vBulletin Help CSS in Vbulletin
Discussion in 'Forum software usage' started by computer19852007, Jun 26, 2014.
  1. computer19852007
    computer19852007 Member
    84
    2:18 PM
    Centmin Mod 1.2.3-eva2000.06
    MariaDB 5.5.34
    I have used Vbulletin Suite 4.2.2 P1
    My nginx.conf
        listen       80;
        server_name diendantinhoc.vn;
        return       301 http://www.diendantinhoc.vn$request_uri;
      server_name www.diendantinhoc.vn;
    ssi  on;
      access_log /home/nginx/domains/diendantinhoc.vn/log/access.log combined buffer=32k;
      error_log /home/nginx/domains/diendantinhoc.vn/log/error.log;
      root /home/nginx/domains/diendantinhoc.vn/public;
    autoindex  on;
      #autoindex_localtime on;
      #try_files         / /index.php;
    try_files $uri $uri/ @rewrite;
            location /includes {
            allow 127.0.0.1;
            deny all;
            location /packages {
            allow 127.0.0.1;
            deny all;
            location /vb {
            allow 127.0.0.1;
            deny all;
            location /admincp {
            #auth_basic "Private";
            #auth_basic_user_file /usr/local/nginx/conf/htpasswd;
    location @rewrite {
        # Forum
        rewrite    /threads/.*                /showthread.php?$uri&$args      last;
        rewrite    /forums/.*                /forumdisplay.php?$uri&$args    last;
        rewrite    /members/.*                /member.php?$uri&$args          last;
        rewrite    /blogs/.*                /blog.php?$uri&$args            last;
        rewrite    /entries/.*                /entry.php?$uri&$args           last;
        rewrite    /content/.*                /content.php?$uri&$args           last;
        # MVC
        rewrite    ^/(?:(.*?)(?:/|$))(.*|$)$        /$1.php?r=$2                    last;
    And i have post new Artice, and i have save it, but it reload and it show error: Please view image attach. I have config Store CSS Stylesheets as Files in admincp
    Please Help Me, @eva2000
    Thank you
    55,942
    5:18 PM
    did you make sure that /clientscript/vbulletin_css/*.css and /clientscript/*.js files actually do exist and to chmod 0777 the vbulletin_css directory as instructed in vB docs ?
    also for now comment out /usr/local/nginx/conf/block.conf line and restart nginx just to make sure there still isn't anymore conflicts with /usr/local/nginx/conf/block.conf
  3. computer19852007
    84
    2:18 PM
    MariaDB 5.5.34
    55,942
    5:18 PM
  5. computer19852007
    84
    2:18 PM
    MariaDB 5.5.34
    Thank you @eva2000
    I have used firefox, and it work. thank you
    55,942
    5:18 PM
    for Chrome, not sure if this would work but adding a Content Security Policy might help
    in your domain Nginx vhost try adding just below your
    the following line
    add_header X-WebKit-CSP "default-src 'self'; script-src 'self' data: 'unsafe-inline' 'unsafe-eval'";
    restart nginx server and see if it works
    check your browser's developer tools and console for blocked resources which are due to CSP
    You can use Content Security Policy generator at http://cspisawesome.com and/or http://cspbuilder.info to further customise your specific domain's CSP using browser developer tools/console for troubleshooting. I just did this for this forum's CSP and ended up with the following:
    More info on Content Security Policies at https://developer.mozilla.org/en-US/docs/Web/Security/CSP/Introducing_Content_Security_Policy and http://www.html5rocks.com/en/tutorials/security/content-security-policy/ and https://bitcoinsecurityproject.org/...policy-x-content-security-policy-x-webkit-csp
  7. computer19852007
    84
    2:18 PM
    MariaDB 5.5.34
    I have add and restart nginx, but it not working in google chrome
    55,942
    5:18 PM
    oh well worth a try :)
    edit: or try
    add_header Content-Security-Policy "default-src 'self'; script-src 'self' data: 'unsafe-inline' 'unsafe-eval'";
    55,942
    5:18 PM
