guide me uninstall xcache
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by paddy, Dec 28, 2014.
  1. paddy
    paddy New Member
    27
    6:21 AM
    1.7.7
    MariaDB 5.5
    hi , can someone gyuide me on how to completely remove xcache .. need to switch to APC Cache.
    thank you
    55,380
    12,255
    9:21 AM
    see Centmin Mod Insights forums info posted at PHP Opcode and Memcached statistics pages | Centmin Mod Community
    Just selecting centmin.sh menu option 9 to install APC Cache will auto remove Xcache. The same if you select to install Xcache (menu option 8) or Zend Opcache (menu option 12), it auto removes all other PHP opcachers - coded it that way :D
    Centmin Mod 1.2.3-eva2000.07 - http://centminmod.com
                       Centmin Mod Menu
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    14). SELinux disable
    16). Change SSHD Port Number
    20). NSD Re-install
    22). Exit
    Enter option [ 1 - 22 ]
  3. paddy
    paddy New Member
    27
    6:21 AM
    1.7.7
    MariaDB 5.5
    thank you eva , can u suggest a step to reduce high cpu usage or is there any trick to optimize ?
    55,380
    12,255
    9:21 AM
    Centmin Mod LEMP stack is provided as is and already has it's base Nginx, PHP-FPM and MariaDB MySQL settings with optimal starter settings. But there is no one size fits all so if your site(s) need more optimisation, that is left up to end user to do as I do not provide optimisation support for free. I do paid server optimisation consultation that starts in 4 figure $$$$ range for 4+ days or work but I am usually booked up several weeks and even months in advance in paying clients (like I am now).
    My advice is to figure out why and where cpu load is coming from first. Checking monitoring tools discussion monitoring and alert tools? | Centmin Mod Community as well as my mysqlmymonlite.sh script at mysqlmymonlite.sh Addon. Official site page is at mysqlmymon.com and the web site lists an example output of what type of server info and stats the script gathers. How to install video located at mysqlmymon.com/#video
  5. paddy
    paddy New Member
    27
    6:21 AM
    1.7.7
    MariaDB 5.5
    thank you , will check first with tools you provide :D
