Sysadmin Grub Help?
Discussion in 'System Administration' started by Jimmy, Sep 15, 2017.
  1. Jimmy
    12:06 AM
    Remember, you can always boot via the Grub with the commands above.
  2. rdan
    12:06 PM
    It works Great Now Sir!
    MANY MANY Thanks!
  3. Jimmy
    12:06 AM
    No problem. Glad to hear it works. :)
    12,574
    2:06 PM
    Excellent work @Jimmy (y):cool:
    Btw was what server specs you and jimmy have at OVH?
  5. Jimmy
    12:06 AM
    I have the SP-128 w/ NVMe
    12,574
    2:06 PM
    so sounds like for NVMe based servers, after a kernel update you need to rebuild grub before rebooting
    grub2-mkconfig -o /boot/efi/EFI/centos/grub.cfg
    reboot
  7. rdan
    12:06 PM
    SP-64-SGP Server - E3-1245v5 - 64GB
    With NVME also.
  8. Jimmy
    12:06 AM
    I've updated kernels before on this machine, never had to mess with the grub.cfg. Probably something to do with 7.4 IMO.
    I didn't get the time, but someone should submit a bug report or post a link to this thread on the Centos forum. My guess is when they tested for centos 7.4, they didn't use NVMe drives or no testers used NVMe.
  9. rdan
    12:06 PM
    Just tested this on my own server now, with new kernel update and yes work as expected :).
    There's no harm on running this in all server before rebooting right?
    Just to avoid issues.
    12,574
    2:06 PM
    if it works.. :)
  11. pamamolf
    4,128
    7:06 AM
    Recently (1-2 days ago) there was out an update related to grub2 for Centos 7 but don't know if there was a fix related to your issue or not....
  12. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    6:06 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    Confirm
  13. BamaStangGuy
    BamaStangGuy Active Member
    669
    192
    11:06 PM
    This thread was very helpful. Ran into this issue as well.
  14. rdan
    12:06 PM
    OVH & NVMe + CentOS 7.4?
  15. pamamolf
    4,128
    7:06 AM
    @RoldanLT
    Does that issue exist on latest kernel with Nvme ?
  16. rdan
    12:06 PM
    On OVH I think Yes.
  17. dcg
    dcg Member
    68
    24
    Florida, USA
    12:06 AM
    1.21.x
    10.3.x
    I just had the same issue with the upgrade. OVH Nvme
    Thanks @Jimmy for the fix. Worked fine
  18. pamamolf
    4,128
    7:06 AM
    Someone must fix it after so long time :)
    Did you notify them about the issue and let them know how you fix it so they can find out what is wrong and apply a proper fix?
    12,574
    2:06 PM
    Don't think it's a bug just another less documented issue with NVMe and efi bioses ? Will check it out if kernel updates comes on my OVH MC-64-OC 7700K with 2x450GB NVMe raid 1
  20. pamamolf
    4,128
    7:06 AM
    I just contact OVH and ask about that issue as a server that i was need to get has only this option for Nvme ssd's and not plain ssd's and they verify that the issue exists for latest Centos 7 :(
    That's really sad to not have a real solution for this one :(
    Now i have to remember to run those two commands before reboots and be lucky to boo again :(
