vBulletin [Help] Mod-Rewrite in Nginx
Discussion in 'Forum software usage' started by computer19852007, Jun 25, 2014.
  1. computer19852007
    computer19852007 Member
    84
    11:23 PM
    Centmin Mod 1.2.3-eva2000.06
    MariaDB 5.5.34
    i have read this topic http://centminmod.com/nginx_configure_vbulletin4_friendly_urls.html
    I have used Vbulletin Suite 4.2.2 P1 (forum and CMS)
    and i have config in this tip, but it not working in CMS when i add new content and this show error "404 Not Found"
    my forum link mark: content/1-home/addcontent => "404 Not Found"
    Please Help me.
    49,869
    11,482
    2:23 AM
    post your entire contents for your domain's Nginx vhost file at /usr/local/nginx/conf/conf.d/yourdomain.com.conf
  3. computer19852007
    84
    11:23 PM
    MariaDB 5.5.34
    @eva2000
        listen       80;
        server_name diendantinhoc.vn;
        return       301 http://www.diendantinhoc.vn$request_uri;
      server_name www.diendantinhoc.vn;
    ssi  on;
      access_log /home/nginx/domains/diendantinhoc.vn/log/access.log combined buffer=32k;
      error_log /home/nginx/domains/diendantinhoc.vn/log/error.log;
      root /home/nginx/domains/diendantinhoc.vn/public;
    autoindex  on;
      #autoindex_localtime on;
      #try_files         / /index.php;
    try_files $uri $uri/ @rewrite;
            location /includes {
            allow 127.0.0.1;
            deny all;
            location /packages {
            allow 127.0.0.1;
            deny all;
            location /vb {
            allow 127.0.0.1;
            deny all;
            location /admincp {
            #auth_basic "Private";
            #auth_basic_user_file /usr/local/nginx/conf/htpasswd;
    location @rewrite {
        # Forum
        rewrite    /threads/.*                /showthread.php?$uri&$args      last;
        rewrite    /forums/.*                /forumdisplay.php?$uri&$args    last;
        rewrite    /members/.*                /member.php?$uri&$args          last;
        rewrite    /blogs/.*                /blog.php?$uri&$args            last;
        rewrite    /entries/.*                /entry.php?$uri&$args           last;
        #rewrite    /content/.*                /content.php?$uri&$args           last;
       # rewrite    /widget/config/([0-9]+)                /widget.php?r=config/$1&$args           last;
        # rewrite ^widget/config/([0-9]+) widget.php?r=config/$1&$args           last;
        # MVC
        rewrite    ^/(?:(.*?)(?:/|$))(.*|$)$        /$1.php?r=$2                    last;
    49,869
    11,482
    2:23 AM
    try commenting out the include line for include /usr/local/nginx/conf/block.conf; and restart Nginx
  5. computer19852007
    84
    11:23 PM
    MariaDB 5.5.34
    Thank you very much @eva2000
    It Working
    49,869
    11,482
    2:23 AM
    yeah the block.conf might have a few lines that cause problems, might need to remove some like
    limit_req_status 444;
    if ($args ~ CtrlFunc_* ) {   return 444; }
    set $my_var 0;
    set $the_var 2;
    if ($request_method = POST ) {    set $my_var 1; }
    if ($args = / ) {    set $the_var 1; }
    if ($my_var = $the_var ) { return 444; }
    # from
    # http://www.howtoforge.com/nginx-how-to-block-exploits-sql-injections-file-injections-spam-user-agents-etc
        ## Block SQL injections
        set $block_sql_injections 0;
        if ($query_string ~ "union.*select.*\(") {
            set $block_sql_injections 1;
        if ($query_string ~ "union.*all.*select.*") {
        if ($query_string ~ "concat.*\(") {
        if ($block_sql_injections = 1) {
            return 403;
        ## Block file injections
        set $block_file_injections 0;
        if ($query_string ~ "[a-zA-Z0-9_]=http://") {
            set $block_file_injections 1;
        if ($query_string ~ "[a-zA-Z0-9_]=(\.\.//?)+") {
        if ($query_string ~ "[a-zA-Z0-9_]=/([a-z0-9_.]//?)+") {
        if ($block_file_injections = 1) {
            return 403;
        ## Block common exploits
        set $block_common_exploits 0;
        if ($query_string ~ "(<|%3C).*script.*(>|%3E)") {
            set $block_common_exploits 1;
        if ($query_string ~ "GLOBALS(=|\[|\%[0-9A-Z]{0,2})") {
        if ($query_string ~ "_REQUEST(=|\[|\%[0-9A-Z]{0,2})") {
        if ($query_string ~ "proc/self/environ") {
        if ($query_string ~ "mosConfig_[a-zA-Z_]{1,21}(=|\%3D)") {
        if ($query_string ~ "base64_(en|de)code\(.*\)") {
        if ($block_common_exploits = 1) {
            return 403;
    If you do have time, you can try commenting some out until you find the problem :)
  7. computer19852007
    84
    11:23 PM
    MariaDB 5.5.34
    i have remove it #Blocking HTTP POST Attack, after my forum working, but i don't know my forum will protect HTTP POST Attack
    Thank @eva2000
    49,869
    11,482
    2:23 AM
    yeah removing the following should fix it.. will actually update .07 beta 21 and remove these lines
    set $my_var 0;
    set $the_var 2;
