Wordpress GZip not working with WP-Rocket
Discussion in 'Blogs & CMS usage' started by ArisC, Mar 29, 2018.
  1. ArisC
    ArisC Active Member
    125
    30
    7:06 AM
    Nginx Latest
    MariaDB Latest
    Hello, today I checked if gzip is working and it seems is not on my wordpress site using WP-Rocket as a cache plugin. It is enabled, I checked the demo site that is running with my server hostname... Where should I look to troubleshoot this. Thank's
    46,648
    10,590
    2:06 PM
    how you verifying if gzip is working or not ?
  3. ArisC
    ArisC Active Member
    125
    30
    7:06 AM
    Nginx Latest
    MariaDB Latest
    With this online tool Check GZIP compression
    Its not working on WordPress but it does with hostname (server1.domain.tld)
    BTW the server is in Linode with the stackscript.
    nginx -V
    nginx version: nginx/1.13.10
    built by gcc 7.2.1 20170829 (Red Hat 7.2.1-1) (GCC)
    built with OpenSSL 1.1.0h  27 Mar 2018
    TLS SNI support enabled
    configure arguments: --with-ld-opt='-ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib' --with-cc-opt='-m64 -march=x86-64 -DTCP_FASTOPEN=23 -g -O3 -fstack-protector-strong -flto -fuse-ld=gold --param=ssp-buffer-size=4 -Wformat -Werror=format-security -Wimplicit-fallthrough=0 -fcode-hoisting -Wp,-D_FORTIFY_SOURCE=2 -gsplit-dwarf' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-compat --with-http_stub_status_module --with-http_secure_link_module --with-libatomic --with-http_gzip_static_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module=dynamic --with-http_geoip_module --with-stream_geoip_module --with-stream_realip_module --with-stream_ssl_preread_module --with-threads --with-stream=dynamic --with-stream_ssl_module --with-http_realip_module --add-dynamic-module=../ngx-fancyindex-0.4.2 --add-module=../ngx_cache_purge-2.4.2 --add-module=../ngx_devel_kit-0.3.0 --add-dynamic-module=../set-misc-nginx-module-0.31 --add-dynamic-module=../echo-nginx-module-0.61 --add-module=../redis2-nginx-module-0.14 --add-module=../ngx_http_redis-0.3.7 --add-module=../memc-nginx-module-0.18 --add-module=../srcache-nginx-module-0.31 --add-dynamic-module=../headers-more-nginx-module-0.33 --with-pcre=../pcre-8.42 --with-pcre-jit --with-zlib=../zlib-cloudflare-1.3.0 --with-http_ssl_module --with-http_v2_module --with-openssl=../openssl-1.1.0h --with-openssl-opt='enable-ec_nistp_64_gcc_128'
    46,648
    10,590
    2:06 PM
    Use Chrome web browser dev tools network tab to check for gzip content or use curl compressed header check for Content-Encoding: gzip i.e.
    non-HTTPS
    curl --compressed -I http://yourdomain.com
    HTTPS
    curl --compressed -I https://yourdomain.com
    example for my Wordpress7 demo site
    curl --compressed -I http://wordpress7.centminmod.com/
    HTTP/1.1 200 OK
    Date: Wed, 28 Mar 2018 22:09:02 GMT
    Connection: keep-alive
    Vary: Accept-Encoding
    Link: <http://wordpress7.centminmod.com/wp-json/>; rel="https://api.w.org/"
    X-Powered-By: centminmod
    X-Cache: HIT
    X-Cache-2: BYPASS
    X-Frame-Options: SAMEORIGIN
    Server: nginx centminmod
  5. ArisC
    ArisC Active Member
    125
    30
    7:06 AM
    Nginx Latest
    MariaDB Latest
    Its working............ :mad: Sorry @eva2000
    46,648
    10,590
    2:06 PM
    Hehe.. only trust online gzip tools as far as you can throw them :D
    curl header checks and browser checks more accurate :)
