vBulletin [Help] it can not Redirect to Home Page when Login complete
Discussion in 'Forum software usage' started by computer19852007, Jul 10, 2015.
  1. computer19852007
    computer19852007 Member
    84
    2:41 PM
    Centmin Mod 1.2.3-eva2000.06
    MariaDB 5.5.34
    I have upgrade Centmin Mod v1.2.3-eva2000.07 ( with: PHP 5.4.42 and 5.5.44-MariaDB),
    i have a Problem: When i login in my account in vbulletin, it show Popup Login Complete, but it can not Redirect to Home Page.
    I have attach a image
    Please help me @eva2000
    Thanks you
    55,952
    5:41 PM
    Can you post your full vbulletin domain's nginx vhost file in CODE tags ?
  3. computer19852007
    84
    2:41 PM
    MariaDB 5.5.34
    Please help me \
    Thanks @eva2000
        listen       80;
        server_name diendantinhoc.vn;
        return       301 https://www.diendantinhoc.vn$request_uri;
    server_name www.diendantinhoc.vn;
    # Cloudflare
    set_real_ip_from 204.93.240.0/24;
    set_real_ip_from 204.93.177.0/24;
    set_real_ip_from 199.27.128.0/21;
    set_real_ip_from 173.245.48.0/20;
    set_real_ip_from 103.21.244.0/22;
    set_real_ip_from 103.22.200.0/22;
    set_real_ip_from 103.31.4.0/22;
    set_real_ip_from 141.101.64.0/18;
    set_real_ip_from 108.162.192.0/18;
    set_real_ip_from 190.93.240.0/20;
    set_real_ip_from 188.114.96.0/20;
    set_real_ip_from 197.234.240.0/22;
    set_real_ip_from 198.41.128.0/17;
    set_real_ip_from 162.158.0.0/15;
    set_real_ip_from 104.16.0.0/12;
    real_ip_header CF-Connecting-IP;
    #ngx_pagespeed & ngx_pagespeed handler
    ssi  on;
      access_log /home/nginx/domains/diendantinhoc.vn/log/access.log combined buffer=32k;
      error_log /home/nginx/domains/diendantinhoc.vn/log/error.log;
      root /home/nginx/domains/diendantinhoc.vn/public;
    autoindex  on;
      #autoindex_localtime on;
      #try_files         / /index.php;
    try_files $uri $uri/ @rewrite;
            location /includes {
            allow 127.0.0.1;
            deny all;
            location /packages {
            allow 127.0.0.1;
            deny all;
    location /archive {
                    rewrite ^/archive/index.php/t-([0-9]+)\.html /archive/index.php?t-$1.html last;
                    rewrite ^/archive/index.php/f-([0-9]+)\.html /archive/index.php?f-$1.html last;
                    rewrite ^/archive/index.php/f-([0-9]+)-p-([0-9]+)\.html /archive/index.php?f-$1-p-$1.html last;
    location @rewrite {
        # Forum
        rewrite    /threads/.*                /showthread.php?$uri&$args      last;
        rewrite    /forums/.*                /forumdisplay.php?$uri&$args    last;
        rewrite    /members/.*                /member.php?$uri&$args          last;
        rewrite    /blogs/.*                /blog.php?$uri&$args            last;
        rewrite    /entries/.*                /entry.php?$uri&$args           last;
        #rewrite    /content/.*                /content.php?$uri&$args           last;
        # MVC
        rewrite    ^/(?:(.*?)(?:/|$))(.*|$)$        /$1.php?r=$2                    last;
    55,952
    5:41 PM
    what happens if you disable ngx_pagespeed and/or cloudflare ?
  5. computer19852007
    84
    2:41 PM
    MariaDB 5.5.34
    I have used cloudflare and custom file pagespeed.conf and i have change Line 107
    #pagespeed DisableFilters rewrite_javascript;
    to
    Because vBulletin 4.2.3 Error with Google Page Speed
    Please Help me @eva2000
    55,952
    5:41 PM
  7. computer19852007
    84
    2:41 PM
    MariaDB 5.5.34
    i have restart nginx show
    Is it error?
  8. computer19852007
    84
    2:41 PM
    MariaDB 5.5.34
    I have defaut Config, but it can not redirect in vbulletin, have i send infomation of My VPS, can you help me?
    Thanks @eva2000
    55,952
    5:41 PM
    no error info message only Nginx PageSpeed - 1.9.32.1 is not playing well. | Centmin Mod Community - those messages should be gone in latest nginx and ngx_pagespeed, if you still see them, then you need to update to latest .07 stable or .08 beta03 depending what you use now + recompile/update nginx via centmin.sh menu option 4
    unfortunately, you're on your own as Centmin Mod is provided as is.
    For updating
    1. Upgrading the actual Centmin Mod code which you downloaded via zip file or via github. This is heart of Centmin Mod where the code is the engine that runs centmin.sh shell based menu and all the automation you're accustomed to.
    2. Upgrade software that Centmin Mod installed or manages. For this part following outline at Upgrade - How to upgrade Centmin Mod is best.
    There's 3 ways you can upgrade your .07 stable or .08 beta03 code you have on your server. They are outlined in respective upgrade sections of the first posts linked below:
    1. For .07 stable 1st post see section on upgrades Install - Centmin Mod 1.2.3-eva2000.07 stable install
    2. For .08 beta 03 1st post see section on upgrade to latest code CentOS 7.x - How to help test .08 CentOS 7 Betas with Github code ?
    3. For either .07 stable or .08 beta03 via github command line Upgrade - Working with git command line for updating Centmin Mod local copies
    Github commit log for
