HELP ! I have baned myself on centminmod
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Venucci, Oct 31, 2019.
  1. Venucci
    Venucci Member
    65
    1:08 AM
    currentyl
    • CentOS Version: i.e. 64bit / CentOS 7 64bit ?
    • Centmin Mod Version Installed: i.e. 123.09beta01
    • Nginx Version Installed: i.e. 1.17.5
    • PHP Version Installed: i.e. 7.3.11
    • MariaDB MySQL Version Installed: i.e. 10.3.18
    • When was last time updated Centmin Mod code base ? : this week
    • Persistent Config: letsencrypt y
    I have tried to connect using SFTP but i have not had the chance to connect . After trying it several times my ssh root does not work . I have tried using vpn with another ip and is working properly . How can unban my ip ? Sorry for this problem :(
    SOLVED !!!
    How To Unblock an IP Address in CSF | Liquid Web
  2. Jimmy
    364
    7:08 PM
    1.17.x
    # nano /etc/csf/csf.deny
    Remove your IP from the list.
    # nano /etc/csf/csf.allow
    Add your IP to the list.
    44,425
    10,144
    9:08 AM
  4. EckyBrazzz
    182
    8:08 PM
    @Venucci Lucky you did not change the SSH port, dropped connection and tried to log in again!
    @Jimmy Thanks, now the forum becomes like a community forum, fast response time to help a user in panic with an issue. Hope that more and more people start to act the same. Help each other! Build each other and Centmin to become the best, where even people from the Plesk forum (example) come to seek for an answer here at Centmin Mod Community Support Forums
  5. Jimmy
    364
    7:08 PM
    1.17.x
    I just stop by because there is the only place I get to use Xenforo. ;)
    In all seriousness, @eva2000 does so much hard work for free, I try to help out when I can. It's nice to have a good community. Getting answers quickly, makes everyone happy. I know I've had issues in the past and I've need help. Most of the time I get the answer pretty quick.
    Plus I'm hoping to get a discount on the centmin mod certification. :D
  6. Venucci
    Venucci Member
    65
    1:08 AM
    currentyl
    thank you ;)
    44,425
    10,144
    9:08 AM
