Drupal help drupal nginx config
Discussion in 'Blogs & CMS usage' started by hardousse, Feb 14, 2016.
  1. hardousse
    hardousse Active Member
    169
    35
    Sweden
    6:50 AM
    1.11.*
    10.1*
    hi
    i want install Drupal site with centmin setup can anyone have working nginx config for drupal to work correctly.
    Drupal version 7.4
    thank you
    55,896
    12,281
    1:50 PM
  3. VinCent
    VinCent New Member
    11:50 PM
    1.9
    5
    I responded but this Forum policy forced me to create a new thread in the "Introduction" section first, so I put everything there. Try search
  4. VinCent
    VinCent New Member
    11:50 PM
    1.9
    5
    Modufy /usr/local/nginx/conf/conf.d/EXAMPLE.COM.conf
    for Drupal 7:
    #server {
    #  listen  80;
    #  server_name d7.local;
    #  return 301 $scheme://www.d7.local$request_uri;
      server_name d7.local www.d7.local;
      access_log /home/nginx/domains/d7.local/log/access.log combined buffer=256k flush=60m;
      error_log /home/nginx/domains/d7.local/log/error.log;
      root /home/nginx/domains/d7.local/public;
      location ~ (?:^|/)\. {
      deny all;
    # This is added - our primary location block.
      index index.php;
      try_files $uri $uri/ @rewrite;
      expires max;
      # This matters if you use drush
    location = /backup {
    deny all;
      # Very rarely should these ever be accessed outside of your lan
    location ~* \.(txt|log)$ {
    allow 127.0.0.1;
    deny all;
    # This location block protects against a known attack.
    location ~ \..*/.*\.php$ {
    return 403;
    # This will rewrite our request from domain.com/node/1/ to domain.com/index.php?q=node/1
    location @rewrite {
    rewrite ^/(.*)$ /index.php?q=$1;
    # image should never be a directory. So there's no point in wasting a
    # stat to serve it that way.
      location ~ ^/sites/.*/files/imagecache/ {
      try_files $uri @rewrite;
    # We're serving a static file that ends with one of the following extensions
      location ~* \.(js|css|png|jpg|jpeg|gif|ico)$ {
      expires max;
      log_not_found off;
      include  /usr/local/nginx/conf/staticfiles.conf;
    In case you will need Drupal 8:
    # must read [URL='http://centminmod.com/getstarted.html']Getting Started Guide - CentminMod.com LEMP Nginx web stack for CentOS[/URL]
      server_name d8.local www.d8.local;
      access_log /home/nginx/domains/d8.local/log/access.log combined buffer=256k flush=60m;
      error_log /home/nginx/domains/d8.local/log/error.log;
      root /home/nginx/domains/d8.local/public;
      allow 192.168.0.36;
      deny all;
      return 403;
      location ~ ^/sites/.*/private/ {
      return 403;
      # Block access to "hidden" files and directories - names begin with a dot
      location ~ (^|/)\. {
      return 403;
      # try_files $uri @rewrite; # For Drupal <= 6
      try_files $uri /index.php?$query_string; # For Drupal >= 7
      location @rewrite {
      # Fighting with Styles? This little gem is amazing.
      # location ~ ^/sites/.*/files/imagecache/ { # For Drupal <= 6
      location ~ ^/sites/.*/files/styles/ { # For Drpal >= 7
      expires max;
      log_not_found off;
    Success!
    55,896
    12,281
    1:50 PM
  6. hardousse
    169
    35
    Sweden
    6:50 AM
    1.11.*
    10.1*
    @VinCent thank you so much for your code and your help....
