Nginx Help setting a nginx reverse proxy
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by apidevlab, Apr 16, 2017.
  1. apidevlab
    apidevlab Member
    91
    33
    /dev/null
    12:48 PM
    1.11.1
    5.2.14-122
    I have installed semaphore and ansible with success, I created a vhost via option 2 and this is configured and working as it should.
    semaphore provide an example reverse proxy I am stupmed as to how I can merge this into the current centminmod produced ssl based .conf so I can use semaphore on the domain as set:
    Anyone care to help?
    45,441
    10,312
    10:48 PM
    looks like just this part of example reverse proxy goes into your centminmod nginx vhost domain.com.ssl.conf file with addition of proxy_http_version 1.1; line
    # disable any limits to avoid HTTP 413 for large image uploads
    client_max_body_size 0;
    # required to avoid HTTP 411: see Issue #1486 (https://github.com/docker/docker/issues/1486)
    chunked_transfer_encoding on;
      proxy_pass http://semaphore_api/;
      proxy_set_header Host $http_host;
      proxy_set_header X-Real-IP $remote_addr;
      proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
      proxy_set_header X-Forwarded-Proto $scheme;
      proxy_buffering off;
      proxy_request_buffering off;
      # this is necessary for us to be able to disable request buffering in all cases
    location /api/ws {
      proxy_pass http://semaphore_api/api/ws;
      proxy_set_header Upgrade $http_upgrade;
      proxy_set_header Connection "upgrade";
      proxy_set_header Origin "";
    and only this part of example goes into /usr/local/nginx/conf/nginx.conf which http{} context
    upstream semaphore_api {
    server semaphore_api:3000;
    assuming proxy_pass defined upstream location is working (semaphore_api:3000)
  3. apidevlab
    apidevlab Member
    91
    33
    /dev/null
    12:48 PM
    1.11.1
    5.2.14-122
    I have not so far been able to merge them, I keep getting errors on ngxreload...
    Reloading nginx configuration (via systemctl):  Job for nginx.service failed because the control process exited with error code. See "systemctl status nginx.service" and "journalctl -xe" for details.
    As you highlighted proxy_http_version 1.1 do I need to update/install that on my box, it's not something I spotted?
    Also:
    If you mean do I have semaphore working on port 3000 the answer is yes.
    Will keep at it and read some more on the nginx/semaphore docs :)
    45,441
    10,312
    10:48 PM
    test nginx config to see where error is
    nginx -t
