = 399
    real    0m2.009s
    user    0m0.000s
    sys     0m0.003s
    innodb_io_capacity = 428
    real    0m2.029s
    user    0m0.000s
    sys     0m0.013s
    innodb_io_capacity = 542
    real    0m2.013s
    user    0m0.000s
    sys     0m0.000s
    innodb_io_capacity = 393
    real    0m6.042s
    user    0m0.000s
    sys     0m0.000s
    innodb_io_capacity = 316
    real    0m6.047s
    user    0m0.003s
    sys     0m0.007s
    innodb_io_capacity = 504
    real    0m6.045s
    user    0m0.000s
    sys     0m0.003s
    innodb_io_capacity = 499
    real    0m6.036s
    user    0m0.000s
    sys     0m0.003s
    on 1GB theskyspace.com OpenVZ
    innodb_io_capacity = 777
    real    0m2.011s
    user    0m0.001s
    sys     0m0.001s
    innodb_io_capacity = 809
    real    0m2.018s
    user    0m0.000s
    sys     0m0.003s
    innodb_io_capacity = 467
    real    0m2.018s
    user    0m0.000s
    sys     0m0.002s
    innodb_io_capacity = 485
    real    0m2.018s
    user    0m0.000s
    sys     0m0.003s
    innodb_io_capacity = 451
    real    0m6.052s
    user    0m0.001s
    sys     0m0.006s
    innodb_io_capacity = 488
    real    0m6.052s
    user    0m0.001s
    sys     0m0.006s
    innodb_io_capacity = 690
    real    0m6.053s
    user    0m0.001s
    sys     0m0.004s
    innodb_io_capacity = 647
    real    0m6.052s
    user    0m0.002s
    sys     0m0.005s
    55,926
    6:45 PM
    new version with 2 methods of calculation via ioping and fio
    ioping calculated
    innodb_io_capacity = 874
    innodb_io_capacity = 641
    innodb_io_capacity = 937
    innodb_io_capacity = 991
    innodb_io_capacity = 742
    innodb_io_capacity = 696
    fio calculated
    Full Reads: 3923
    Full Writes: 117928
    innodb_io_capacity = 2358
    innodb_io_capacity = 1684
    innodb_io_capacity = 1310
    innodb_io_capacity = 1072
    Full Reads: 3788
    Full Writes: 117928
  20. ModeltogTossen
    313
    97
    Denmark
    10:45 AM
    1.9.12
    10.0.23
    And here one run from me - 8 GB vps on own vmware host - CMM is not optimized in any way manually - only by menu options.
    [root@sarah ~]# curl -sL https://gist.github.com/centminmod/01b5ec3ebd394fa9284f/raw/innodbio.sh | bash
    ioping calculated
    innodb_io_capacity = 670
    innodb_io_capacity = 753
    innodb_io_capacity = 684
    innodb_io_capacity = 993
    innodb_io_capacity = 841
    innodb_io_capacity = 848
    fio calculated
    Full Reads: 1853
    Full Writes: 283
    Full Reads: 1913
    Full Writes: 252