  7. hardousse
    169
    35
    Sweden
    6:50 AM
    1.11.*
    10.1*
    @VinCent still one problem its about clean url all time test failed?any soltuion please
  8. nVidian
    nVidian Member
    98
    10:50 AM
    1.7.9
    5.5
    I've got this working, but of course please correct me if something wrong
    Its works for Drupal 6 & 7 and non SSL site - Just replace mydomain.tld with your domain
    mydomain.tld.conf
    # This is for redirect www to no www
       server_name www.mydomain.tld;
        return 301 http://mydomain.tld$request_uri;
            server_name mydomain.tld;
            root /home/nginx/domains/mydomain.tld/public;
    # ngx_pagespeed & ngx_pagespeed handler include /usr/local/nginx/conf/pagespeed.conf; include
    # /usr/local/nginx/conf/pagespeedhandler.conf; include /usr/local/nginx/conf/pagespeedstatslog.conf;
            location = /favicon.ico {
                    log_not_found off;
                    access_log off;
            location = /robots.txt {
                    allow all;
                    log_not_found off;
                    access_log off;
                    deny all;
                    allow 192.168.0.0/16;
                    deny all;
                    return 403;
                    # This is cool because no php is touched for static content
            location @rewrite {
                    # Some modules enforce no slash (/) at the end of the URL Else this rewrite block wouldn't be needed
                    # (GlobalRedirect)
            location @rewrite {
                    # Drupal in a subdirectory
                    rewrite ^/([^/]*)/(.*)(/?)$ /$1/index.php?q=$2&$args;
            location ~ \.php$ {
                    error_page 418 = @rewrite;
                    recursive_error_pages on;
                    fastcgi_split_path_info ^[^=](.+\.php)(/.+)$;
                    include fastcgi_params;
                    if ( $uri = /index.php ) {
                            # not sure this conditional works, will have to check the debug logs
                            break;
                    if ( !-e $document_root$fastcgi_script_name) {
                            return 418;
                    #NOTE: You should have "cgi.fix_pathinfo = 0;" in php.ini
                    #fastcgi_intercept_errors on; fastcgi_read_timeout 240;
                    fastcgi_pass 127.0.0.1:9000;
            # Fighting with ImageCache? This little gem is amazing.
            # Catch image styles for D7 too.
                    expires max;
                    log_not_found off;
    55,896
    12,281
    1:50 PM
    moved your post to more appropriate thread
    as to drupal config, i wouldn't know myself as I don't use drupal
    these aren't formatted correctly though
    should be
  10. nVidian
    nVidian Member
    98
    10:50 AM
    1.7.9
    5.5
    For SSL sites - there are 2 conf: mydomain.tld.conf and mydomain.tld.ssl.conf
    This is mydomain.tld.conf - Just replace mydomain.tld with your domain & myIP with your IP
    # redirect to https and also www to non www
             listen myIP:80;
            server_name mydomain wwww.mydomain;
            return 301 https://mydomain$request_uri;
            root /home/nginx/domains/mydomain/public;
                    log_not_found off;
                    access_log off;
                    allow all;
                    log_not_found off;
                    access_log off;
                    deny all;
                    deny all;
                    return 403;
            location @rewrite {
                    # (GlobalRedirect)
            location @rewrite {
            location ~ \.php$ {
                            break;
                            return 418;
                    expires max;
                    log_not_found off;
        return 301 https://mydomain.tld$request_uri;
      listen myIP:443 ssl http2;
      access_log /home/nginx/domains/mydomain.tld/log/access.log combined buffer=256k flush=60m;
      error_log /home/nginx/domains/mydomain.tld/log/error.log;
      ssl_dhparam /usr/local/nginx/conf/ssl/mydomain.tld/dhparam.pem;
      ssl_certificate      /usr/local/nginx/conf/ssl/mydomain.tld/webtivia_unified.crt;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/mydomain.tld/webtivia.key;
      # mozilla recommended
      ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA:!CAMELLIA;
      #spdy_headers_comp 5;
      ssl_buffer_size 1400;
      ssl_session_tickets on;
      # enable ocsp stapling
      #resolver_timeout 10s;
      #ssl_stapling on;
      #ssl_stapling_verify on;
      ssl_trusted_certificate /usr/local/nginx/conf/ssl/mydomain.tld/webtivia_trusted.crt;
    # include /usr/local/nginx/conf/pagespeed.conf;
    # include /usr/local/nginx/conf/pagespeedhandler.conf;
    # include /usr/local/nginx/conf/pagespeedstatslog.conf;
      # ssi  on;
                    log_not_found off;
                    access_log off;
                    allow all;
                    log_not_found off;
                    access_log off;
                    deny all;
                    deny all;
                    return 403;
            location @rewrite {
                    # Else this rewrite block wouldn't be needed (GlobalRedirect)
            location @rewrite {
            location ~ \.php$ {
                            break;
                            return 418;
                    #fastcgi_read_timeout 240;
                    expires max;
                    log_not_found off;
  11. nVidian
    nVidian Member
    98
    10:50 AM
    1.7.9
    5.5
    This is for NON SSL site
    mydomain.tld.conf
                    log_not_found off;
                    access_log off;
                    allow all;
                    log_not_found off;
                    access_log off;
                    deny all;
                    deny all;
                    return 403;
            location @rewrite {
                    # (GlobalRedirect)
            location @rewrite {
            location ~ \.php$ {
                            break;
                            return 418;
                    expires max;
                    log_not_found off;
  12. hardousse
    169
    35
    Sweden
    6:50 AM
    1.11.*
    10.1*
    thanks for all help evreythink work ok..
