Having more then 1 site per VPS
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Matt Williams, Dec 10, 2014.
  1. Matt Williams
    537
    104
    Virginia, USA
    2:35 PM
    latest
    Hello!
    Is it possible to have more the 1 site on a VPS when running centmin mod? I did a test and setup the first site using the automated WP install script then did the same thing changing the domain name for the automated WP setup but one site resolved to the other
    domain.com
    resolved to
    domain2.com
    Do I need an additional IP address for each site and use option 3 from the menu? I know when I run the auto WP install script, it creates the vhost and installs WP
    Can you have mutiple sites under 1 IP or does each site need a dedicated IP to work?
  2. Inforit
    Inforit Premium Member Premium Member
    52
    15
    7:35 PM
    nginx/1.7.3
    MariaDB 5.5
    It should work, ok, I just tried and had no problem, first domain is also still ok.
    Check your domain.conf file see if all is correct there.
    55,335
    12,255
    4:35 AM
    @Matt Williams as @Ryder14 pointed out, you should have no problems using the Wordpress Auto installer script to setup multiple separate domains as they don't interact with each other from default Nginx vhost setup. Only if you're edited the Nginx vhost.
    Maybe post the Nginx vhost for both your domains wrapped in CODE tags for us to check out.
