Sysadmin Grub Help?
Discussion in 'System Administration' started by Jimmy, Sep 15, 2017.
  1. Jimmy
    390
    12:01 AM
    I just upgraded to centos 7.4 and not the server hangs on the grub command and won't boot. Anyone good at working with Grub or know how to get my system working again?
    If this thread is in the wrong forum, please move it.
    Thanks!
  2. Jimmy
    390
    12:01 AM
  3. Jimmy
    390
    12:01 AM
    This is what the doc uses
    grub> set root=(hd0,1)
    grub> linux /boot/vmlinuz-3.13.0-29-generic root=/dev/sda1
    grub> initrd /boot/initrd.img-3.13.0-29-generic
    grub> boot
    I got the first line:
    grub> set root=(md/md2)
    Not sure about the second line. All my files are on (md/md2) so not sure if I would need root again???
    grub> linux /boot/vmlinuz-3.10.0-693.2.2.el7.x86_64 root=????
    Third line: don't see any initrd on the list? I only see initramfs. Would the line be:
    grub> initramfs /boot/initramfs-3.10.0-514.26.2.el7.x86_64.img
  4. Jimmy
    390
    12:01 AM
    Entering linux to start the second line gives me an error: "can't find the command 'linux'"
  5. Jimmy
    390
    12:01 AM
    What ended up working:
    grub> set prefix=(md/md2)/boot/grub2
    grub> insmod linux
    grub> normal
    Once the system restarted I ran:
    grub2-mkconfig
    Haven't rebooted yet, so not sure if the make config command works.
  6. Jimmy
    390
    12:01 AM
    So, I rebooted and still getting the grub prompt.
    I guess grub2-mkconfig didn't work.
    Any ideas? How to get the grub to work on boot?
  7. Jimmy
    390
    12:01 AM
    55,801
    12,271
    2:01 PM
    what type of server ? virtualisation ? which web host ?
    got access to out of band console/kvm console ? using distro default kernel or custom kernels ?
  9. Jimmy
    390
    12:01 AM
    This is on my dedicated server at OVH.
    Using default kernel. Yea, I have IPMI access.
    I can get system booted with the hack above from Grub. Can't seem to get the grub to update or don't know what I need to do to get the grub working again. Always boots to the grub prompt.
  10. pamamolf
    4,101
    428
    7:01 AM
    Nginx-1.26.x
    Isn't there a way to log the kernel issue to a log file on the system so you can check what the issue is?
  11. Jimmy
    390
    12:01 AM
    I'm not super savvy with the grub stuff, but I think it's something in the grub config that's the issue. I don't think anything will log if the grub prompt is as far as the system gets booting. I could be totally wrong though.
    55,801
    12,271
    2:01 PM
    output for
    awk -F\' '$1=="menuentry " {print $2}' /etc/grub2.cfg
  13. Jimmy
    390
    12:01 AM
    # awk -F\' '$1=="menuentry " {print $2}' /etc/grub2.cfg
    CentOS Linux (3.10.0-693.2.2.el7.x86_64) 7 (Core)
    CentOS Linux (3.10.0-514.26.2.el7.x86_64) 7 (Core)
    CentOS Linux (3.10.0-514.26.1.el7.x86_64) 7 (Core)
    CentOS Linux (3.10.0-514.21.2.el7.x86_64) 7 (Core)
    CentOS Linux (3.10.0-514.21.1.el7.x86_64) 7 (Core)
    CentOS Linux (0-rescue-1e98a4cc1263468b9f9a12e365316b95) 7 (Core)
  14. pamamolf
    4,101
    428
    7:01 AM
    Nginx-1.26.x
    Some related info:
    HowTos/Grub2 - CentOS Wiki
    grub2-mkconfig -o /boot/grub2/grub.cfg
    I think that should rebuild and fix your issue....
    55,801
    12,271
    2:01 PM
    Updated my OVH server fine
    uname -r
    @Jimmy what's output for
    grub2-set-default 0
    that should rebuild and then do reboot
  16. Jimmy
    390
    12:01 AM
  17. Jimmy
    390
    12:01 AM
    # grub2-set-default 0
    # grub2-mkconfig -o /boot/grub2/grub.cfg
    Generating grub configuration file ...
    Found linux image: /boot/vmlinuz-3.10.0-693.2.2.el7.x86_64
    Found initrd image: /boot/initramfs-3.10.0-693.2.2.el7.x86_64.img
    Found linux image: /boot/vmlinuz-3.10.0-514.26.2.el7.x86_64
    Found initrd image: /boot/initramfs-3.10.0-514.26.2.el7.x86_64.img
    Found linux image: /boot/vmlinuz-3.10.0-514.26.1.el7.x86_64
    Found initrd image: /boot/initramfs-3.10.0-514.26.1.el7.x86_64.img
    Found linux image: /boot/vmlinuz-3.10.0-514.21.2.el7.x86_64
    Found initrd image: /boot/initramfs-3.10.0-514.21.2.el7.x86_64.img
    Found linux image: /boot/vmlinuz-3.10.0-514.21.1.el7.x86_64
    Found initrd image: /boot/initramfs-3.10.0-514.21.1.el7.x86_64.img
    Found linux image: /boot/vmlinuz-0-rescue-1e98a4cc1263468b9f9a12e365316b95
    Found initrd image: /boot/initramfs-0-rescue-1e98a4cc1263468b9f9a12e365316b95.img
    done
    I'll try the reboot now.
    55,801
    12,271
    2:01 PM
    try rebooting now
  19. Jimmy
    390
    12:01 AM
    Nope. Grub command prompt.
  20. rdan
    1,412
    12:01 PM
    Yay so many issues with CentOS 7.4 :/.
